Old 04-02-2004, 07:57 PM   #1
ursine
Member#: 51771
2000 Impreza GC6 SRP
1980 G2 Celica Rally Taxi
Impreza GC8 Voltage Clamp
I am working on turbocharging my RS and I dont want to do anything crazy, just something in the 3-4 psi range (its my daily driver), I cant afford to run something like a Link so I am just going to use a Vortech RRFPR, a Power Inc. Fuel Pump and some injectors that according to part numbers should be STi injectors. And from doing research it appears that I need a Voltage Clamp, first off, what do they do? Secondly, based on my setup what kind should I get and how much should I expect to pay?
ursine is offline   Reply With Quote
Old 04-02-2004, 08:17 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
If you're going to go about it that way, just use a voltage clamp, fuel pump, and an RRFPR, do not install injectors as well. You might also consider some timing control or knock monitoring like a J&S Knock Computer which retards the timing as it hears knocking (before it even becomes audible).
Old 04-02-2004, 08:21 PM   #3
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
Since your car is factory NA, your ECU would go into fuel cut mode if it sees enough positive manifold pressure. The voltage clamp keeps the MAP voltage low enough to prevent the ECU from doing this. I think you can make these with about $5-10 worth of parts from RadioShack... there's really nothing to them.
ExecNav is offline   Reply With Quote
Old 04-02-2004, 08:28 PM   #4
ursine
Member#: 51771
Why not the injectors? Should I go with WRX ones instead?
Do you know where I can find directions?
Old 04-02-2004, 08:29 PM   #5
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
you can buy them from http://www.splitsec.com/products/clamps.htm.
There's also one built into the V2 J&S Safeguards and the Greddy e-Manage.
lotusTT is offline   Reply With Quote
Old 04-02-2004, 09:07 PM   #6
ursine
Member#: 51771
Would I be better off just getting one of these instead? How much do these run?
Old 04-02-2004, 09:13 PM   #7
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Yes, it would be much safer and more reliable.
They're both about $400-500 for everything you'd need to use them. For the e-manage, you'd need the main unit, ignition harness, support tool, and possibly the pressure sensor.
Old 04-02-2004, 09:16 PM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Injectors with just a RRFPR would lead to FAR too much fuel for the car, let alone when it's idling the ECU wouldn't be able to trim enough back.
Old 04-03-2004, 05:13 PM   #9
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
Hey I have a split second timing device, and a VC2 voltage clamp for sale. They came with my Forced air Tech stage 3 turbo kit, but im not using them anymore. I am just looking to get rid of them both let me know if you are interested. Pm'd you too BTW..
Pi7467mp is offline   Reply With Quote
Old 04-03-2004, 07:58 PM   #10
ursine
Member#: 51771
What does a split second timing device do? Do I need one?
Old 04-03-2004, 08:09 PM   #11
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
It retards timing per pound of boost. you don't "need" one to have a turbo charged car, but if you want reliable horsepower it is the way to go. I have heard of a lot of guys blowing motors, and knocking only under 6psi of boost.. with this you can pull timing 0-30 degrees, per pound of boost. It saved my butt a couple of times. Anyone else have any more input on this?
voltage clamp spgavin Normally Aspirated Powertrain 0 10-04-2001 12:51 AM
Proper voltage clamp? SubaFastR Normally Aspirated with bolt-on Forced Induction Powertrain 3 09-02-2001 04:40 PM
Check valve vs voltage clamp? wcbjr Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-28-2001 01:54 PM
voltage clamp, or check valve??? LVSUBARU Normally Aspirated with bolt-on Forced Induction Powertrain 15 08-24-2001 10:50 PM
Voltage clamp for MAP fix? NOT! JC SPORTS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-27-2001 08:23 PM
