Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 04-07-2004, 09:47 PM   #1
PeterJ
Member#: 14727
2002 impreza RS
Question Forester suspension on impreza
Do you guys know of any combination (US or JAP) of forester strut and spring (lowering?) that, when installed on a GD impreza, would yield a normal ride height, but offer more droop travel? Thanks
PeterJ is offline   Reply With Quote
Old 04-08-2004, 10:52 AM   #2
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
Peter, bear in mind that droop travel is all about spring rate. If you go with a stiffer aftermarket spring you'll lose droop travel no matter if you have an impreza or forester strut.
FWIW, Tien softs for a SG Forester are 3k front and 1.8-3.6k progressive in the rear according to this.
Do you know how much your car weighs at each end? It's going to matter as much as the free-length of the springs will.
Stock free-length on SG Forester springs is ~ 16" front and 14" rear. I can't find the rates with a quick google search, but I seem to recall they're really low. 140 lbs/in front and around 110 lbs/in rear maybe?
[edit]
Actually, that sounds close -- with 140lbs/in springs a 6" droop requires 1680lbs on the front end. Actually a bit more, as the struts require some force to compress too. [/edit]
Chromer is offline   Reply With Quote
Old 04-08-2004, 11:11 AM   #3
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Just buy some ground control coilovers or Teins, that way you can raise and lower.
BrysImpreza is online now   Reply With Quote
Old 04-09-2004, 09:26 PM   #4
PeterJ
Member#: 14727
2002 impreza RS
Thanks, I have wrx springs which are around F160/R120 and they yield about F3"/R4" of sag/droop at ride height. The car has something like 1800 on the front and 1200 on the rear. Without the bump stops, the struts give you 6.5" front travel and 7.5" rear. All of the above numbers are approximations, but are pretty close ones. Thanks for the info.
Another problem is that on the forester struts, I think that the spring perches might be welded higher up on the strut body, so if I started at stock impreza ride height, my bump travel might be reduced. It would be nice to have both more bump and droop travel; but, the same amount in bump and extra droop was what I was initially thinking.
Old 04-15-2004, 08:07 AM   #5
DriftZero
Member#: 39616
Everyone has
stories they bore me
Yea Forester suspension actually gives you a rally look.
SOD
Eli
DriftZero is offline   Reply With Quote
Old 08-25-2013, 06:50 PM   #6
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Forester suspension on my impreza
Old 08-26-2013, 03:25 PM   #7
79letour
Member#: 302570
2013 XV
DGM!
It works so well Subaru sells em that way
79letour is offline   Reply With Quote
Old 08-26-2013, 03:26 PM   #8
79letour
Member#: 302570
2013 XV
DGM!
Well- lifted, of course.
Old 09-23-2013, 03:30 PM   #9
yotasteak569
Member#: 287333
I think its funny subaru tosses lifted suspension on an impeza and calls it a new car
yotasteak569 is offline   Reply With Quote
forester suspension on a bugeye?? oh2wrxBLk Brakes, Steering & Suspension 5 10-12-2008 02:41 AM
Forester suspension in Impreza Outback? flyingmachine Brakes, Steering & Suspension 29 05-24-2008 05:51 PM
Forester suspension on WRX ?'s SilverSpool Brakes, Steering & Suspension 1 11-29-2006 03:21 AM
Forester suspension on WRX wagon? kingston Brakes, Steering & Suspension 5 01-04-2005 02:07 PM
Forester Suspension on a WRX? KC Brakes, Steering & Suspension 2 10-26-2004 11:46 AM
