Old 07-27-2000, 06:49 PM   #1
Rax
Member#: 1973
Post Looking to get a 2.5 RS
Greetings,
I am hoping to purchase an Impreza 2.5RS. It has been a car I have wanted for some time as I think rallycross is awesome. I found a 1998 Impreza 2.5 RS Coupe at a dealer around here... it has 24,000 miles on it, a manual transmission, cd player, and moonroof. The car also has 1 year/12,000 miles left on the bumper to bumper factory warranty. The dealer is asking $15,995 for it. Does this price seem reasonable? I was hoping to be able to get it to around 14,000 or 14,500 out the door... how does this sound?
Secondly, I am going to take a look at it tomorrow... is there anything in particular that I should check for, such as known problems that this year/model are prone to? Possibly something that can be used towards getting a lower price?
All thoughts, ideas, and comments are greatly appreciated.
Thank you
Rax is offline
Old 07-27-2000, 07:54 PM   #2
Overtime
Member#: 1346
Arrow
Just lettin ya know...
Moonroof is standard. CD was 400 extra from the factory.
I think it's a good price.
Check for the clutch, which has been a noted problem. The weak clutch is a definite issue. Also mention the fact that it's the Phase 1 DOHC engine with a much less smooth torque curve than the new SOHC engine. Also mention that it's no longer made and is the only model year with that DOHC. It also has slightly less power than the 99 and 00s.
I think 15k for a gently used MY98 with low mileage is okay. But 14k would be much better. Have you gotten the Kelly Blue Book value on it yet?
Keep in mind throughout that used cars are where salesmen make their money. Make sure to take note of that fact. He's making way more money than on a new vehicle. Remind him of that.
What color, if I may ask? If it's green or red, use that against the dealer, as green and red aren't offered anymore. For that matter, neither is the white-it was changed to aspen white in 99.
Have a good one...good luck with the car!
Overtime is offline
Old 07-27-2000, 07:59 PM   #3
edekker
Member#: 143
1999 Impreza 2.5RS
Supercharged - and STOLEN
Post
Rax,
There are a few things you should look out for (and hopefully others can add to this) -
1) Check the power windows. They should move easily up and down with no sign of struggle. At the same time check for some vertical scoring or scratches running up along somewhere near the center of the windows.
2) If the windows have been tinted (or even if they hadn't been) they may not seat (seal) against the weather strips as tightly as they should. I recommend you subject the car to one of those touchless car washes, or any place which thrashes the car with high pressure water - there shouldn't be a drop of water coming in.
3) Check for scoring along the ABS brake lines which run along the passenger side of the motor. On some cars, for some reason, the lines run too close to the motor and they rub against it (the stock motor mounts are soft and when the car is driven hard the motor literally whacks itself side-to-side).
4) Test the clutch when the car is stone cold. The clutch should not grab but engage smoothly with no sign of shudder.
5) Some cars have this dreaded hesitation problem. The car will suddenly lurch and/or bog. It can happen unexpectedly in any gear and RPM whether accelerating hard or not. Put the car 'through the ringer' and make sure it doesn't do that. Don't be afraid to hit that rev limiter.
6) The rear wheel bearings have a reputation of going bad very quickly. The problem is not with the bearings proper, but with how they had been installed at the factory. Do a test drive on a smooth road and listen carefully. From a dead stop accelerate smoothly and calmly. If you hear a sound similar to the kind winter tires make, which increases in frequency with the road speed, then the bearings are suspect.
The car is a blast - you'll have fun. Good luck.
Regards,
Ed.
edekker is offline
Old 07-27-2000, 08:01 PM   #4
Fred Zaplitny
Gone... But not forgotten
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Talking
If it's green that's cool. Green is rare, very rare among RS's. I love green.
Fred Zaplitny is offline
Old 07-27-2000, 08:07 PM   #5
Rax
Member#: 1973
Post
It is black. The Kelley Blue Book value appears to be $16,970... seems a little bit out of proportion...
However, the clutch problem will be a good thing to know if necessary... along with the change in engines, I was unaware of this...
Thanks a lot for your help... I hope the everything goes well with the car because I would really like to get it!
Rax is offline
Old 07-27-2000, 08:09 PM   #6
Rax
Member#: 1973
Post
whoah, a bunch more was posted while I was typing a reply to the first post... I will thoroughly check the items that you mentioned edekker, thank you for your help.
Rax is offline
Old 07-27-2000, 08:19 PM   #7
Faraz
What?...
Do they speak English in What?
Member#: 1459
2008 WRX 5door MT
WR Blue
Post
IMPREZA-4 Cyl.
Body Style: Coupe 2 Door RS
Model Number: M67
Weight: 2,825
Acceptable Mileage Range: 38,000 - 42,000
Vehicle Identification Number (VIN): JF1GM675XW()500001 and Up
Low Retail: $13,375
Average Retail: $15,075
High Retail:$16,125
Optional Equipment
Add Compact Disc Player: $100
Deduct W/out AutomaticTransmission: ($400)
Totals
Total Low Retail:$13,075
Total Average Retail:$14,775
Total High Retail:$15,825
Options included in valuation are:
Automatic Transmission
Air Conditioning
All Wheel Drive
Next Time Use the guide that the Dealers use:
i'd take it for $14,250 or lower
Faraz is offline
Old 07-27-2000, 08:34 PM   #8
Rax
Member#: 1973
Post
What guide do the dealers use?
Rax is offline
Old 07-27-2000, 08:56 PM   #9
Faraz
What?...
Member#: 1459
2008 WRX 5door MT
WR Blue
Post
www.nada.com
nada guides that's where those #s came from
Faraz is offline
Old 07-27-2000, 10:38 PM   #10
JC
Member#: 692
2011 Grand Cherokee
Triumph Speed Triple R
Post
Use edmunds its always got the lowest price. Kelly is always too high, IMHO.
JC is offline
Old 07-28-2000, 06:46 AM   #11
Rax
Member#: 1973
Talking
Thanks for the help guys. I will let you know how things turn out.
Thank you
Rax is offline
Old 07-28-2000, 02:07 PM   #12
Rax
Member#: 1973
Angry
well, things went terrible... the car was in good shape... there some things wrong with it and such... but it went really bad when we started talking about price... the guy wouldn't even negotiate with me... I gave him an offer and he wouldn't even make a counter-offer on it... I was able to talk him down to $15,250 but that is still too much... the guy was a complete moron... I suggest avoiding Brunswick Nissan and Subaru.. in Ohio
Now, I doubt I will be able to find another RS...
Rax is offline
HTML code is On
Hey guys, new around here! Looking to get a 2.5 RS real soon to join the Scooby Fam! abui01 Mid Atlantic Impreza Club -- MAIC 6 09-02-2008 03:04 PM
('93-'01) What to look for in a 2.5 RS teamzzyzx Impreza Forum 11 11-21-2003 09:51 AM
Lets say I were to look at a used 2.5 RS from a Subaru dealership.. Thursday Newbies & FAQs 7 07-22-2003 06:38 PM
looking to buy a 2.5 RS in a month or 2, in the DC/VA/MD area obsol33t Mid Atlantic Impreza Club -- MAIC 7 09-13-2002 02:59 PM
looking to buy a 2.5 RS soon2bscooby Southern California Impreza Club Forum -- SCIC 2 06-17-2002 04:35 PM
