Old 04-02-2004, 04:37 PM   #1
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
Default Recirculating BOV
How many of you are running a recirculating BOV? Im using a blitz DD right now and Im wondering if the recirculating BOV's like the greddy and others can help me reduce turbo lag. im doubtful since im running only 6.6 psi that it would help much but i was wondering what are your guys' opinions?
Derk1127 is offline   Reply With Quote
Old 04-02-2004, 05:59 PM   #2
Andursun0013
Member#: 11616
1998 2.35RS-T
2006 Baja 2007 Leg. Wagon
i'm running a recirc. BOV but thats pretty much only because I have a MAF and it wouldn't run/idle right without a recirc. BOV
Kyle
Andursun0013 is offline   Reply With Quote
Old 04-02-2004, 06:13 PM   #3
Mancini
Member#: 20726
The only reason the recirc might help is that it's open at idle/part throttle, which could help some of the intake bypass the turbo. Probably not enough to be noticable though. Unless the recirc BOV opens at idle (like a stock WRX or 1G DSM BOV) it would have no effect on a MAP based car. I ran with both recirc and atmospheric BOV's on my 98RS-T and the only difference I noticed was in drivability with the MAF sensor, no noticable difference in spool-up.
Brian
Mancini is offline   Reply With Quote
Old 04-02-2004, 09:18 PM   #4
Unsung Boxer
Member#: 37196
Yeah, i had a WRX BOV venting to ATM, the car wouldnt idle with it. People dont realize the real problem with this is vacuum leak, not the venting to ATM part.
If you are using a stock BOV, it is prone to leak at idle and low RPMs. This results in a vacuum leak, which will cause a lean condition, ultimately causing lean misfires and poor idle. You can fix this by crushing the BOV, or buying a stiffer aftermarket one.
I am running 12PSI, on a 98MAF based ECU, venting to ATM w/ a TurboXS BOV, and no problems.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 04-02-2004, 09:46 PM   #5
Mancini
Member#: 20726
^ Right on! Just keep in mind the reason behind it staying open is to aid in spool up and response when the BOV releases at light throttle, or at least that's what I've always been told
Old 04-03-2004, 04:08 AM   #6
Unsung Boxer
Member#: 37196
spool and response has nothing to do with it, it is to reduce surge to the turbo compressor... I suppose if the valve is partially open, it might allow the turbo to spin for a millisecond longer, but once you open the throttle blade the turbo will hit full boost immediatly anyways...
If it makes a difference, I would like to hear the theory why.
-Jake
Old 04-03-2004, 07:09 PM   #7
Mancini
Member#: 20726
Well the theory is that it allows an unrestricted intake path to let air bypass the turbo, which "could" help get the motor spinning faster before the boost threshold. But like I said above if there is any benefit it was not significant enough for me to notice. By "response" I meant BOV response in light throttle release. Like you said above the recirc definately helps reduce surge. That's cause the response of the open recirc bov is much faster since it's already partially open at light throttle. Just thought I'd clarify what I meant.
Brian
Wtt hks bov for recirculation bov local Va beach Corpuz04 MAIC Private Classifieds 0 03-25-2010 02:23 PM
Atmospheric BOV vs Recirculating BOV GameMastyr Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-17-2003 09:41 PM
Recirculating BOV? Obscure411 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 04-04-2002 10:06 AM
Atmospheric or recirculating BOV? toerag Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 11-29-2001 07:27 AM
Fully Recirculating BOV Conduit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-15-2001 07:36 PM
