Old 04-07-2004, 11:15 AM   #1
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
Unhappy Holy Crap! A/C kills my engine.....
Hey all,
I got a problem...
I went to turn on my A/C the other day and I heard this loud screeching noise from my engine and then it died. I was able to start it back up again, but when I cut on the A/C or the windshield defroster I got the same noise and the same engine death.
It's weird, the car works fine if i have the fan on and the selector dial is at anything except AC or the windshield defroster. If I turn the fan off and set the selector to either those settings it still works. But as soon as i cut on the fan with the selector at one those settings the engine screeches and dies. *** is wrong with my car?? I'm at 100K miles and I just got the oil changed & the belts serviced. I've been religious with my preventive maintenance. Other than a leaking valve cover gasket, my engine is tip-top. Please help!
bongchild is offline   Reply With Quote
Old 04-07-2004, 11:31 AM   #2
00RScoupe
Member#: 57535
2004 FXT
Maroon
If your A/C compressor is siezed it could put such a load on the car that it would die, and make a horrible noise.
Did it happen only after they serviced the car.?
00RScoupe is offline   Reply With Quote
Old 04-07-2004, 12:26 PM   #3
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
Yep. I took it to Jiffy Lube to get the belts serviced. I figured those guys over there knew what they were doing.....
Old 04-07-2004, 12:45 PM   #4
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
Jiffy Lube?
ommmjido is offline   Reply With Quote
Old 04-07-2004, 12:50 PM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Originally posted by ommmjido
Jiffy Lube?
my thoughts exactly
you realize that jiffy lube is the toilet of automotive service rigth?? and your a/c compressor is more then likley siezed
Old 04-07-2004, 12:54 PM   #6
bongchild
Member#: 28352
1993 1.8 helL (AWD)
'06 Corolla XRS!
Jiffy Lube?
Yeah, yeah... It was right there and I didn't have a whole lot of $ in my pocket so I went for it. So my compressor is seized, eh? I take it that means I need to get it replaced, ja? Of all times, too. I'm out of dough and the hot season is right around the corner....
Old 04-07-2004, 11:11 PM   #7
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
could it be a vacuum issue? My car will stall out sometimes if it's in idle with the a/c or just the heat on...Just a thought.
//marcus
marcus12 is offline   Reply With Quote
Old 04-08-2004, 12:40 AM   #8
redwagon
Member#: 2181
2008 SpecB
Take it back to Jiffy Lube and make them put it right. Could be they overtightened the belt?
redwagon is offline   Reply With Quote
Old 04-08-2004, 01:42 AM   #9
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
Ditto on the proper servicing but stay away from them afterwards. I've seen some costly damage because some of them were not knowedgeable.
joubtt is offline   Reply With Quote
Old 04-08-2004, 02:56 PM   #10
anders8
Member#: 26658
1 Love Grassroots
NASA Rally Sport FTW!
Dude, first things first.
Start your car. Open the hood. Watch your belts. Have a friend inside the car turn on the AC. If the AC clutch engages but doesn't turn, then yes, it has seized.
You will need to watch it happen. When you say "the engine screeches" we don't know if that's a belt, the engine, the compressor, or some pulley.
Need more info.
anders8 is offline   Reply With Quote
Killed my engine Lopez75 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 07-16-2006 01:21 AM
Oil restrictor killed my engine!!!! bugeyes Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-13-2005 03:08 PM
holy crap! I just broke my toe! bleuquila Off-Topic 16 12-18-2003 11:55 PM
OT: Holy crap! 4K to replace my gf's mazda tranny!!! Evegan South East Region Forum 7 07-16-2003 05:23 PM
crap what happened to my engine? scrappy doo Normally Aspirated Powertrain 12 05-13-2003 09:17 PM
