Old 04-05-2004, 08:56 PM   #1
Kinsbane
Member#: 15679
Default Need help with some UNIX commands.
So, I need to copy all of a directory's files into a directory of another name.
I tried cp -r dir1 dir2, but it put dir1 as a sub-directory of dir2. I don't want that.
Kinsbane is offline   Reply With Quote
Old 04-05-2004, 08:59 PM   #2
jaywat513
Member#: 23736
Platinum Silver
go into dir1 cp -r *.* dir2
it has been a while since I used a nix.
edit: or maybe even cp -r dir1/* dir2
there are a ton of ways to do it..
jaywat513 is offline   Reply With Quote
Old 04-05-2004, 09:02 PM   #3
Skyline
Member#: 6074
2002 Impreza WRX
Sedona Red Pearl
Your dir2 can't exist already. If dir2 does not exist, dir2 will be a copy of dir1. If dir2 already exists, the dir1 copy will go inside dir2.
Skyline is offline   Reply With Quote
Old 04-05-2004, 09:02 PM   #4
Kinsbane
Member#: 15679
which would you say is the better way to do it? -r *.* or -r dir1/* ?
Old 04-05-2004, 09:03 PM   #5
Skyline
Member#: 6074
2002 Impreza WRX
Sedona Red Pearl
Save the "*.*" for DOS. It'll only cause you headaches in Unix.
Old 04-05-2004, 09:08 PM   #6
aod
Member#: 7121
Yes, *.* is for lam0rz in *nix land.
aod is offline   Reply With Quote
Old 04-05-2004, 09:09 PM   #7
Kinsbane
Member#: 15679
so its -r dir1/* then ?
Old 04-05-2004, 09:12 PM   #8
jaywat513
Member#: 23736
Platinum Silver
yeah, like I said it has been a while
Old 04-05-2004, 09:14 PM   #9
Skyline
Member#: 6074
2002 Impreza WRX
Sedona Red Pearl
If dir2 already exists, "cp -r dir1/* dir2" will copy the contents of dir1 into the dir2 directory.
If dir2 does not already exist (what you really should be doing), then "cp -r dir1 dir2" will make dir2 the copy.
Old 04-05-2004, 11:51 PM   #10
aod
Member#: 7121
Oops. I didn't mean you specifically. I used to get a kick watching management types try to learn how to get around in *nix at one of my jobs. Every single one of them would type "dir *.*" as their very first *nix command. Of course, sometimes "dir" is aliased, but still. Then when they'd learn that "ls" was the correct command, then came the "ls *.*", etc.
Kinsbane: In *nix, it is not required for a filename to have a . in it like it is in DOS. *.* in *nix matches everything that has a . in the filename. In fact, I always thought it was generally a poor idea to do *.* in DOS too since * will match all files in DOS as well.
Also, Skyline is correct on the methods. The -r flag in cp means "recursive". When in doubt about a *nix command, check out the manual page for it. Type "man cp" at the prompt to pull up a manual page for the cp command.
Hope that helps.
I need help with some track/autoX research please… J Ritt Motorsports 16 10-13-2003 02:38 AM
All you chemistry majors or people that know chemistry I need help with some problems Meat-Head-h Off-Topic 1 10-06-2003 08:45 PM
Need help with some part numbers, ASAP foolio Interior & Exterior Modification 9 12-11-2002 02:12 PM
Need help with some speaker sizes crxtls2 New England Impreza Club Forum -- NESIC 1 06-23-2002 04:30 PM
Need help with some items I can't find. obyone Mid West Subaru Owners Club Forum -- MWSOC 2 06-02-2002 01:39 AM
