![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#26 |
Member#: 29528
Vehicle:02 WRX wagon V7 RA -C conversion |
Here are the pic's (If someone would like to host them, let me know)
A few updates/clarifications: The wheels are +48. The suspension has settled some and the front gap is a little bigger than the front. The rear camber would not come into spec when aligned. It is approx -1.5. I am not sure why, even with camber bolts. I need to get that sorted out. The rear fenders will require rolling, they are OK for me, but with rear passengers I am sure it would be a problem.
#27 |
Member#: 7453
TXIC
Vehicle:2005 Legacy GT Wagon 2006 LJ Rubicon |
What were the front camber numbers like?
#28 |
Member#: 22879
Huh ?So your wheels are basically setup the same as the 04 sti wheels right(17x7.5x48mm)? Just how close is it to rubbing in the back? Would it hit the side wall or the top side of the tire? I'm kinda confused as to exactly what offset does for a wheel. I know it moves the wheel one way or another, i just forgot which. B |
#29 | |
Member#: 29528
#30 |
Member#: 7453
TXIC
You don't happen to know how much negative camber was possible in front do you? My whole reason for doing something like this would be so that I didn't have to run low amounts of negative camber in front. I was able to get somewhere between -.3 and -.4 in front with the wagon control arms. I don't think switching to the sedan ones would be worth it unless it could get me at least -1 degree without camber plates.
#31 | |
Member#: 7453
TXIC
#32 | |
Member#: 9106
SCIC
Vehicle:2002 WRX Wagon - PSM 2008 STI - Aspen White |
#33 |
Member#: 13643
SCIC
Vehicle:'02 WRX Sdn WRB '05 Leg GT Ltd Wgn Black |
AFAIK, the 04 wagons' suspension was re-tuned to deliver performance that is in between the STI and the WRX sedan since there isn't an STI wagon.
#34 |
Member#: 22879
Cool, now if they'd just "Retune" the rest of the car to be more sti like.....
#35 | |
Member#: 29528
#36 |
Member#: 22879
Does anyone know if the part that attaches to the knuckle and runs forword then attaches to the body is the same between the wagon and the sedan? Anyone know if the new part is the same as the older legacys and impreza?
I think the part is called a trailing arm. Brent |
#37 |
Member#: 7453
TXIC
I assume that you are talking about the rear suspension. Yes it is the trailing arm and yes the sedan and wagon share the same part. I thought it was the same as on the older Imprezas, but subaruparts.com lists a different part number. Rallispec does sell the same STi pink trailing arm for 93-current Subarus with this caveat Note:Some N/A models may require spacers (addiitonal washers) at the knuckle end due to variations in the knuckle bushing width used over the years on non-WRX models.
| Thread Tools | |
| Display Modes | |
| Has anyone eaten chicken out of the can? | b0dh1 | Off-Topic | 10 | 12-01-2004 10:59 PM |
| Any Canadian vendors of the STi/SPT suspension kit? | codger | Canada Region Forum | 0 | 05-23-2003 01:49 AM |
| Has anyone recieved insurance quotes for the STi? | Wagonboy | STi Forum Archive | 0 | 05-23-2003 12:26 AM |
| Has anyone driven A WRX with the STI springs...or know how it might drive | SILVERWRXWAGON | Brakes, Steering & Suspension | 1 | 08-24-2001 02:35 PM |
