Old 04-06-2004, 06:43 PM   #1
Mako
Member#: 5770
2000 Legacy Outback
Green with Stromung & CAI
Default Jiffy Lube says '04 WRX needs special oil filter?? Say what??
My girlfriend took her brand new 2004 WRX to a Jiffy Lube-type place for the 1000-mile oil filter change and was told that the 04 WRX needs a special oil filter??!! I know the body is different and all but isn't it the same 2.0L engine as the bugeye models? I did a search under Oil Filter here but found nothing on this....any input? Is the guy at Jiffy on crack?
Thanks,
Mako
Mako is offline   Reply With Quote
Old 04-06-2004, 06:50 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You should find the info you need in this thread-
http://forums.nasioc.com/forums/show...hreadid=434057
And Please, Please don't take the car back to Jiffy Lube, ever. Way too many horror stories about bad things happening to cars serviced there. Either do it yourself, it's easy, or take it to a dealer or local shop you trust.
Old 04-06-2004, 06:51 PM   #3
Silver04WRX
Member#: 37644
2009 Legacy 2.5i
"the 1000-mile oil filter change"???
I got my first oil and oil filter change at about 3000 miles. Why not take the car to the dealership to get it changed? It should be about the same price.
Silver04WRX is offline   Reply With Quote
Old 04-06-2004, 06:52 PM   #4
Silver04WRX
Member#: 37644
2009 Legacy 2.5i
Old 04-06-2004, 06:54 PM   #5
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Remember to check the blinker fluid while you're at it.
wcbjr is offline   Reply With Quote
Old 04-06-2004, 06:57 PM   #6
jamesohoh7
Member#: 39070
GTF off my lawn!
Default Re: Jiffy Lube says '04 WRX needs special oil filter?? Say what??
Thanks,
Mako
reciting what a Subaru parts-guy told me:
They revised the oil-filter when the '04's came out (or very nearly at the same time), but that's not to say that it is "04-Specific"... merely that a new filter supercedes the old one (from Subaru, that is... no idea about after-market filters).
The new one from Subaru has a different part number (15208aa080) than the previous one, and it's slightly smaller in diameter... ostensibly to avoid getting heat-soaked by the exhaust and so on that runs nearby it.
However, if you have an old one that you never used, it should fit your '04 no problem. They did not change the threads or do anything that makes new vs. old incompatible as far as installation on your car goes.
If you get your oil filter at Subaru, they don't even ask "what year", they just bring you the new part (presuming you live in a town where the dealer keeps up with such things )
FWIW: my '04 WRX Sedan came with the old, fat filter on it. That's how I found all this out, when I went to get the new one, it was smaller.. then I got the explanation that I just gave above from the parts-counter guy.
Don't forget to get a new crush gasket.. the counter-guy doesn't always ask... it's only like $1 anyway.
-James
jamesohoh7 is offline   Reply With Quote
Old 04-06-2004, 09:07 PM   #7
The Professor
Member#: 23183
2002 Cobb StageIIWRX
WR Blue
AGREED!
98 Ford probe GT V6 + Jiff Lube = dead
99 Toyota Corolla + Jiff Lube = Spun bearing (oil starvation) traded......probably long dead.
Both cars lost all the oil from loose drain plug on one and loose oil filter on other.
The Professor is offline   Reply With Quote
Old 04-06-2004, 10:19 PM   #8
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
[/b][/quote]And Please, Please don't take the car back to Jiffy Lube, ever. Way too many horror stories about bad things happening to cars serviced there. Either do it yourself, it's easy, or take it to a dealer or local shop you trust. [/b][/quote]
Please don't make us cringe by taking it to Jiffy Lube. Dudes working there making $6/hr touching your car=big no-no. My 2 cents...
Mika
finnRex is offline   Reply With Quote
Old 04-06-2004, 10:23 PM   #9
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
I say use the long filter from amsoil.. and their oil too..
and I 3rd or 4th or 5th the never ever ever ever go to jiffy lube idea.. they put the wrong tranmission fluid in my buddies car and it burned out.. then they stonewalled his asking for them to replace it...
MustGoFast is offline   Reply With Quote
Old 04-06-2004, 11:04 PM   #10
STIenvy
Member#: 37112
2003 WRX
Since your doing that might as well replace the muffler bearing.
STIenvy is offline   Reply With Quote
Old 04-07-2004, 01:31 AM   #11
speedblind
Member#: 42202
Most likely. And, yes, please do not take your car to Jiffy Lube for any reason unless you want the full service: change air in tires, inspect/replace the fetzer valve, check brake couplings etc. And don't forget to fill up with the green boost fluid, not the red that GM cars use.
There are probably local guys that are willing to help you with the oil change if you're not willing to take it to the dealership. I routinely change oil for two of my neighbors and several people at work.
speedblind is offline   Reply With Quote
Old 04-07-2004, 03:51 AM   #12
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
I have an idea! I want to make a how to change your oil video
Step by step with what tools you need where to get them how much they cost proper jack points on the car where to place jack stands
I have started using Adobe premiere and I could do this.
My only concern would be the overall file size of the video.
Maybe I could split it up into two video files.
What do you guys think? I'm serious I'm not talking about changing blinker fluid and Jiffy lube.
I have read horror stories on here anything from some ones oil pouring out in a parking lot to smashed in oil pan from a jack.
This would be a big job and would be nice if it was put in a place where everybody could see it and find it easily
-Scott A.
cky211 is offline   Reply With Quote
Old 04-07-2004, 10:39 AM   #13
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
One Touch Operation
Reduces Oil Changing Time and Expenses
Eliminates Stripped Thread
No More Contact with Hot Oil
No Messy Hands or Cloths
Easy Installation
http://www.fumotovalve.com/
Wheeler Bement is offline   Reply With Quote
Old 04-07-2004, 10:40 AM   #14
NeedAWD
Member#: 30831
2004 WRX
Java Black Pearl
A new WRX at Jiffy lube? I hope they didn't take it out for a "road test" afterwards...
NeedAWD is offline   Reply With Quote
Old 04-07-2004, 10:41 AM   #15
TurbojonLS
Member#: 38772
2 Cars, No Bling
Default Re: Re: Jiffy Lube says '04 WRX needs special oil filter?? Say what??
Originally posted by jamesohoh7
reciting what a Subaru parts-guy told me:...If you get your oil filter at Subaru, they don't even ask "what year", they just bring you the new part...
Funny. I walked in to a Subaru dealer I happened to be driving by & said, "I need an oil filter for an 04 WRX" The parts guy started hunting & pecking on the keyboard, and after about a minute, asked me "Is that the 4-cyl or the V-6?" This still bothers me months later.
Needless to say, I'm not ever going there again...
TurbojonLS is offline   Reply With Quote
Old 04-07-2004, 10:54 AM   #16
rex65
Member#: 34280
2003 WRX-Cobb II
Originally posted by Silver04WRX
Agreed.
rex65 is offline   Reply With Quote
Old 04-07-2004, 11:03 AM   #17
eric m.
Member#: 14872
02 WRX Wagon
99 Forester
Default Re: Re: Re: Jiffy Lube says '04 WRX needs special oil filter?? Say what??
at first i thought about the 6 cylinder legacy, but it's an H6 not a V6. subaru has never had a V6. ever! i hate people who are incompetent at their jobs. come on. these people work with subarus every day, and every EJ20 motor uses that size filter. but what am i thinking? most subaru parts guys have no idea what an EJ20 is.
yeah, never go to jiffy lube. you'd think they do a good job because they change oil all day, but no. they suck. you'd be better going to wal-mart, seriously. you don't need a special oil filter. if you get a purolator filter, it's ALMOST the same as the OEM filter. but to be honest, fram or any filter works fine. easy street uses fram filters and they're running 9 second quarter miles in their wrx. so it's probably not going to be an issue.
eric m. is offline   Reply With Quote
Old 04-07-2004, 11:43 AM   #18
remowgn
Member#: 41149
09 FXT
SSM
You can hardly compare the loads that the easy street car experiences to what a normal street car sees. They'll kill that bottom end long before they will get any wear and tear from poor oil filtering... so at that point, the cheapest filter will do.
Purolator does make excellent filters, though, I'll agree with that.
remowgn is offline   Reply With Quote
Old 04-07-2004, 12:07 PM   #19
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
The only thing that is wrong about this thread is people bashing this guy for changing out the factory oil at 1000mi. Many of us did our first oil change this early. There is nothing wrong with an early oil change after the initial break in.
And an FYI,
That new smaller oil filter is what they are using on all EJ series engines, not just the EJ20. I picked one up the other day and got the new 080 part number vs the 060 fatty filter...
Old 04-07-2004, 12:32 PM   #20
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
But but, what about the boost fluid?!?
Old 04-07-2004, 03:53 PM   #21
SuberStar
Member#: 38799
04 WRX
Smooth Silver
-Scott A.
Great idea, or at least easy directions with pics. I am one of the many too scared to change my own oil.
SuberStar is offline   Reply With Quote
Old 04-07-2004, 04:19 PM   #22
CynicX
Member#: 48199
06 WRX
ok oil change write up
1. remove drain plug, drain oil
2. remove oil filter
3. install new oil filter, lubercate new gasket with fresh oil
4. install drain plug w/ new crush washer
5. fill to proper levels
this all can be combined into one step
1. change oil
maybe cky211 will do a write up with pics....its mind numbingly easy....i cant even think of a way to mess it up...unless u strip the drain plug back in?....but if you cant insert a bolt into a lubercated hole then you should probably take it somewhere anyway....
smashing in oil pans?...wow i'd love to be there to smack that guy after he did that and say "now what did you learn?"
CynicX is offline   Reply With Quote
Old 04-07-2004, 04:26 PM   #23
Psydotek
Member#: 44168
2003 Yellow WRX
You don't even have to jack up the car to do it.
Oh yeah, torque value for the drain plug bolt is like 32.5 ft/lbs.
[or at least tight enough to just crush the crush washer. you did get a crush washer, right? Right?!?]
[old crush washer or no crush washer = leaking oil. and yes, i'm speaking from experience.]
[oh yeah, there's a write up with pics on www.scoobymods.com]
Old 04-07-2004, 05:43 PM   #24
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Remove the oil filler cap first, it will allow the oil to drain better/faster.
1. change oil
cdvma is offline   Reply With Quote
Old 04-07-2004, 07:32 PM   #25
jamesohoh7
Member#: 39070
GTF off my lawn!
Yikes!... that's a pretty crummy dealership then. I agree, I'd avoid such a place. I guess I'm lucky that my parts-counter guy knows enough to know about the new stock filters offered by the company he ultimately works for (in addition to knowing what fits what on Subaru's in general).
Good thing you knew better and left... gives me the willies thinking about stuff like that going on to the average Joe who has no clue.
-James
So the guy at Jiffy Lube tells me I need.... 4x4GGG Off-Topic 7 01-26-2007 04:44 PM
ABQ: Who needs WRX or STi oil filters? I'm going to buy a dozen ImportVenom South West Impreza Club Forum -- SWIC 10 02-02-2004 03:14 AM
I need JDM oil filters! I don't trust the USDM ones! Butt Dyno Off-Topic 2 12-04-2003 05:20 PM
How many quarts needed when oil filter has been prefilled? palpullero Service & Maintenance 8 06-16-2003 06:08 PM
Help! Need an oil filter! rirwater Bay Area Impreza Club Forum -- BAIC 5 02-15-2003 04:54 PM
