Welcome to the North American Subaru Impreza Owners Club Sunday February 7, 2016
Old 04-06-2004, 12:50 PM   #1
Blitz04
Member#: 28099
05 CLK320
Default newb question: MY03 HID kit: daylight
if I get the HID kit for my car, how does day light work? does HID lights dimmer at day light?
Blitz04 is offline   Reply With Quote
Old 04-06-2004, 01:29 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Assuming you mean DRLs or daytime running lights, you must disconnect them if you get HIDs, by unplugging the control module by the glovebox. HIDs cannot be run as DRLs using the existing DRL system.
There are several threads in this forum on how to disconnect them, a quick search should turn them up.
Old 04-06-2004, 02:21 PM   #3
Blitz04
Member#: 28099
05 CLK320
thanks I meant day time running light..
what will happen if I don't disconnect the module?
Old 04-06-2004, 02:31 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Depends on how you hook up your HIDs.
If you connect them directly to the stock wiring for both positive and negative (not recommended), the DRL system will try to run the HIDs through a dropping resistor. This system is not designed to handle the high current the HIDs draw when first turned on so as a result the resistor may overheat and burn out, and you may see the HIDs flicker when in "DRL mode".
If you directly ground the HIDs (the proper way to connect them) and still use the factory headlight power, they will be on all the time because the DRL module keeps the headlights energized.
Disconnecting the main DRL module will avoid these issues.
Old 04-06-2004, 05:37 PM   #5
Blitz04
Member#: 28099
05 CLK320
thanks alot
Old 04-07-2004, 04:17 AM   #6
0083
Member#: 38818
1999 GC8
black
where is the DRL module in a GC? Thanks.
0083 is offline   Reply With Quote
newb question: warranty swartzfeger Newbies & FAQs 15 12-18-2004 01:25 AM
HID newb question: "OEM HID projectors"? aznfoos Electrical & Lighting 2 07-24-2004 07:34 PM
Another newb question: Does selecting a gear without clutching hurt your car? -=Ice-T=- Transmission (AT/MT) & Driveline 9 03-25-2003 01:45 AM
Newb question: Is it worth having a water temp guage in a WRX TrunkMonk Newbies & FAQs 14 02-12-2003 04:45 AM
