Old 07-28-2000, 04:17 AM   #1
Fusion
Member#: 553
2000 2.5RS Coupe
Silverthorne Metallic
Post What's the best motor oil?
I've recently been told that Lubro Moly is the best. Is this accurate? And what about oil filters, any special brands? I have a hookup for this stuff so cost is irrelevant.
Thanks
Haig
Fusion is offline
Old 07-28-2000, 05:04 AM   #2
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
I've always heard Mobil 1 synthetic is best... but my knowledge range in that department is limited.
JGard is offline
Old 07-28-2000, 05:19 AM   #3
BrianR
Member#: 647
Post
If cost is irrelevant then for the engine oil get redline and for the oil filter, puralator(sp??) would work fine.
BrianR
BrianR is offline
Old 07-28-2000, 07:30 AM   #4
nativo
Member#: 157
1998 JDM STIv8 6sp
Rally Blue Pearl
Cool
Guys one of the best 100% synthetic by Euro standards MOTUL 300V. Even better than Mobil 1 and Red Line which by Euro standards are consider Semi-Synthetic
Nativo
nativo is offline
Old 07-28-2000, 08:44 AM   #5
codemunky
Member#: 1804
Post
My sube mechanic says he doesn't recommend synthetic. He says it's better to have clean oil all the time, whereas in synthetic, oil change isn't required till about 7000 miles. Any takers?
codemunky is offline
Old 07-28-2000, 01:50 PM   #6
ImprezaRS2000
Member#: 779
1998 STi Wagon
Post
I just use Valvoline DuraBlend, and change every 3000 miles. I'm sure that works just as well as Mobil 1, changing every 5-10k miles.
New Porsches come with Mobil 1, and the warranty is voided if you use anything else. Also, it only needs to be changed every 15k miles! But, it's still really expensive, because it holds 11 quarts!
ImprezaRS2000 is offline
Old 07-28-2000, 01:55 PM   #7
Faraz
What?...
Do they speak English in What?
Member#: 1459
2008 WRX 5door MT
WR Blue
Post
i never heard of lubro Moly I have used and use Mobil 1 or Redline ....
Ok Colin:
What filter should we use and what wieght oil then?
Faraz is offline
Old 07-28-2000, 02:08 PM   #8
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Wink
Beats me, but it's a lot more important than what oil you use. Changing the oil and short intervals for hard use is needed because the filter is contaminated, not that the oil is bad.
ColinL is offline
Old 07-28-2000, 02:30 PM   #9
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Arrow
OK so I save all sorts of e-mail that I think I may need some day. This is something from another list I'm on that I thought was germain to this question:
Begin quote:
Dear Peter and list subscribers,
I am a chemist who used to work for one of the large chemical companies who
supplied the basestocks for synthetic lubricants; one of my customers was
Redline; I helped them design the basestock combinations for a number of
synthetic applications. Based my my extensive experience with synthetics, I
would recommend at least 5,000 mis prior to changeover to synthetic. You WANT
wear in the first few thousand miles so that the metal is completely smooth. The
lubrication qualities of synthetic will keep the molecular "peaks and valleys"
that result from even the best of machined surfaces. Use of a synthetic before
this microscopic wear happens will result in incomplete seating of rings,
bearings,etc. which will decrease long-term efficiency and performance.
After a 5-10K breaking with ideally "cheap" oil, you then "stop" wear with the
better lubricity of the synthetic. I stick with the factory drain intervals at
5K, even at first oil change, aothough the basestocks for synthetic hold up for
much longer, thje additives do become depleted.
The small amount of mineral present after change will entirely mix, and be
surrounded by synthetic basestock so there is a minimal need to "flush" the
crankcase. The darker color is due to the affinity for the synthetic to
solubilize varnish and sludge deposits throughout the engine. Synthetic can
support about 10x the dirt, varnish, etc. compared to mineral oil without damage
to engine. Oil filters do tend to get loaded up faster w/synthetic.
Regarding the use of synthetic in the manual tranny for the Contour, the pour
point of the PAO basestocks used in redline, Amsoil, and Mobil 1 is
ap[proximately minus 80F; certainly low enough to improve lubricity at temps
encountered in US and most of Canada. The EP additive makes sense to enhance
extreme pressure antiwear performance in a manual trans, since there are many
points where the oil is being "squeezed" metal to metal in the transmission; the
EP additives provide a sacrificial microscopic film of phosphate-sulphur
additive to keep the metal from contacting, even when the oil is completely
squeezed out of the space. Since it is sacrificial, you should change out oil
with new additive every 40K miles, just to make sure. I don't believe that you
will find that the EP additive will contribute to improved shifting while cold,
it will only reduce gear wear over the long run.
Richard Huckins
[email protected]
end quote
Peaty is offline
Old 07-28-2000, 06:58 PM   #10
burr101
Member#: 907
2002 WRX Sedan
Post
i use mobil 1, decent price and easily avaiable and i change every 3000.
Can some one please give me a quick lesson about oil weight?? i'm never sure which is the best at what time in what engine. please explain viscocity too!! thanks
shaun
burr101 is offline
Old 07-29-2000, 12:07 AM   #11
Faraz
What?...
Member#: 1459
2008 WRX 5door MT
WR Blue
Post
i still changed my synthetic oil ever 3500-4500 miles
Faraz is offline
Old 07-29-2000, 12:14 AM   #12
svxxx-26
Member#: 1645
Thumbs up
Best oil: Red Line synthetic. And yeah, I change it every 3 to 5 thousand miles.
svxxx-26 is offline
Old 07-29-2000, 12:16 AM   #13
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Worry less about the brand of oil and more about your filter and the weight of the oil.
ColinL is offline
Old 07-29-2000, 12:25 AM   #14
Fusion
Member#: 553
2000 2.5RS Coupe
Post
Has anyone actually heard of Lubro Moly? I thought it was better than Redline even.
Haig
Fusion is offline
HTML code is On
AMSOIL: The BEST Motor & Gear Oil & Filters WC LATHE WERKS Car Care & Detailing 1 08-19-2009 10:46 AM
What's the best oil weight to use on a Stage 4 engine nicholam Service & Maintenance 2 06-28-2007 10:13 PM
What's the best oil pump sealant? 2slofouru Normally Aspirated Powertrain 3 12-17-2006 12:45 PM
Best motor oil???? Rags North West Impreza Club Forum -- NWIC 50 03-12-2002 03:38 PM
What's the best oil grade Soon2Bgreat Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-31-2001 09:28 AM
