Closed Thread
Old 04-07-2004, 05:27 PM   #1
racinready300ex
Member#: 21953
Default 5 speed clutch 6 spd tranny??
Can I use a 5 speed clutch on a sti 6 spd tranny? I want to drop a sti tranny into my 02 wrx. It'll be a couple of months before I have the money for the tranny. But much clutch is in pretty bad shape know. If I put in a ACT 5 spd clutch in now will it work with the sti tranny?
I don't want to waste any money here, this is going to cost enough as it is. But I don't want to limp around on a weak clutch if I don't have to.
Any body ever done this?
Thanks
racinready300ex is offline
Old 04-07-2004, 05:31 PM   #2
5spdfrk
Member#: 46407
blew
bump for answers
5spdfrk is offline
Old 04-07-2004, 05:38 PM   #3
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
Now of course I'm speaking with no experience, but reading around here I seem to recall you need the 6spd flywheel, so I would assume a different clutch.
Hopefully this will tide you over until someone with ACTUAL knowledge comes and answers you.
mexicanpizza is offline
Old 04-07-2004, 05:40 PM   #4
cronic
Member#: 9749
I am not sure about the 5pd into 6spd but i know people have made the 6spd clutch work in the 5spd with some grinding.. Why not go that route if you are sure you will go 6spd?
cronic is offline
Old 04-07-2004, 05:41 PM   #5
MiamiLife
Member#: 32486
03 WRX
2004 FXT
Head on over to the drivetrain forum for more answers.
MiamiLife is offline
Old 04-07-2004, 05:48 PM   #6
racinready300ex
Member#: 21953
Seem like more people come through here than the drivetrain forums, that's why I posted it here. But, I'll try that.
I may consider changing the clutch and then going with a gear set. But, I really want a 6 speed lol.
Old 04-07-2004, 06:18 PM   #7
ErikAnderson
Member#: 26739
Turbo4me did a 6 speed swap on his WRX and is using the 5 speed clutch and i want to say flywheel... don't quote me though. Pm him and see
ErikAnderson is offline
Old 04-07-2004, 07:35 PM   #8
mixup52
Member#: 39691
2002 WRX Wagon
you should just do the 6 speed clutch on your 5 speed until you can get the sti tranny. The clutch, flywheel and throw out bearing is ~ 300.00. Here is a link to do the 6 speed clutch into the 5 speed tranny.
http://forums.nasioc.com/forums/show...hreadid=496150
Chris
mixup52 is offline
Old 04-07-2004, 09:04 PM   #9
redhat778
Member#: 34184
02 WRX
Now with STI VII Swap
I put a 5 speed clutch made for my wrx in 6 speed
redhat778 is offline
Old 04-08-2004, 01:01 AM   #10
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
it will fit fine....use the 5spd clutch and flywheel if you want
mr2guru is offline
Closed Thread
1 STi 6 spd Tranny in Stock! JDM 5th/6th Close Ratio Conversion! Clutches! Gruppe-S Drivetrain 6 10-18-2005 05:58 PM
6spd clutch in 6 spd tranny? possible? OneArmedScissor Transmission (AT/MT) & Driveline 1 04-07-2004 07:29 PM
5-speed clutch for use with STi 6-speed? Red Rocket Transmission (AT/MT) & Driveline 13 01-23-2004 05:43 PM
