Old 04-05-2004, 04:01 PM   #1
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
Default Tach signal for shift light?
99RS can i get a tach signal off the back of the instrument cluster? i was checking with a volt meter couldn't find a tach signal. I know its the connector all the way to the right of the cluster.
jeff22 is offline   Reply With Quote
Old 04-05-2004, 10:15 PM   #2
brunetmj
Member#: 8023
2004 2.5 RS
I do not believe you can find a tach signal with a multimeter anyway. Supposedly your suppose to use AC 12 volt. However I have never gotten a reading even from a known working tach wire. I am not an electronics person so I dont pretend to know what this means but the signal is some kind of a waveform and not true AC. Anyway it doe not suprize me that you found no reading.
brunetmj is offline   Reply With Quote
Tach signal for 99 RS mlovro32 Pre-2002 Factory Turbo Powertrain 2 03-16-2006 11:40 AM
Tach signal for 99 RS mlovro32 Normally Aspirated Powertrain 2 03-16-2006 10:57 AM
FS: Apex i black tach meter with shift light mint condition Watanabe Private 'For Sale' Classifieds 0 04-07-2005 03:06 AM
Need Wire For Shift Light Install Quick Time Electrical & Lighting 1 08-24-2003 02:31 AM
wiring diagram for shift light kenchan Transmission (AT/MT) & Driveline 12 11-13-2002 07:32 PM
