#1 |
Member#: 14364
Vehicle:2003 WRX, '06 Armada 05 Vette & 05 STi (sold) |
Thought these were neat pictures that I took so I thought I would post them.
![]() -Mike ![]() ![]() ![]() ![]() ![]()
#2 |
Member#: 55089
SWIC
what's the price on that bad boy?
#3 |
Member#: 39092
Vehicle:2004 WRX STi Java Black Pearl |
so shiny and clean!
#4 |
Member#: 12682
Hmm, Mikey mine are different Por que?
-Melo |
#5 |
Member#: 18311
TXIC
Vehicle:2010 STi SE OBP |
What pistons are those CP?
#6 |
Member#: 13607
Vehicle:82 Suzuki GS 1100E Gold-ish |
cp in a 2.5 block?
#7 | |
Member#: 18311
TXIC
#8 |
Member#: 6124
Vehicle:2000 NFR AP1 S2000 '07 Honda FIT sport (5MT) |
Hey Mike, is that my motor?
![]() I was going to say, I had forgotten to ask you guys to snap pictures hehe ![]() Jorge (RiftsWRX) www.ProjectWRX.com |
#9 |
Member#: 4419
Vehicle:2002 S2K - 2013 ISP i don't have a wrx |
almost to pretty to use.....nah!
#10 | |
Member#: 14364
#11 | |
Member#: 5778
South East
Vehicle:09 135i Jet Black |
the mother of all pistons !!! Brad |
#12 |
Member#: 13831
NICE jorge, finally you go with the good stuff
#13 | |
Member#: 6124
![]() Let's do it all over again!!! ![]() Jorge (RiftsWRX) www.ProjectWRX.com |
#14 |
Member#: 21267
Vehicle:STI, EWG 8cm Green UTEC/ECUtek/WI & SD tune |
Jorge
I guess we will see how out of round the stock liners go. What rods did you end up with? |
#15 |
Member#: 6124
Stock USDM rods. I'm really not looking at pushing this. Honestly if the motor ever saw more then 17 PSI by redline I'd be surprised.
#16 | |
Member#: 40501
Vehicle:2005 Decathalon 21sp One WheelSeanPower |
#17 | |
Member#: 6124
#18 | |
Member#: 21267
#19 | |
Member#: 6124
.Jorge (RiftsWRX) www.ProjectWRX.com |
#20 | ||
Member#: 7321
NESIC
Vehicle:.... 122 IggPoints Work... ahhh... so tired. |
Ya.... it would look nice hanging on the wall right? Quote:
Lets start a pool... when will Jorge brake his only 17psi rule? Good luck dude! Are the pistons lighter then the stockers? |
#21 |
Member#: 42075
SCIC
#22 | |
Member#: 6124
With a stock set of WRX heads, and stock 257 gasket.. no clue. I'll let the guys at Axis chime in. Jorge (RiftsWRX) www.ProjectWRX.com |
#23 |
Member#: 14364
With those pistons and our cometic head gaskets, compression ratio should be ~8.5/8.6:1
With the thinner gasket, it will be a little higher. Talking about installing with WRX heads. -Mike |
#24 | |
Member#: 21267
#25 |
Member#: 13448
Vehicle:2002 wrx wagon silver |
The pistons are designed specially for the ej257 motor. They use the piston dish of our 2.35, which with unmodified wrx heads and Cometic gaskets yeilds about 8.5-8.6:1. Jorge's heads were slightly modified, so I would say his final cr will be around 8.0-8.1:1.
When using stock ej257 gaskets, you can figure on about 8.8-8.9:1 cr with wrx heads. The pistons themselves have a modified compression height, so the bottom oil control ring does mount slightly lower than it does on the stock piston. All 3 rings were lowered a bit to give more crown and a thicker top ring land for strenghth. The pistons should be able to take more than 30psi without hassles, but I doubt the stock rods will take much more than 24-25psi and still stay together. We usually suggest that the ej257 block not see more than 24psi if you want it to live for more than a couple months. Ron |
| Thread Tools | |
| Display Modes | |
| looking for sti block or forged pistons | JADSTI | NWIC Private Classifieds | 6 | 08-01-2010 04:08 AM |
| USDM 2.5 STi block with CP Pistons | Rizzo314 | Private 'For Sale' Classifieds | 1 | 07-27-2006 08:50 AM |
| 2.5 STI block v 2.5 na | blacktalon606 | Factory 2.5L Turbo Powertrain | 9 | 04-20-2006 11:54 AM |
| Yet another 2.0 to 2.5 sti block ? | serious | Factory 2.0L Turbo Powertrain | 40 | 12-22-2003 03:24 PM |
| 2.5 sti block with 2.0 regular wrx heads | serious | Normally Aspirated with bolt-on Forced Induction Powertrain | 21 | 08-03-2003 12:36 PM |
