Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 04-04-2004, 10:10 AM   #1
STiLL
Member#: 50043
04 STi
java black pearl
Cool Defi BF's to RED...write up...
Finally, someone has sucessfully changed the backlight color of the defi BF's...Thank you S2K...
http://forums.s2ki.com/forums/showth...highlight=Defi
STiLL is offline   Reply With Quote
Old 04-04-2004, 10:45 AM   #2
tm999xxx
Member#: 34408
07 Spec B
SoapBox?
too risky for me..but a good write up
tm999xxx is offline   Reply With Quote
Old 04-04-2004, 12:29 PM   #3
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
cnstman is offline   Reply With Quote
Old 04-04-2004, 01:30 PM   #4
Tobey
Member#: 21400
2015 WRX Limited
ISM
i just wish there was a way to do this WITHOUT removing the needles. i wonder if there is an easier way...
having a boost or egt gauge that isn't calibrated correctly is useless.
Tobey is offline   Reply With Quote
Old 04-05-2004, 07:21 AM   #5
happasaiyan
Member#: 37731
might have to take a look into this today.
happasaiyan is offline   Reply With Quote
Old 04-05-2004, 07:01 PM   #6
happasaiyan
Member#: 37731
done.
...it looks pink though. so i guess im going to have to go look for a yellow sharpie to offset the red and make it a little more orange to match the dash.
the procedure was easy. there werent any problems with calibration- all i did was move the needle all the way to max and then mark on the metal ring under the cover where the max is. the when you go to put the needle back in, just align the max to the same place. very easy. if you can get the colors right, this is a very worthwhile mod.
and yes, i know...ttiwwop. ill take pics after i yellow things up a bit....unless you guys want to see what they look like pink?
Old 04-05-2004, 08:37 PM   #7
Janq
Member#: 33246
1993 Legacy L+ AWD
Phoenician blue met./blue
The Sharpie method is short term temporary at best.
The ink dries & dissolves with exposure to air.
Also the heat of the bulb (in this case LED) will help to speed up the drying and thinning of the Sharpie ink.
A better solution would be sandwich in a layer of translucent red colored film/plastic as a filter.
- Janq
Janq is offline   Reply With Quote
Old 04-05-2004, 09:18 PM   #8
happasaiyan
Member#: 37731
ok. redid them with an orange sharpie. 100x better. ill take pics in a bit and post them at the end of the evening.
Old 04-05-2004, 10:22 PM   #9
Tobey
Member#: 21400
2015 WRX Limited
ISM
- Janq
exactly what i was thinking. i use a paint for lightbulbs for this type of stuff (interior bulbs to my jeep) and it holds up real well. i don't think leds get too awful hot but i don't think the sharpie idea will last long either.
so next question: where to get a good, red/orange film?
Old 04-05-2004, 11:26 PM   #10
happasaiyan
Member#: 37731
here ya go:
before
after
Old 04-05-2004, 11:43 PM   #11
Janq
Member#: 33246
1993 Legacy L+ AWD
I use stained glass window liquid latex coloring paint which is resitant to indirect heat. Even it fades though after 4 months or less depending ont he size of the bulb (output) and its usage.
As for locating a red filter/film I'd try a photgraphy supply shop or your local arts & crafts center.
Just follow the fat ladies wearing home made macrame sweaters and driving cars with cats in them.
- Janq
Old 04-06-2004, 03:46 AM   #12
mixup52
Member#: 39691
2002 WRX Wagon
That looks nice, I used red model paint that you by at walmart when I did my Radio and HVAC.
Have a look
mixup52 is offline   Reply With Quote
Old 04-06-2004, 06:19 AM   #13
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
ive also been looking at this and attempted many things,
including the red celophane, and actually changed the leds to red. however wot i found is that there no where near intense as the cluster.
if u guys could help me source the leds i would be really appreciative.
i measured them to be 3.2mm long x 2.6mm wide. they dont have to be exactly these measurements as the ones i had were a lil smaller. anyway their called smt LEDS or surface (mount LEDS). u obviously need them to be high intensity red.
any info would be great. thanks guys
tino is offline   Reply With Quote
Old 04-06-2004, 08:01 AM   #14
mindchatter
Member#: 36447
Heav en for the weat
her & Hell for company
I think soldering in red LED's would be the ideal fix on this....is that what you're going to do Tino?
Stu
mindchatter is offline   Reply With Quote
Old 04-06-2004, 08:48 AM   #15
STiLL
Member#: 50043
04 STi
java black pearl
I posted something similar in the imprezawrxsti forum, here's the thread about the LED's...hope it helps...
http://www.imprezawrxsti.com/postnuk...ewtopic&t=7665
Old 04-06-2004, 10:16 AM   #16
tino
Top Scoob 019
Member#: 43630
yeah thats wot im trying to do. found sum leds from singapore they were a tad smaller but fitted fine. but when i turned the gauge on it was a dull red. and dosent match the cluster. thats the problem. i wonder if any1 hasa pulled apart the sti cluster and tried to use those leds.
havent had the balls to pull apart the cluster to see wot type of leds they are.
Old 04-08-2004, 07:10 PM   #17
Tobey
Member#: 21400
2015 WRX Limited
ISM
i think the leds we need are a totally different type. they have a weird name but i can't think of it at the moment...
Old 04-08-2004, 08:26 PM   #18
tino
Top Scoob 019
Member#: 43630
yeah the ones we need are called smt leds
Old 04-08-2004, 09:01 PM   #19
Tobey
Member#: 21400
2015 WRX Limited
ISM
doesn't that stand for surface mount or something like that?
i am thinking of something different that indicates a more intense light. maybe EL lighting??
Old 04-08-2004, 10:40 PM   #20
tino
Top Scoob 019
Member#: 43630
yeah its surface mount leds.
the common ones are round 1-10mcd but im looking at gettin some which are 80mcd min -120mcd max. i think they will be superbright. im gonna look at the dealer and ask sum more questions then hopefully get a sample.
Old 04-08-2004, 11:07 PM   #21
typer_126
Member#: 14377
2004 STi
Twin Scroll Goodness
FWIW, I talked to the fellow that's the (original and now again) North American distributor for Defi, when I was at IAS last weekend. I mentioned the red BF series gauges that Defi had shown at this years TAS. If enough people show an interest, he felt that he could get them to speed up their release.
Here's his name and contact info:
Hubbie Fuh
President - Sharp Precision Instruments Inc.
732-290-2213
hubie@spipowerexcel.com
typer_126 is offline   Reply With Quote
Old 04-08-2004, 11:18 PM   #22
samwY
Member#: 31816
they're coming out with RED BF Series
samwY is offline   Reply With Quote
Old 04-09-2004, 12:49 AM   #23
gills
Member#: 11316
2004 STi
'90 E30 S54 swap project
When? next year?
gills is offline   Reply With Quote
Old 04-17-2004, 05:09 PM   #24
catass
Member#: 31976
2004 WRX STi
World Rally Blue
I emailed that guy. I want some red guages and the current defi bf guages are way too expensive to attempt to mod them myself!
catass is offline   Reply With Quote
Old 04-17-2004, 06:10 PM   #25
typer_126
Member#: 14377
2004 STi
Very cool. Hopefully more folks will show some interest and help us all out.
4EAT to 5spd Write up? DIY? soccerdommer Subaru Conversions 3 07-15-2008 05:56 PM
Changing green Defi gauge to red? akinasdevil Interior & Exterior Modification 6 09-15-2006 09:42 AM
Is it possible to mute the Defi BF's shemoves Electrical & Lighting 8 06-27-2005 11:49 PM
how to dim the DEFI BF's txjunglist Interior & Exterior Modification 5 12-27-2004 11:44 AM
Converting BF Defi gauges to red backlight tino Electrical & Lighting 38 07-02-2004 11:06 PM
