Old 04-07-2004, 08:13 AM   #1
odie
Member#: 59039
Default Cruise control?
The cruise control on my 02 WRX is not working. The light comes on on the dash, but the speed will not set. Is there a fuse or something that I can check?
I've only had the car a week, so I am trying to figure everything out.
Thanks
Jason
odie is offline   Reply With Quote
Old 04-07-2004, 10:37 AM   #2
eric m.
Member#: 14872
02 WRX Wagon
99 Forester
take it to the dealer if you have a warranty. there is a recall for the cruise control, actually. i know it is probably not related to your problem, but it might be. and yeah, it could be a fuse. the cruise control is fused.
eric m. is offline   Reply With Quote
Old 04-07-2004, 10:55 AM   #3
odie
Member#: 59039
Where can I find that fuse?
Old 04-13-2004, 01:01 AM   #4
perfusionista
Member#: 59471
2006 WRX Wagon
Crystal Gray
Default Re: Cruise control?
Thanks
Jason
Are you trying to activate cruise above 90mph? I had this prob when I first got mine. Cruise OK thru town @ 60, get out in the open and hit 3-figures, cruise won't work. Finally worked out that 90 is limit: you have to set cruise @ 85 then use accelerate function (push lever up) until you reach 90 and that's as far as you can go!
perfusionista is offline   Reply With Quote
Old 04-13-2004, 08:53 AM   #5
skyhawk
Member#: 36255
04 WRB WRX
Drive 2 Work,Work 2 Drive
I've never seen a speed limit in any town that fast
skyhawk is offline   Reply With Quote
easiest way disconnecting cruise control cable from TB, cruise control removal 02-03 fastwrx25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-21-2008 07:30 PM
UTEC: If the cruise light is flashing....cruise control doesn't work? bpwatts Engine Management & Tuning 4 07-10-2006 07:07 PM
Cruise Control Aint Cruising ahawks Service & Maintenance 0 10-21-2005 01:12 PM
Cruise actuator but no cruise control!! Improviser Normally Aspirated Powertrain 14 11-13-2002 04:48 PM
