Old 04-04-2004, 11:34 AM   #1
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
Default rear Oxygen sensor question
I am getting a CEL... pretty sure it's a PO420, but I haven't had it pulled since I changed some stuff around.
Here's what I have: Borla Headers -> RandomTech Cat -> Stromung midpipe -> Prodrive muffler
The rear o2 sensor had to be replaced and my only option at the time was a universal fit Walker rear oxygen sensor. The sensor didn't come with instructions for how to wire a Subaru 4 wire connector, only the old 3 wire style, even though their product guide said it was supposedly the right sensor.
I have been trying to track down the wiring pinouts for the OEM sensor to make sure I wired it up properly but can't seem to find them. I checked my shop manuals and I didn't see a description of the wires. I have been searching all morning but haven't found anything that seems to match what I have.
The stock sensor I have is a Bosch and has A24-A71 057 98010 on it. There are 4 wires on it: 2 white, 1 grey, 1 black. The 2 white should be the heater wires (polarity independent). I am trying to confirm which of the other 2 is ground and which is signal to the ECU.
Anyone out there have a clue?
bigdweeb is offline   Reply With Quote
Old 04-04-2004, 07:03 PM   #2
gavinl
Member#: 57891
2005 9-2x Aero
The grey wire is signal and the black is ground.
If you want to completely bypass the rear O2 sensor I have a bypass that I construct that can do that.
gavinl is offline   Reply With Quote
Old 04-05-2004, 12:48 PM   #3
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
I would rather get the stupid thing working again if possible... it's mostly on sheer principle at this point. What does your bypass entail? Is it similar to the Pony Express MIL Eliminator?
I think I may have made the opposite assumption that the grey wire was the ground due to its position on the sensor. I looks like it comes out of the side instead of the back like the other 3. I think that was the logic I used anyway. I will have to crawl under the car again to see for sure. If I did miswire it, I hope it's not busted from being miswired all this time.
Old 04-05-2004, 09:33 PM   #4
gavinl
Member#: 57891
2005 9-2x Aero
Yup, what I rigged is similar to Pony Expresses Mil Eliminator.
Being a 1v signal device, I don't think you'll bust the O2 sensor if wired opposite. Check it out and see if the wires were indeed reversed.
2007 STi Rear Oxygen Sensor ( O2 Sensor ) Nitro Don Engine/Power/Exhaust 3 02-19-2009 11:49 AM
Replacing rear oxygen sensor Fubaru Service & Maintenance 12 11-03-2005 12:00 AM
Rear Oxygen Sensor for Link? cpu77 Normally Aspirated with bolt-on Forced Induction Powertrain 15 04-11-2003 09:49 AM
W/B Rear Oxygen Sensor feropont Tri-State Area Forum 7 04-08-2003 01:29 AM
P0139 Rear oxygen sensor circuit slow response slin02 Mid West Subaru Owners Club Forum -- MWSOC 3 05-11-2002 02:32 AM
