Old 04-07-2004, 01:53 AM   #1
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
Default Gains from weight-reduced pulley and lightweight flywheel?
There's a stock dimensions weighed reduced Perrin pulley (1.2lbs over 5.2lbs stock) and of course I can grab a lightweight flywheel too, what sort of gains am I looking at? EJ22E N/A. No exhaust mods. Intake and electrical.
JonofScio is offline   Reply With Quote
Old 04-07-2004, 01:55 AM   #2
Ruff
Member#: 32131
2006 Nissan 350Z
Was 01 2.5 RS
Well on the 1/4 which can be inconsistant, I trapped about .25 mph quicker on average with the addition of my perrin pulley. I will get back to you this friday, when our drag strip opens, as to what I run. I recently installed the exedy street clutch and lw flywheel.
Ruff is offline   Reply With Quote
Old 04-07-2004, 02:21 AM   #3
obyone
Member#: 16523
Man!...I don't know nuffin....but word out on da street is that a drop in flywheel weight from 30lbs to 12.9lbs will give you a butt dyno effect of + 12-15HP.
<--Butt dyno monkey.
obyone is offline   Reply With Quote
Old 04-07-2004, 09:45 AM   #4
Pat L.I.
Member#: 20498
2006 WRX TR
the flywheel will really help with throttle response, and your low end quite nicelly. It helps you get up into the sweet spot quicker! and once your in it you pull through it quicker. My revs fly up AND DOWN. i picked up the exedy sport clutch and lw flywheel combo. why not do the clutch while your in there aswell.
Pat L.I. is offline   Reply With Quote
Old 04-07-2004, 12:44 PM   #5
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
Yeah lw flywheel and pulley combo is very sweet. Starting from a stop or while moving at low rpm in the lower gears the combo is very noticeable and very fun. I would reccomend getting STI engine and trans mounts when doing this though. It will make the car much easier to drive at low rpms by reducing drivetrain lash.
Compressed is offline   Reply With Quote
Old 04-07-2004, 02:42 PM   #6
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I just had the exedy fw, clutch, sti motor and tranny mnts put in. It's hard to tell the difference, as I was babying it w/ a slipping clutch. I don't notice much of a difference, but I don't drag or auto-x any more.
AO
m750 is offline   Reply With Quote
Old 04-10-2004, 02:38 PM   #7
dcoty
Member#: 3149
01 V7 GC/R32 sky
I have an exedy 9lb flywheel and throttle response is crazy. But one thing to warn you about, if you get an aftermarket clutch (I have a bully 6 puck), you may get pedal vibrations at the friction point since the lighter flywheel cant soak up the vibrations as well as a heavier one.
This may not happen in your case, but with my setup there is a bit of vibration from a stop in first, but I can drive around it for the most part by not staying on the friction point very long when starting.
Dan
dcoty is offline   Reply With Quote
Old 04-10-2004, 05:10 PM   #8
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Re: Gains from weight-reduced pulley and lightweight flywheel?
Hello John,
When my OBS was N/A (it's back N/A now) and I had the pulley installed, my 1/4 mile times at the dragstrip was dropped .2 - .3. My trap speed increased 2-3mph. I have an auto.
Using a G-Tech Pro that I used to have, I posted this info on an old site of mine:
Subaru Outback (2.2L):
"My average runs before the pulley came out to [email protected] MPH. Then I changed my pulley and made four runs averaging [email protected] MPH. Did you hear me? I shaved almost 1/2 second off my time just changing my pulley!"
Kevin"
Unorthodox Racing took my quote off of my site (Subaru Information Webpage) and added it to their Testimonials section. It's funny because I never believed the testimonial sections of any site.
http://www.unorthodoxracing.com/testimonials.html
Kevin Thomas is offline   Reply With Quote
Old 04-16-2004, 05:12 AM   #9
obyone
Member#: 16523
AO
I replaced my flywheel before I did the STI mounts. I've already told you how the flywheel went (with stock clutch) but the mounts didn't do **** for drivetrain lash. The only thing they did was make my shifter rock solid! It's just insane how much play were in the stock mounts.
The stock mounts are made from a gummybear type rubber. I could easily flex the damn thing with my bare fingers while the STI mounts were so hard that I could barely make a tiny indentation while giving it alot of pressure.
The shifter response is the best part. If you thought the change from the stock rubber shifter bushing to urethane bushing made a hugh difference in shifter feel, then you honestly cannot imagine how much of a leap ahead is the difference when doing the STI mounts. I honestly cannot flex the shifter more than a millimeter when I try to force it side to side. The stocker would go half an inch at least, if not more.
Old 04-16-2004, 07:37 AM   #10
X4 SRT
Member#: 40636
2001 2.5 RS Coupe
I'm not too sure that the lighter pulley and lighter flywheel really make a difference at all. I have a friend with a 01 RS with the following mods:
Brullen SS exhaust
Injen CAI
N1 Lightend pulleys
Exeddy clutch
Exeddy Lightened flywheel
Mods on my 01 RS
Cobb CAI
Now we ran eachother a few times but nothing really serious. We didn't launch any of the times, so its a fairly good test of what kind of power gains you can expect. It basically came down to who started moving first. Neither one of us ever pulled on the other, and it was dead even the whole time. So, I'm not sure they really make a difference. Sure his car revs faster, but i think because of the torque that is lost in his set up I'm able to stay right with him. IMO. But alas. i will be buying my new pulley set on friday.
X4 SRT is offline   Reply With Quote
Old 04-16-2004, 10:14 AM   #11
m750
Member#: 2278
8Sti | 07 allez
White | Comp
I agree, this seems to be peoples recomendation to cure that, but I honestly think it's got alot to do with a low geared, high compression, low reving motor. You will get lots of Engine braking and therefore if you aren't smooth, lashing. IMHO.
The shifter response is the best part. If you thought the change from the stock rubber shifter bushing to urethane bushing made a hugh difference in shifter feel, then you honestly cannot imagine how much of a leap ahead is the difference when doing the STI mounts. I honestly cannot flex the shifter more than a millimeter when I try to force it side to side. The stocker would go half an inch at least, if not more. [/b]
What I have noticed besides the additional vibration, is the shifter is more solid, doesn't herk / jerk when acceling, and starting or stopping. Which I like alot.
Old 04-16-2004, 12:56 PM   #12
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
I would agree that the biggest benefit from the mounts is in shifter feel. Rock solid as everyone else has testified. However, I have noticed that my car is a bit easier to drive at very low rpms in first or second. Basically when I'm creeping the car in traffic I can move the car with small throttle inputs more easily, and without using the clutch as much.
WTB: new/ used clutch for 05 sti act 6 puck/exedy single and lightweight flywheel boostin05blacksti Private 'Wanted' Classifieds 1 12-27-2006 05:00 PM
NY: Exedy Organic Street Disc and Lightweight Flywheel Timdog1650 Private 'For Sale' Classifieds 4 04-01-2005 03:55 PM
Clutch and lightweight flywheel combo WRXXXXXXXXXXXX Private 'For Sale' Classifieds 6 09-30-2004 10:21 PM
STi clutch and lightweight flywheel on a 02 wrx? Autologic Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-05-2004 01:22 PM
lightweight crank pulley or lightweight flywheel? imprezey Normally Aspirated Powertrain 16 06-02-2003 05:01 AM
