#1 |
Member#: 51940
NESIC
i really want to improve my top end, and one of the better bangs for the bucks is cams, seeing i already have underdrive, intake, and exhaust. . does any company make cams for the 2.2l L impreza ? do 2.5RS cams swap in ? should i go for the 2.5l head and cam swap ont my 2.2l block ?
i was looking around the cobb tuning website, and found a byunch of nice stuff, including the stage 3 kit, and it's componets, will these cams wrk on my engine ? or should i just give up . . .. ![]()
#2 |
Member#: 51282
Vehicle:98 RS black & blue from parking |
2.5 cams won't work on a 2.2L... not sure you'll see enough improvement to make it worthwhile to swap heads.
#3 |
Member#: 51282
Just drop in a ej22t for real improved top end!
#4 | |
Member#: 21811
South East
Vehicle:2003 WRX Wag/01 OBS WRB and SM |
#5 |
Member#: 51940
NESIC
i dunno. .i just wanted soem nice cams, but i guess, theres no cams for me
#6 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
We had quite a long thread about this issue a while back. I don't remember the title or I would pull it up for you. Unfortunately, I also do not remember what we concluded. The discussion covered both swapping in the EJ25 cams as well as the EJ25 heads. A little searching should bring it up...
| Thread Tools | |
| Display Modes | |
| Keep the stock WRX cams or go with aftermarket cams? | triguy | Built Motor Discussion | 11 | 09-21-2006 05:41 AM |
| Aftermarket Cams & Valves | SPESHAL | Factory 2.5L Turbo Powertrain | 10 | 11-05-2004 02:11 PM |
| gas mileage with aftermarket cams | ClimbinNBouldern | Normally Aspirated Powertrain | 11 | 06-05-2004 10:18 AM |
| ProTorque Torque Converter and Aftermarket Cams | Kevin Thomas | Transmission (AT/MT) & Driveline | 0 | 05-10-2004 07:02 PM |
| JDM Head Valvetrian and aftermarket cam question | roybfr | Factory 2.0L Turbo Powertrain | 3 | 01-10-2004 04:40 PM |
