Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 04-04-2004, 12:50 PM   #1
marioej18
Member#: 31115
2004 saab 9-3 aero
black
Question some weird turbo questions
ok, i thought of something weird the other day....
--say if you had turboed your ej25 or whatever NA subaru engine and you do all the computer stuff and fuel stuff as well, but you dont do your internals at all... say, if you dont run that 5-6 pounds of boost (avo kit for example, not to say that this is what i would use, its jsut for a reference) that you would normally, but instead you get it to run at only 2-3 pounds of boost...
would that be harmful on the engines internals at all, even with the proper fuel tuning and whatnot?
--then, the other thing that i thought of runs along those same lines, but instead of running 2-3 pounds you would get it so the engine neuther has to suck in the air nor is it forced into the engine, i think it would kind of be like zeroing the vaccum pressure...
the engine wont have to work to suck the air in, and it wont be forced either, the air would just kind of be there
but i dont know if you could acheive a zero pressure with that though
i know that neither one of these will create lots of power and some people will say that it isnt worth even doing...
i want to hear what everyone else thinks of the idea...
any input would be great!
marioej18 is offline   Reply With Quote
Old 04-04-2004, 05:48 PM   #2
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
I went over 30000 miles on 4.5psi with just a RRFPR for fuel management. Had no problems till i got boost happy.
Drac9 is offline   Reply With Quote
Old 04-04-2004, 07:02 PM   #3
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
I run up to 9 psi on a stock MY99 bottom end and have been for over a year (about 30k mi) on WRX injectors/pump and GReddy E-manage. So far so good.
Besides, no turbo that I know of comes with a 2-3 psi spring in the wastegate... and you can't run less than the wastegate. In a nutshell, a low cfm turbo at 6 psi will be fine if you upgrade the fuel system... start turning up the boost and they run hot.
Old 04-04-2004, 09:24 PM   #4
marioej18
Member#: 31115
2004 saab 9-3 aero
black
really, my concerns are about the strength and reliablility of the DOHC ej25 engine if you go turbo with it. i dont want to throw too much boost at it, im just looking for some extra power. thats why im asking so much and trying to think of those different things to do...
im doing as much research as i can about turboing my engine, but there is just so much more that im looking for
i would consider buying a kit, but then again, i might want to build my own, hence all the research im doing on it...
Old 04-05-2004, 06:31 AM   #5
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
If you want more power and don't want any chance of blowing your motor from boost, stay naturally aspirated...
Realistically though, running 4-6psi on just about any motor is reliable for long time. That's only adding about 30% to the amount of air that can normally enter the engine in N/A form... Run it safe (good fuel and timeing control) and you should have no issues. Note: boosting is addicting...
On another note... there is no difference between 'forcing' air into the engine and 'sucking' it in N/A. Its all based on pressure differentials. The cylinder always 'sucks' the air in, even at 3 bar of boost... There is just a larger pressure differential between the inside of the cylinder and the manifold, so more air get sucked in... Just a little symantics, but its an important idea to keep straight.
-Charlie
phattyduck is offline   Reply With Quote
I get some weird stuff to scan here... IggDawg Off-Topic 5 10-07-2003 03:04 PM
Some turbo questions ImprezedRS Normally Aspirated with bolt-on Forced Induction Powertrain 4 03-11-2002 11:19 AM
Blue WRX sighting in SD, yellow wheels, some weird lights WRX Power Southern California Impreza Club Forum -- SCIC 0 12-02-2001 04:12 PM
Some newbie turbo questions... Fred Fredburger Newbies & FAQs 1 02-04-2001 06:51 PM
