Closed Thread
Old 04-03-2004, 05:24 AM   #1
5spd Alcyone
Member#: 34383
1992 SVX-T3/T04E
Dark Teal Metallic
Angry battery got hooked up backwards, need help finding gremlins
Well to make a long story short, the battery got installed backwards in my SVX today. blew the fusable link. Fixed that and i have the following problemes:
1)radio works. The CD player dosnt work. But the lights on the cd player works and if i hit the eject button 2 times(yes only if twice) then the dash lights blink off for a second and then back on.
2)The clock is half lit. is keeping time perfectly.
3)Memory of stations resets everytime the car is started(radio is off when i turn it back on
4)when the car is on and i open the doors, the lights on the dash go off. I have no lights function in the doors or dome. dimmer switch does work and so does the bright button(cuases a little bit more light on the clock as well.)
5)Security system dosnt arm with the remote. lock and unlock however does work. When i hit the secuirty button on the dash it blinks repetitivly and quickly.( im not that worried about fixing this one.)
Other then these weird gremlin glitches the car runs great. I suspect i blew out a control module somewhere along the way and its a matter of finding out which ones.
BTW no fuses blew other then the fusable link, so i find these problems very odd as if the power made it past hte fusable link it would have blown any fuse that gets power when the battery is connected.
if you can help me at all it would be much apreciated . Im in madison wi.
phil
5spd Alcyone is offline
Old 04-03-2004, 09:30 AM   #2
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
Default Re: battery got hooked up backwards, need help finding gremlins
The best gess is that the hand full of fuses for all of the peices = more than main fuseable link
Reguardless, not knowing the internals of an SVX you may endup replacing every module in the car...
I'd start by taking out the stereo & doing some tests on the car...
Try & find the back feeds/broken circuits from the toasted diodes.
Keep pulling parts untill the problems go away & replace as necessarry.
GLwagon is offline
Old 04-03-2004, 01:38 PM   #3
5spd Alcyone
Member#: 34383
1992 SVX-T3/T04E
Dark Teal Metallic
Every single problem fixed. All hot circuit fuses were not visibally blown but upon replacement work. Including my secuirty system(which nevr worked)
phil
Old 02-10-2007, 09:05 PM   #4
doogsdouglas
Member#: 138462
1998 Legacy OB 2.5l
Redish
Default Similiar Problem
What was the first thing you looked for once you hooked the battery up wrong?
doogsdouglas is offline
Old 02-10-2007, 10:28 PM   #5
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Smoke?
This thread is almost three years old, you might keep that in mind when you're posting in threads you found while searching.
BlkTS02 is offline
Old 02-10-2007, 10:35 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
+1, please don't bump ancient threads and expect a response from the original poster.
Mulder is offline
Closed Thread
What my BCS lines are hooked up backwards? live_2race Texas Impreza Club Forum -- TXIC 5 08-22-2008 04:36 AM
I got the hook up! Anyone need a detail? mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 11 09-20-2006 10:08 PM
so sdfi just got the treo 600 and i need help find a free version of AIM for it. bubba03wrx Off-Topic 2 08-21-2004 07:43 PM
AVCS hook up problem need help fatray Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-03-2004 03:39 AM
Autometer a/f ratio gage- best location to hook up power. Need help quick-please. odin1 Electrical & Lighting 11 12-09-2003 01:17 AM
