Old 04-05-2004, 11:33 PM   #1
jarelee
Member#: 31506
05 Tacoma on TE37'
Default Question about Autometer EGT Gauge...
Hey guys. I'm wondering if my gauge is messed up. It's a autometer Ultra-lite 52mm EGT gauge, and the needle sits at 2. It hasn't been hooked up, but just taken out of the box. Is it ok/right to be sitting at 2 or should it be sitting at 0??
Basically....is my gauge defective or is it ok?
jarelee is offline   Reply With Quote
Old 04-06-2004, 01:20 PM   #2
awdman
Member#: 27962
2003 WRX Sedan
Blue, with more dings!
Default It's OK
Mine did the same thing. Autometer Z series. The temperature in the dash is changing the resistance in the gauge giving you a reading. Now you'll know if your dash overheats! Once you finish the install be prepared to see alot more than 200 degrees.
awdman is offline   Reply With Quote
autometer egt gauges, what egt probe are you using? Tobey Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 07-09-2004 11:19 PM
Autometer EGT Gauge Question Terbeauwrx Engine Management & Tuning 24 02-20-2004 04:43 PM
Autometer EGT Gauge question jetsiphon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 11-14-2003 05:00 PM
Questions about Autometer gauges t.rod Normally Aspirated with bolt-on Forced Induction Powertrain 18 10-26-2001 09:56 PM
question about Autometer vacuum gauge joostin420 General Forum Archive 2 12-20-2000 12:08 AM
