Old 04-06-2004, 01:16 AM   #1
vf39hipsi
Member#: 55794
Default A/F Gauge install
Where do you hook up on the STi???, and is the autometer one accurate or just a light show?
vf39hipsi is offline   Reply With Quote
Old 04-06-2004, 01:38 AM   #2
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
Well, A/F gauges are fairly useless on WRXs unless you install your own sensor. As soon as you install all of your exhaust plumbing, you'll lose the sensor.
At least, that is, if it's like the WRX. Perhaps the lack of an up-pipe cat to replace makes it different on the STi.
MB38 is offline   Reply With Quote
Old 04-06-2004, 09:56 AM   #3
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
No it's worthless on the STi too. The factory narrowbands will only give you a light show. It won't show any good real information.
I'd hook it up on the STi by selling the gauge and buying something useful.
mbiker97 is offline   Reply With Quote
Old 04-06-2004, 11:50 AM   #4
vf39hipsi
Member#: 55794
what would be a good solution to see how rich I'm running?
Old 04-06-2004, 12:13 PM   #5
1DOWNCLOWN
Member#: 50287
02 WRX
egt gauge i think
1DOWNCLOWN is offline   Reply With Quote
Old 04-06-2004, 01:49 PM   #6
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Either buy a wideband (~$350) or you can _sort of_ see it with an EGT gauge. You WON'T be able to see how rich you are from the factory sensors. They aren't accurate except near 14.7:1.
Old 05-13-2004, 10:45 PM   #7
Tuned
Member#: 45843
2007 Cooper Works
Pepper White
I just did a search and found this thread from about a month ago.
So to make sure i understand, if I buy a GReddy A/F gauge and hook it up to the factory 02 sensor it will be a waste of money because the factory 02 sensor can't read a value below about 11? And in order to have the A/F gauge work correctly I would have to spend another $350 to buy a decent 02 sensor?
Please clarify.
Thanks,
Jeff
Tuned is offline   Reply With Quote
Old 05-14-2004, 09:36 AM   #8
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
To get an accurate a/f reading from a gauge you need to buy a wideband O2 sensor. Most of the wideband kits come with some sort of gauge so you wouldn't need to go buy another one. If you hook up a gauge to the factory sensors then it is just a fancy light show.
Old 05-14-2004, 11:09 AM   #9
Tuned
Member#: 45843
2007 Cooper Works
Pepper White
Thanks. I appreciate your help.
Jeff
Boost Gauge & A/F Gauge Installed on 06 WRX; worth a look... preluden20 Member's Car Gallery 31 06-25-2006 12:09 AM
Gauges installation issues / constant power to gauges aimetti Electrical & Lighting 7 04-16-2006 08:59 PM
turbo timer boost gauge install w/ factory boost gauge Blakestyle521 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-21-2004 10:19 AM
