Old 04-02-2004, 08:08 PM   #1
Boxer20
Member#: 25049
2002 Impreza WRX
Sedona Red
Default speedo converter
I'm getting an STi cluster and I'm looking to put in a converter for KPH to MPH. Anyone ever hook up one of these and where is a good place to pick one up?
Boxer20 is offline   Reply With Quote
Old 04-03-2004, 11:26 AM   #2
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Follow the link in THIS THREAD to answer your problems.
It's a small chip (smaller than quarter) with 4 lines coming off it that will allow your cluster to display your speed in MPH on the KPH scale. They're in GB, so shipping will take a while and be a bit, but it's worth it.
Great company. And you will want the one on the top, with black heat shrink over it.
AJ
AJ711 is offline   Reply With Quote
Old 04-04-2004, 08:10 PM   #3
the2rz
Member#: 46033
2008 BMW 335i
Silver/Black
so it only shows one or the other...not both?
the2rz is offline   Reply With Quote
Old 04-04-2004, 08:14 PM   #4
Boxer20
Member#: 25049
2002 Impreza WRX
Sedona Red
Yeah, I emailed them four times now and haven't had a response.
Old 04-04-2004, 09:33 PM   #5
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
It took them a while to reply to mine, though I did order first, so that might have had a thing to do with it.
All it does is take the pulses from the speed sensor (in MPH) and scales it so that the pulses that leave the chip correspond to a KPH speed.
Therefore, when you're doing 40 MPH, your speedo will show 40 KPH. My speedo goes from 0-180(MPH) now with this chip and the JDM V5 cluster.
AJ
Old 04-05-2004, 08:07 AM   #6
Boxer20
Member#: 25049
2002 Impreza WRX
Sedona Red
I have a V7 cluster so I hope that the solder points are the same as the one in the pic in the thread link you gave me. Thanks for the link BTW, very helpful! Of course, now I guess I just have to wait until they contact me. I ordered one last week on Tuesday and fired off a couple more emails throughout the week. I will write again tomorrow. They must not check their emails very much.
Old 04-05-2004, 08:44 PM   #7
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
The solder points may not be the same, but all you will need to do is find the following;
1) +12v
2) ground
3) speed signal wire
Just clip the speed signal wire, and connect the chip as told from the instructions provided, and you will be done.
Personally, interupting a wire is a bit simpler to visualize and do than interupting the circuitry on the back of the cluster.
Good luck with things, glad I could help out.
AJ
Old 04-06-2004, 07:13 PM   #8
WS6toWRX
Member#: 25087
2004 WRX sedan
WR Blue
where is the speedometer line? I have the heads up siaply tach/speedo and i need to know which wires to tap. for the tach and for the speedo.
WS6toWRX is offline   Reply With Quote
Cat Converter hangman Normally Aspirated Powertrain 1 06-02-2010 09:14 AM
FS: Speedo converter / Delimiter KPH-MPH Matt A Interior/Dressup/Audio & Security 4 01-11-2008 09:32 AM
Toyota Solara Convertable vs. Saab 9-3 Compact Convertable 2k2 Off-Topic 20 12-16-2004 01:11 AM
Speedo quit, CEL: bad speed sensor or speedo gear? superg Transmission (AT/MT) & Driveline 4 06-20-2004 03:49 PM
Convert your Kph speedo to Mph lenyx New England Impreza Club Forum -- NESIC 1 02-12-2003 10:09 PM
