Old 04-07-2004, 10:14 AM   #1
Dracon
Member#: 50613
Default So I read the Offset thread...
but like many, I'm still a little confused... especially since a lot of posters contradict others...
I'm looking into a set of Enkei wheels that are:
Size - 18 x 7 1/2
Offset - 50
This is about the closest thing to "perfect" that I could find... I would actually prefer to get 17's but the offset isn't as close to what it should be... They are:
Size - 17 x 7
Offset - 48
Am I correct in thinking the the 18 x 7 1/2 is going to be better for my bearings and closer to stock??
Thanks!
Dracon is offline   Reply With Quote
Old 04-07-2004, 10:17 AM   #2
Tire Rack Moderator
Member#: 1215
ext. 4362
you'll be fine in the 48-53mm range ....
Old 04-07-2004, 10:21 AM   #3
Midwestrider
Member#: 42955
2004 Bone Stock..
I would say that wa 18x7.5 w/ +50mm would be safe to run as most 7.5 wide wheels are +48mm offset (ie.. Provdrives, Rota's and others)
I myself am looking at 18x8 w/ either a +50mm or +51mm offset for my wagon w/ 225/40/18 and trying make sure no rubbing will occur.
Hope this helps ya out..
Midwestrider is offline   Reply With Quote
Old 04-07-2004, 10:30 AM   #4
Dracon
Member#: 50613
thanks, I actually forgot to ask about the rubbing... would that be an issue with my choices?
Thanks!
Old 11-18-2012, 03:35 AM   #5
ryangrz18
Member#: 316342
2009 2.5i
pearl white
ok guys been reading these forums for a bit now trying my best toget a clear answer but still not sure. was told from a dealership thatthe 045 msr 18x8 5x100 35 offset with 225/40 r18*tires*would fit my*2009 impreza 2.5i. no alterations n hoping not to. is this gonna work?thnx. ryan******
ryangrz18 is offline   Reply With Quote
Old 11-18-2012, 04:38 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
an 18x7.5 wheel is almost useless
a 17x7 is only good for winter use, really
Old 11-18-2012, 04:39 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
....and bumping threads from 2004 is NOT gonna tell you ANYTHING about a 2009 car
So I was reading the tshirt thread afpdl Texas Impreza Club Forum -- TXIC 5 11-08-2006 01:57 PM
So i read the "how to clear the 04+ headlights" thread VTSubieRS Interior & Exterior Modification 26 07-14-2005 09:20 AM
need help with rim offset and i have read the offset sticky Richmond WRX Tire & Wheel 8 03-06-2005 03:51 PM
So, after reading all these threads the verdict is... casualsurfer Transmission (AT/MT) & Driveline 4 05-27-2004 12:57 PM
So, what *is* the offset on the new WRX? AutoXr Brakes, Steering & Suspension 4 11-17-2000 02:59 PM
