Old 04-03-2004, 07:49 PM   #1
InfamousDX
Member#: 25413
Default Reset Air Bag Light?
Bottom line is my air bag light is on and I don't know how to reset it. All the connections are good so it's not that. I hear there is a certain way to reset airbag lights and I don't know how. Anyone have any info? Thanks.
Old 04-03-2004, 07:56 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There is a procedure in the service manual to check for codes when the airbag light is on.
Was the car in an accident where an airbag deployed, or did the light just come on for no apparent reason?
Old 04-03-2004, 08:10 PM   #3
InfamousDX
Member#: 25413
Pretty much... switching interiors. The clips of the harness broke off so no way to unplug them so we had to cut and then resplice/solder them back. Stupid, I know. Thanks for the tip.. will look in the service manual.
Old 04-05-2004, 09:28 PM   #4
InfamousDX
Member#: 25413
Anyone else? The manual just says to keep bringing it to the damn dealer
Old 04-05-2004, 10:53 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What manual are you looking at? The factory service (not owners) manual has a diagnostic procedure for the airbag system that you can do yourself to get the codes, no special scanner is needed.
Old 04-06-2004, 01:12 AM   #6
InfamousDX
Member#: 25413
Oh ***** my bad... factory service. I guess I will be visiting my mechanic or body shop to check one of these out.
Old 04-08-2004, 08:45 PM   #7
InfamousDX
Member#: 25413
Help³ ?
Old 04-08-2004, 09:03 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
So where do you stand on this? Do you have access to a manual?
Old 04-10-2004, 07:34 AM   #9
949
Member#: 58906
maybe you cross wired it. cause mine came on when i took out the driver seat and for got to replug it in. but when i pluged it in ,,, it took about 10 mins then the ecu saw it and then just turn the light off, its been off ever since with no problems. this is awesome cause with my accord i needed to have honda reset with some money with it.
949 is offline   Reply With Quote
Old 04-19-2004, 12:14 AM   #10
db8 na
Member#: 53567
1995 Integra GSR
Frost White
sup its jeff.
i dunno if you still have the airbag light on, but when i swapped wrx seats with sti seats, i got an airbag light when i had only the driver's seat harnesses connected while the passenger front wasn't yet. if you didn't already, check if you cross-wired the passenger harness or re-connect that harness cuz even that one could set off that annoying airbag light on the gauge cluster. if you need another harness, i might have 1 or 2 extra if i didn't break them already call me a noob, but those yellow harnesses are mad f***ing hard to take off.
db8 na is offline   Reply With Quote
Reflash+ECU reset = Air Bag Light? chrisdeaner Engine Management & Tuning 2 10-09-2007 02:31 PM
Air bag light reset ... MoMoZzz Vancouver Impreza Club Forum -- VIC 19 01-13-2007 11:26 PM
STI front side air bag & Resistor to fix air bag light 02WRX_BLUE Interior & Exterior Modification 3 12-29-2004 09:16 AM
Help! Deleted Seat Air Bags & used 3.3 Ohm Resistors & getting Air Bag Light 2.2gotboost Electrical & Lighting 3 02-19-2004 09:36 AM
('93-'01) air bag. light???? bratmantlz Impreza Forum 3 02-22-2002 09:29 AM
