Old 03-10-2001, 04:13 AM   #1
myko011
Member#: 3500
Post Is taking the turns AWD the same as FF?
Is it like in Gran Turismo, where you just keep an flooring the pedal, and keep the steering wheel in the direction of the turn? I'm guessing its probably not like rear wheel drive where you may need to counter steer. Just wondering cuz I've never drive a awd car. thx guys
myko011 is offline
Old 03-10-2001, 04:51 AM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
On our Subarus, we have little sway bars, so there is more understeer than oversteer. So, in a way, it will act like a FWD on dry pavement.
However, on snow, that's another story. The front will pull you to the direction you want, then the back-end will throw the car out to the outside if gas is stepped hard. That's also how I make small-radius donuts to take advantage of these 2 effects. So, in this case, you need to countersteer heavily.
tmat3 is offline
Old 03-10-2001, 05:10 AM   #3
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
not always, though. There are plenty of times on snow, where it's like FWD. The only differece being, in this car, if you do steer harder, and gas it, it usually corrects that understeer.
but on regular turning, it's much different than FWD. Yes, it'll understeer at first, but once you can break more traction, just point the fronts to where you want to go, and gas it! you'll go there.
JGard is offline
Old 03-10-2001, 05:26 AM   #4
Fish
RIP Sirkbac
Member#: 869
1987 GPZ-750 TURBO
90' MX-5/11' DGM STi Sdn
Post
toss a 20mm on that bad boy.. even it out..
I did, the car is rather neutral for the most part.. but withm effort you can get it to oversteer or understeer based on input.
Fish is offline
Old 03-10-2001, 08:21 AM   #5
smacksube
Member#: 4067
01 2.5 rs
Post
hmm, considering the differential and the softness of the stock suspension, the rs tends to act like a fwd car on pavement, however, and this is a big one, if you get brave enough to do this it's super cool and nutso! It works best with 90 degree turns and I wouldn't do it on a racetrack cuz it's probably impractical, but go into the corner with a hard turn, when you hear the front wheels strating to squeal, hit the brake moderately hard for a split second, just enough time to transfer weight off the back of the car, this will swing the rear axel around like a hand brake turn, pop the beoch into 2nd and fly away, it looks super cool and I've perfected it up to 60 mph, but don't flip over! And do 'race style driving' mad responisibly!
smacksube is offline
Old 03-10-2001, 08:30 AM   #6
codemunky
Member#: 1804
Post
As far as turning, in AWD, the tires will squeal later (w/ LSD) FF will squeal once you gun that turn. I'm having too much fun... AWD is like turning on rails. On wet, powerslides are easily controlled.
codemunky is offline
Old 03-10-2001, 11:23 AM   #7
Skirvdawg
Member#: 3375
2002 VW Jetta Wagon
Post
Some things I can't do with AWD on dry pavement:
Spin the tires from a stop.
Spin the tires going through a turn.
Spin the tires...oh, you get the point.
Cool stuff you can do in the wet w/AWD:
Powerslides.
Gun it from a stop and still not spin the tires.
Throw rooster tails of water, dust, sand, whatever on the car behind you.
Save your a** when that exit on the highway comes up a little faster than you thought.
Cool stuff you can do in the snow:
Just about anything you can't do w/FWD.
Skirvdawg is offline
Old 03-10-2001, 01:55 PM   #8
Keiho
Sea to Sky - OWNED
Member#: 610
2003 Lexus IS300
Graphite Gray Pearl
Post
Try a big empty parking lot.
Or even at an autocross track.
Keiho is offline
Old 03-10-2001, 11:39 PM   #9
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Post
Myko, if you have a playstation, go rent Colin Mcrae Rally Racing 2.0... You can adjust the power distribution on those cars AWD from front to back to 50/50 and various degrees inbetween. Its a good way to see the differences...
You can also get it for the PC (which is actually better IMO cause you can get better resolutions and maybe custom cars later) and I just saw it in a Add at Fry's for $19! Check it out...
Kostamojen is offline
Old 03-11-2001, 12:39 AM   #10
myko011
Member#: 3500
Post
I wonder where be a good place to practice this stuff. Sounds like if I mess up.... I'll be a goner. I'm kinda in this fear stage rightnow, because my last car was rwd, and I my tail went loose on a turn and all hell broke out!! I just gotta keep telling myself.... Mike, don't close your eyes. hehe oops
myko011 is offline
Old 03-11-2001, 08:18 AM   #11
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Post
Under power, AWD usually understeers quite a bit less than FWD (assuming the same chassis). Mostly that's because you have double the contact patch to work with. But assuming a smooth turn-in, there is litle or no power-on oversteer associated with AWD cars. They tend to straighten up under the power. Which is why, if something goes wrong and you end up sideways, hit the gas!!!! The car will take care of itself. You just have to try not to hit anything.
And that, my friends, is why I'm probably going to have an AWD car in my garage for the rest of my life.
By the way, many JDM WRX's have planetary center diffs that bias the rear in order to give some RWD-like power on oversteer. Personally I think the whole idea of setting up an Impreza for the dry track is kinda silly, but that's another story.
[This message has been edited by Necromancer (edited March 11, 2001).]
Necromancer is offline
Old 03-11-2001, 08:45 AM   #12
kelley nelson
Member#: 135
Post
It's more like FWD than RWD, but there are still a lot of differences. With power going to all four wheels you can really take advantage of tricks from both the FWD and RWD camps.
My quick general answer is that AWD is more forgiving and easier to drive aggressively than FWD or RWD. If there is enough available traction you can recover from most situations just by staying on the gas and using the standard 'steer into the skid' rules. (One thing that can be pretty counter-intuitive to people used to FWD or RWD)
Of course this won't help you if you are just going to damn fast, which doesn't leave you enough room to do that recovery maneuver.
The tricks of the trade are the ones that let you make the most use of the available traction
kelley nelson is offline
HTML code is On
Is the starter for Impreza same as Impreza Outback Sport? Ptero 1993 - 2001 Impreza Specific Parts 2 05-28-2010 06:08 PM
Is Brembo Gran Turismo brake kit same as 2004 STi Brembos? lotarg Brakes, Steering & Suspension 9 10-07-2008 12:51 PM
Is the 2006 rear-end same as earlier models? ElementalFiend Normally Aspirated Powertrain 7 05-18-2006 06:39 AM
is the baja 2.5L same as STI? spike africa Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 05-15-2006 09:29 PM
is the 2.5 rs(2002) same as the sti motor? DennisAltered Mid Atlantic Impreza Club -- MAIC 5 03-10-2005 06:27 PM
