Old 04-07-2004, 08:16 PM   #1
subegt
Member#: 58929
2000 GT Wagon
Question ABS Light
I have a 2000 Legacy GT Wagon. When I turn my headlights on the ABS light turns on. The dealer has not been able to isolate the problem for over four days now. The dealer claims the ABS system is working properly regardless of the light.
Aside from bypassing the light, has anyone seen this before or have a technical solution?
Thanks!
subegt is offline   Reply With Quote
Old 04-07-2004, 08:25 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Could be an electrical system issue and not the ABS itself. The added drain from the lights may be causing enough of a voltage drop to trigger the ABS light.
I'd suggest checking the system voltage at the battery with a voltmeter to see if the alternator is charging properly. Check the voltage both unloaded (no accessories on) and loaded (lights on and some other things), it should remain around 13.5-14.5 until there is a very heavy load on the alternator, then it may drop down.
It's also possible to have a bad diode or two in the alternator resulting in "dirty" electrical output, so even though it would still charge there could be some strange electrical gremlins.
So, the short Cliff Notes answer is to fully check the electrical system and you may find your answer there.
Old 04-09-2004, 12:26 PM   #3
subegt
Member#: 58929
2000 GT Wagon
Thanks, for the reply.
Well it turns out to be a shorted brake lamp. This is the style that has two lead spots on the end. According to the dealer one of these bulbs was shorted. Six days for a light bulb? WOW.
ABS light on, what sensors trigger it? wheel ABS sensor, speed sensor, what else? kirbykirb Legacy Forum 4 06-19-2010 10:37 PM
ABS light on, diagnosed with a front right ABS hold valve malfunction C-daleRidr Service & Maintenance 0 09-04-2007 03:39 PM
ABS light wierdness.. Faulty ABS Sensor? TKDKracker007 Brakes, Steering & Suspension 6 05-06-2006 12:33 PM
ABS light still on after ABS ring replacement six1five Brakes, Steering & Suspension 3 11-08-2005 09:29 AM
ABS light/ABS is dead Hawk296 Service & Maintenance 15 02-20-2004 04:43 PM
