Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 04-03-2004, 12:54 AM   #1
Unabomber
Amish Rake Fighting
Member#: 18062
is available for
purchasing
ALK FAQ
Boost Control FAQ
BOV FAQ
Car Buying FAQ
Car Storage FAQ
Clutch & Flywheel FAQ
Cooling System FAQ
Differential FAQ
Downpipe FAQ
Engine Management FAQ
Exhaust FAQ
FMIC FAQ
Gauge FAQ
Header FAQ
Injector, Fuel Pump, and Fuel Rail FAQ
Intake FAQ
Intercooler Hose FAQ
Maintenance FAQ
Oil FAQ
OT FAQ
Piston FAQ
Pulley FAQ
Search FAQ
Shifting FAQ
Shipping FAQ
Soldering/Electrical FAQ
Spark Plug FAQ
Spring/Strut/Coilover FAQ
Subaru FAQ
Subaru Caravan FAQ
Subaru Meet FAQ
Suspension & Driveline FAQ
TGV Deletes FAQ
TMIC FAQ
Tool FAQ
Transmission FAQ
Tuner FAQ
Turbo FAQ
Turbo Inlet FAQ
Turbo Timer FAQ
Uppipe FAQ
Wheel FAQ
Not mine, but "Unabomber approved":
Alky/Water/Meth Injection FAQ
Catch Can FAQ
Swaybar FAQ
With these FAQs, I try to be product neutral and just give facts, or when facts are not available, quote "common logic". These FAQs are by no means all encompassing. They are meant to fill in 80% of the gaps, shorten your personal research time, and narrow your future search parameters. As information changes, I update these from time to time as well. I strive for accuracy, so if you see an error, please let me know. I do not "subscribe" to any of these FAQs, so if you have a correction, please make it in the thread and I will research and update when I have time.
How to make your car faster and reduce the stress on your transmission
This post contains my opinion of the "best" commonly used power upgrades.
This post contains my guide to buying items on eBay.
This post contains a simplified version of how to do the H-6 rear brake upgrade on a WRX.
This post contains every type of mud flaps available for the WRX/STi.
This post contains questions no one on NASIOC can answer.
This post contains my exhaust dB testing info.
This post contains my interview with Kartboy.
This post contains my interview with Turn in Concepts.
This post contains my interview with Mach V.
This post contains my interview with OAKOS Automotive.
This post contains upgrades you can do to with a Cobb Accessport other than a TBE.
This post contains my opinon as to first level modifications.
My old dyno results
My new dyno results
My new, new, new dyno results
My new, new, new, not playing around new dyno results
What I have on my car for those with interest:
2004 Subaru WRX Sports Wagon
Power Mods
JDM STi BPV $50 (Dentsport)
Perrin Pulley $125 (Kastle's Korner)
TurboXS Stealthback no cat version $600 (Nino's)
Massiv USA catback $0 (Massiv USA hook-up)
Grimmspeed ported exhaust manifold elbows $0 (Grimmspeed hook-up)
Grimmspeed exhaust manifold crossover pipe $0 (Grimmspeed hook-up)
Grimmspeed Uppipe $0 (Grimmspeed hook-up)
CSS Performance FMIC $0 (CSS Performance hook-up)
Ported Deadbolt Super16G $g-14 classified (Deadbolt hook-up)
TGV deletes $0 (Andrewtech Automotive, deleted by me)
Walbro fuel pump $100 (Andrewtech Automotive)
APS turbo inlet $200 (private sale on NASIOC)
Deatschwerks 650cc injectors $0 (Deatschwerks hook-up)
Cobb AccessPORT & StreetTUNER $600 (Cobb hook-up)
SPT Intake $150 (local dealership)
ProTUNE by Dan @ Mach V
Prodrive BCS $0 (Mach V hook-up)
Driveline Mods
STi short shifter (installed option) (later given away, so I only have the linkage)
Whiteline Steering Rack Bushings $0 (TiC hook-up)
Kartboy short throw shifter $0 (Kartboy hook-up)
Kartboy pitch stop mount $0 (Kartboy hook-up)
Kartboy shifter bushings $0 (Kartboy hook-up)
Kartboy rear shifter bushings $0 (Kartboy hook-up)
Kartboy rear differential bushings $0 (Kartboy hook-up)
Kartboy transmission bushings $0 (Kartboy hook-up)
Turn in Concepts rear differential mount bushings $0 (TiC hook-up)
Turn in Concepts pivot bushings $0 (TiC hook-up)
PPG helical syncro 1-4 gears $3500 (Andrewtech Automotive)
ACT SB3-HD00 clutch/pressure plate $250 (local hook-up)
Suspension Mods
OEM 2003 20 mm sedan rear sway bar $0 (local hook-up)
OEM 2004 STi rear sway bar bushings $6 (Local dealership)
OEM 2004 STi strut/spring assemblies $0 (local hook-up)
eBay H brace $0 (local hook-up)
Kartboy droplinks $0 (Kartboy hook-up)
Kartboy front end links $0 (Kartboy hook-up)
Whiteline subframe lockout bolts $25 (Turn in Concepts)
Whiteline comfort ALK $0 (local hook-up)
eBay front strut tower bar $0 (local hook-up)
Tire/Brake Mods
H-6 brake upgrade $250 (Local dealership)
Falken 512 205/45-16 tires $270 (Edge Racing)
Black Muteki Lightweight Lug Nuts $0 (local hook-up)
Goodridge stainless steel brake lines $0 (local hook-up)
ICE Mods
Infinity Reference Series 6010cs 6 1/2" speakers + Infinity tweeters in the front doors $130 (eBay)
David Navalone line out convertor $30 (local hook-up)
Rockford Fosgate 8 gauge power amplifier kit $35 (eBay)
Alpine 3555 Amplifier $100 (local hook-up)
OEM subwoofer (installed option)
Omori Boost Gauge $100 (j-Spec)
Raammat $115 (Raammat)
PSI3 ECU Data Monitor $0 (Turn in Concepts hook-up)
Exterior Mods
Narva Rangepower+50 H1 lowbeam headlight bulbs $26 (Daniel Stern Lighting)
2004 STi hoodscoop $1 (ebay auction, somebody screwed up )
2004 STi splitter $90 (Local dealership)
2004 STi shroud $40 (Local dealership)
OEM 2004 Impreza TS mud flaps (modified to fit) $70 (Local dealership)
OEM STi fog light covers $120 (local dealership)
Other Mods
Fumoto Oil Valve $30 (fumoto.com)
Throttle body bypass mod $2 (Home Depot )
Crucial Racing Thermostat $65 (Nino's)
PIAA silicone wiper blades $60 (Mach V)
Davenow grounding mod $10 (via me)
Kartboy battery tie down $0 (Kartboy hook-up)
ThermoTec turbo wrap $35 (jegs.com)
Hondata phenolic gaskets $60 (Gruppe 5)
SPT oil cap $0 (local hook up)
And since there has been a request for it, here are the maintenance items/fluids I use so far:
1. Motor Oil: Whatever 5W-30 synthetic is on sale.
2. Drain plug: Fumoto Oil Valve.
3. Oil filter: Purolator Pure One, the high dollar extra filtering yellow sand coated version.
4. Transmission fluid: Redline lightweight shockproof with 1 quart of Mobil to thin it out.
5. Differential fluid: non synthetic 75W90 generic Dollar Store stuff.
5. Air Filter: SPT Intake. When I had the stocker, I just used OEM paper panel filter.
6. Coolant: Subaru cooling system conditioner, Red Line Water Wetter, 1 gallon of distilled water, and 1 gallon of Peak Global Extended Life coolant.
7. Brake Fluid: Valvoline generic stuff or whatever is on sale at the Discount Auto at the time.
8. Spark Plugs: Denso iridium IK22 one step colder .030 gap
Oh and in case you are wondering.....it's just a dumb username, there is no meaning behind it.
Ron from Virginia Beach
Old 04-03-2004, 01:43 AM   #2
Uncle Scotty
Member#: 16200
bah straw and coal
straw and coal as always
Man.....Uncle Sam must LOVE that handle
Good work, Ron.
Old 04-03-2004, 02:24 AM   #3
Aphex28
Member#: 11506
93L beat0rz & 2000
RS STM 300hp o goodness
Wow... damn nice work dude!
Aphex28 is online now   Reply With Quote
Old 04-03-2004, 05:00 AM   #4
OnlyKor..
Member#: 34335
03 Impreza WRX
I think this one's a STICKY!!
OnlyKor.. is offline   Reply With Quote
More Hot Topics on NASIOC...
Old 04-03-2004, 06:22 PM   #5
gamoi
Member#: 51125
2004 Wrx Wagon
Slippery Silver
gamoi is offline   Reply With Quote
Old 04-03-2004, 08:17 PM   #6
Dave6265
Member#: 51583
02 02 GDA WRB
aka-Th3BlindMice
very nice, great writeup
Dave6265 is offline   Reply With Quote
Old 04-04-2004, 04:39 PM   #7
NeedAWD
Member#: 30831
2004 WRX
Java Black Pearl
Default Re: Unabomber's Manifesto
NeedAWD is offline   Reply With Quote
Old 07-05-2004, 05:33 PM   #8
allxusedxup
Member#: 63101
2002 Stage 2 WRX
Sedona Red
excellent work
allxusedxup is offline   Reply With Quote
Old 07-05-2004, 06:03 PM   #9
collegedropout
Member#: 42569
adds to the douchery
level round' here...
nice to see the whole Unabomber FAQ collection....but can I get that in a gold embossed box set?
why no Fireworks FAQ?
collegedropout is offline   Reply With Quote
Old 07-05-2004, 09:11 PM   #10
Davenow
Member#: 23676
Where is the Davenow FAQ????
Old 07-05-2004, 09:12 PM   #11
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
nioce!
Bishop is offline   Reply With Quote
Old 07-05-2004, 09:15 PM   #12
kinkinhood
PBE Specialist
Member#: 54934
199 Miata
I think this one needs a sticky!
kinkinhood is offline   Reply With Quote
Old 07-05-2004, 09:41 PM   #13
Cole
Member#: 64219
2004 WRX FunWagon
2008 Legacy NA Hellastock
Second that
Cole is online now   Reply With Quote
Old 07-05-2004, 11:30 PM   #14
Brad Pittiful
Member#: 34931
Dee Dee Ramone says
eat dope and potato chips
hondaslayer has it in the scooby guru only forum
Brad Pittiful is online now   Reply With Quote
Old 07-05-2004, 11:41 PM   #15
Trip McNealy
Member#: 37338
2007 Legacy 2.5 GT
2009 Daytona 675
View Member's Myspace Profile
FAQ MastAr!!
Trip McNealy is offline   Reply With Quote
Old 07-06-2004, 12:58 AM   #16
fansipans
Member#: 62991
fansipans is offline   Reply With Quote
Old 07-06-2004, 01:01 AM   #17
Hondaslayer
Spay and neuter your OTters
Member#: 4562
1990 Mazda Roadster
Fear my 1.6 litre of fury
Werd up, Guru level card holders only beeotch!
Old 07-06-2004, 01:04 AM   #18
Uncle Scotty
Member#: 16200
bah straw and coal
yeah...
Old 07-06-2004, 01:38 PM   #19
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
I think Scotty has a point about Uncle Sam. Plus the words "unabomber" and "manifesto" used in conjunction like that probably attract some unwanted attention I would think.
DrBiggly is online now   Reply With Quote
Old 07-06-2004, 05:20 PM   #20
dazed/confused
Member#: 62721
2004 Impreza WRX
Platinum Silver Metallic
*big slimy NEWBYHUG! for Unabomber*
Though I think I'd read them all already, this definitely saves space in my favorites list . Keep up the great work Uni, and the community lubs you!
*Proud member of NASP -- Newbies Against Stupid Posting*
dazed/confused is offline   Reply With Quote
Old 07-07-2004, 12:47 PM   #21
Cole
Member#: 64219
2004 WRX FunWagon
bump for the manifesto.....sticky potential is off the charts....
Old 07-07-2004, 12:54 PM   #22
IntraWRX
Member#: 20773
Midnight Black Pearl
IntraWRX is offline   Reply With Quote
Old 07-07-2004, 12:55 PM   #23
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Riiiiiiiight.
Old 07-07-2004, 01:33 PM   #24
scoobieREX
Member#: 25008
orginially
founded by Germans...
I tried to contact North Uraslia to put this up with the other FAQs but he doesn't accept PMs and I can't report the thread to a mod because someone else already did it...
scoobieREX is offline   Reply With Quote
Old 07-07-2004, 01:36 PM   #25
lax13
Member#: 62493
2004 WRX
World Rally Blue
awesome post, thank you.
lax13 is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 12:46 PM.
