Old 04-05-2004, 02:09 PM   #1
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Default are my RC Engineering injectors sitting to far back in the injector port?
I have these RC Engineering Injectors for the Impreza 2.5RS but when inserting them into my MY00 Intake Manifold, not only do they slide in easy(i know i need to use the RS O-rings), but when looking at the bottom of the intake manifold, the injector sits .5" back.
I don't have my original injectors with me at the time, but I do remember that they sat at edge of the injector port not .5" back like in the pictures. Can anyone measure the length of a stock MY00 RS Injector cause the RC's are measuring 2.75" and I need them to bolt/sit properly with my vishnu fuel rails.
Here are some pics:
Injector before sitting in intake manny:
Injector sitting in intake manny:
Underside of the intake manny with injector installed(you can see inside the port a shiny part indicating where the original o-ring from was sitting at:
Any thoughts or suggestions. Since this is an air assisted intake manny as well as the injector spraying in a conical fashion, then I think fuel will be hitting the injector ports in this current configuration. I think they should be sitting much lower.
Any thoughts?
Kevin
latinskllz is offline   Reply With Quote
Old 04-05-2004, 02:23 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Seems Imagestation doesn't allow external linking of their pics.
Old 04-05-2004, 02:31 PM   #3
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Does this work? If not try to right click on the picture and show picture
This is the album where the pictures reside, just choose the drop down menu and start with pic injectors001
Old 04-05-2004, 02:43 PM   #4
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
I'm about to drop some $$ into some RC 440cc's so I'm very interested to see how this works out for you.
-Brett
ExecNav is offline   Reply With Quote
Old 04-05-2004, 02:52 PM   #5
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
I have the RC550s and when I first installed them, they didn't seem to go as deep as the stockers, but they're working fine w/ over 30k miles
-vic
cRayZee is offline   Reply With Quote
Old 04-05-2004, 05:34 PM   #6
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Hey Brett, Chanch (Omar) wants $150 for his RC440s, they've been on since Dec. I believe.
-Vic
Wedge is offline   Reply With Quote
Old 04-05-2004, 11:08 PM   #7
kaos200
Member#: 2692
-vic
yupp
Im selling my 550s and 99 manifold as well. Check here
http://forums.nasioc.com/forums/show...hreadid=517656
kaos200 is offline   Reply With Quote
Old 04-06-2004, 04:58 PM   #8
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
Just bring your manifold and injectors to a machine shop, they'll make it fit. You don't have to worry about the Injector Air Assist system, just disable it and plug up the holes.
Here's how mine look after machining.
FWIW, I ran my injectors far out like what you have now for over a year and it didn't seem to be a problem.
Toon
Boostup! is offline   Reply With Quote
Old 04-13-2004, 09:51 AM   #9
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Toon
Perhaps you didn't notice it, but an injector sitting that far back especially when it's a conical shape may be dumping unnecessary fuel hitting injector walls.
Anyhow, I am going to send my manifold, stock RS injector as it is indeed different that the RS RC Engineering Injector that I have so they can properly design one for the MY00-up model years with the air assist on them.
They told me that they provide spacers with the injectors for fitment, but if the injector can be machined to fit properly from the start, the necessity of spacers is eliminated.
Any opinions?
Old 04-13-2004, 10:12 AM   #10
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I believe that is what [email protected] did when he had RC make injectors for the MY00's. I don't suppose it could hurt to show them the real thing with manifold, though.
Old 04-13-2004, 11:32 AM   #11
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
yeah, it sucks they are charging me $40 plus shipping both ways to remachine them from when they have a design flaw
I'm only trying to help as they are making the 720cc high impedance injectors and then that will be a problem if they still sit that far back.
trying to get back in the seat again. dan az Motorsports 29 12-28-2009 03:23 PM
Want to get back in the Scoobie game! GooseMan General Community 10 08-15-2006 02:42 PM
So I want to get back in the Subie game.... GooseMan Legacy Forum 14 08-14-2006 01:36 PM
going to be back in the bay area Qbushido Off-Topic 13 08-02-2004 04:06 PM
Tired of 13's... Need a setup to get back in the 14's StevieD Texas Impreza Club Forum -- TXIC 16 05-30-2002 10:31 PM
