Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 04-03-2004, 06:18 AM   #1
kaos200
Member#: 2692
Default Trying out new oil catch line routing
Ok, im blowing out way too much oil at high boost. And I think its because of two main things...
1) there are no baffles on the sti valve covers inside under the hole like there are on the std. wrx valve covers.
2) the way I HAD my lines routed. they just dumped into the catch can, and the pcv was t'd in at the back of two of the lines (and not the third)
so now Im doing this...
the two main block holes, T into each other with a line from them to the firewall, where it meets the valve cover lines (which are travelling uphill to get here)
From there, they all t into a line that goes into the catch can, and the other hole in the catch can goes directly to the pcv. It is now a fully sealed system in which vaccum is being applied to all ports equally.
What do you think? Im going to try it anyways (as long as the local shop has the few fittings I need) So I guess Ill find out soon enough
kaos200 is offline   Reply With Quote
Old 04-03-2004, 07:45 PM   #2
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Default Re: Trying out new oil catch line routing
1. Where is your turbo oil return going?
2. Are all your tees "uphill" from all the valve covers even under hard cornering?
I studied the WRX and Legacy Turbo PCV lines, and realized that they both had "traps" to make sure that oil never gets a free "downhill" ride from the valve cover breathers to the PCV valve (or to the oil catch can) under hard cornering. The block holes don't seem to have this problem, so I left the rear one hooked up to the PCV valve and simply plugged the front hole.
Hope this helps,
-WaC
Wayne
wac is offline   Reply With Quote
Old 04-04-2004, 05:09 AM   #3
kaos200
Member#: 2692
1) it goes to the oil pan
2) they are now
How much pressure of oil going out the oil return line? albie1kanobi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 11-15-2007 04:52 PM
Brand New Oil Catch Can PPhilthy Engine/Power/Exhaust 19 08-01-2006 01:39 AM
swapping out my td04 for a used vf turbo. Do I need a new oil drain line gasket? garie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-30-2005 12:44 PM
new oil catch can ttenneb Interior & Exterior Modification 0 03-27-2004 12:49 PM
Check out my oil catch can install jetguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 07-30-2002 12:50 PM
