Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 04-07-2004, 01:39 AM   #1
Do_It_Sidewayz
Member#: 24372
Default How to Calc Injector Flow??
Just wondering how i would see how much my stock Justy Injectors flow??
i'm trying to figure out if even throwing in a set of Stock 2.5 Injectors will do the trick.
BTW...my justy is Turbocharged, running 8.5 PSI of boost!
I'm trying to figure out if i should toss some injectors in it...or play with a RRFPR
Do_It_Sidewayz is offline   Reply With Quote
Old 04-07-2004, 03:42 AM   #2
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
STi-Nismo Dood is offline   Reply With Quote
Old 04-10-2004, 12:56 AM   #3
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
http://forums.nasioc.com/forums/show...hreadid=512707
you can use this utility I have been playing around with to see exactly what size injectors you will need. If you need to know what your OEM injectors will flow, call up the nearest subaru dealership and ask, they should be able to dig that info up. and avoid RRFPR's like the plague, I know I'm going to catch flak for saying it, but they are REALLY bad things. Your justy injectors probably flow better than stock 2.5rs injectors. Keep in mind you will need to use some form of computer trick if you move to any larger injectors. apexi S-AFC's are getting really cheap second hand ($150 or so) and work quite well when moving to larger injectors and higher boost levels.
no-coast-punk is offline   Reply With Quote
best place to get injectors flow tested n cleaned Sean2.5Black North West Impreza Club Forum -- NWIC 7 04-22-2009 04:48 PM
I think I figured out how to calc PWM duty cycles for stand-alones.... ktm Water/Methanol Injection, Nitrous & Intercooler Cooling 20 03-19-2008 07:23 PM
Where to get injectors flow tested? ninethreeeleven Tri-State Area Forum 10 04-22-2006 01:23 PM
How to calculate turbo flow STI8U Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-10-2004 06:29 AM
