Old 03-31-2004, 01:46 AM   #1
JoeBloggz23
Member#: 4612
2014 Forester XT
Satin white pearl
Default Problem with morrette high beams!
hey guys, tonight while I was driving! I tried putting my high beams on and I got nothing. then I kept trying and they began to flicker on and off!! After keeping them on they continued to flicker on and off! Not sure what has gone wrong?
Eric
JoeBloggz23 is offline   Reply With Quote
Old 03-31-2004, 06:31 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Was it both high beams? If so check the wire from the Morettes to the battery positive, make sure the connection is secure. That is the high beam power. Also check the fuse inline with that wire, it should be firmly inserted in the fuse holder.
Old 03-31-2004, 07:31 AM   #3
Imprezive2002
Member#: 18872
2002 Impreza
mine is similar but only does it when i hit the brights the right side projector flickers and sometimes goes off so i have to shut the fog lights off first then hit the brights. Check the stock plug that use to go on the stock headlight mine was like black around some of the prongs you might have to clean it; i used sandpaper i guess its working good luck `Nick
Imprezive2002 is offline   Reply With Quote
Old 03-31-2004, 07:44 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Imprezive, do you have HIDs?
Old 03-31-2004, 11:16 AM   #5
Imprezive2002
Member#: 18872
2002 Impreza
no i do not have Hids just the morettes with projecters and Phillips bulbs.
Old 04-01-2004, 05:36 PM   #6
JoeBloggz23
Member#: 4612
2014 Forester XT
Satin white pearl
Thanks, Mulder I'll check it out!
One other thing I noticed my passenger low beam is out. The morrettes are a little over 1 year old and I have the same bulbs that came with them. Did it blow out already? Shouldn't they last longer than that?
Eric
Old 04-01-2004, 07:59 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
One year on a bulb is not that unusual. Definitely check the bulb itself before tearing into the wiring on that side. If it's not the bulb you can also check the headlight fuse for that side, with Morettes the factory headlight circuits only power the low beams since the high beam power comes straight from the battery.
Old 04-02-2004, 04:52 AM   #8
JoeBloggz23
Member#: 4612
2014 Forester XT
Satin white pearl
Ok, I'll check it out!
Damn, one thing leads to another. Tonight I noticed, while the car was off, the high beam indicator light was illuminated on the dash??? When I start the car and hit the high beams it goes off?? *** is going on ??
Eric
Old 04-04-2004, 04:14 PM   #9
JoeBloggz23
Member#: 4612
2014 Forester XT
Satin white pearl
bump
How Can I Make My Low Beams Stay on With the High Beams? subarumafia700 Interior & Exterior Modification 3 09-24-2009 02:54 PM
Morrette High Beams Subyman01 Electrical & Lighting 1 11-04-2004 11:14 AM
Morrette ....High Beams out wolf8314 Electrical & Lighting 2 06-12-2003 01:46 AM
Has anyone rewired there fog lights so they could run with the high beams on? subisrule Interior & Exterior Modification 21 06-12-2001 08:24 AM
Fog Lights on with the High Beams VwFreak96 Interior & Exterior Modification 9 03-20-2001 11:34 AM
