Old 07-28-2000, 09:44 AM   #1
codemunky
Member#: 1804
Post hp, power to the wheels vs. dyno
K, I need to get edu-cay-ted. What's the difference? Thanks a bunch.
codemunky is offline
Old 07-28-2000, 02:40 PM   #2
ASNG
Member#: 681
Post
I see there are still no takers to answer you...maybe because its "borderline" technical forum...
...maybe nobody cares...
Anyways, all engines produce TORQUE! Horsepower is a product of torque and rpm.
If two engines produce the same torque, the one that does it at a higher rpm will have more HP.
"Power to the wheels" is really what a "dyno" is measuring, so they are theoretically the same thing.
If you really meant flywheel vs. dyno, then the "flywheel" is what comes out the engine and "dyno" is what gets to the wheels, which is allways less than flywheel Hp, because of the friction in the tranny, the differentials and all the other drivetrain components.
Manufacturers allways publish the flywheel HP, because its a bigger number.
ASNG
ASNG is offline
HTML code is On
anyone know how much hp/tq to the wheels the Blouch Dominator 1.0 turbo can handle m_wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 04-25-2010 11:30 PM
Horse power to the Wheel Kalb2360 Newbies & FAQs 42 03-10-2006 11:00 PM
More Power to the Wheels sube-trex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-12-2005 08:05 PM
What was your HP to the Wheels at Dyno? BigElm Tri-State Area Forum 33 07-31-2002 01:52 PM
Check this out if you want more power to the wheels? BADWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 07-10-2002 09:45 PM
