Old 04-08-2004, 12:12 AM   #1
wkderf
Member#: 47027
2004 Impreza STi
I Heart Prodrive
Default serious electrical problems!!!
im having some serious issues with my 04 wrx: i cant get my headlights to turn on, only the DRLs will light up, not the high beams or brighter low beams. my reverse lights dont work, my e brake light is on regardless of the e brakes position, and my abs light comes on and off every time i try to turn my headlights on, and whenever my engine is running, my radiator fans are blowing. my cruise control also does not work.
this is not a joke and all of these problems happened at once when i started the car this evening after having driven it twice already today. my only electrical mod is an alarm / remote start but that was installed almost a month ago with no problems whatsoever. any imput would be great.
i have to call to schedule a warranty appointment but im looking here for any possible answers.
PLEASE HELP!!!!!
wkderf is offline   Reply With Quote
Old 04-08-2004, 01:42 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
There are green connectors under the dash these should NOT be plugged together. Did you do this recently?
Old 04-08-2004, 01:53 AM   #3
wkderf
Member#: 47027
2004 Impreza STi
I Heart Prodrive
i have done nothing under the dash. where are these connectors under the dash?
Old 04-08-2004, 01:10 PM   #4
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Who installed the alarm/remote starter? A mistake that may not have been apparent upon installation could later manifest into an electrical problem (i.e. a short). If you installed it yourself, you may want to back-track your installtion to make sure eveything is connected properly. .......just throwing out ideas/possibilities.
Kean is offline   Reply With Quote
Old 04-08-2004, 01:18 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
First thing to do is check ALL the fuses in the car, especially the large main ones in the underhood fuse box. If one of these blows it will affect several circuits in the car. Should you find one of these fuses to be blown you then must find the reason because they very rarely do so.
The green diagnostic connectors under the driver side dash will cause some strange things but not what you're reporting. The only common symptom is the fans running, but if those connectors were plugged together you would also have a constantly flashing CEL (even in "run" position with the engine off). Can't hurt to check under there anyway.
There should not be a problem getting the dealer to fix this under warranty, as long as it doesn't turn out to be caused by the alarm. If it does, the alarm installer should be responsible for the cost of the repairs.
Old 04-08-2004, 09:56 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Sounds like you have a major ground issue.
Check the wires and connections for the remote start.
check the battery cables. Disconnect the remote start if you can and see if the problem goes away.
Jay
Old 04-09-2004, 10:24 PM   #7
wkderf
Member#: 47027
2004 Impreza STi
I Heart Prodrive
update: no improvement. things are controlling things that they shouldent even be connected to. when i attempt to turn the headlights on ( which still dont work) my speedometer drops to zero. the same thing happens when i have the headlight switch off and i try and use "flash to pass" also, when i put the car in reverse, the e brake light and the ABS light come on in the dash and they dont go off until i start to drive forward. and my radiator fans are allways on when the engine is running.
the car drives like normal and my A/C, rear defroster, and A/C fans work as they should. my appointment is set for monday. i am POSITIVE that the alarm is not the cause of this - I work at tweeter in the mobile dept and had this alarm installed by a 7 year vet in the buisness. i have had no problems with the alarm for the entire month that it was installed. now this????????
any insights would be great. any estimates of the cost to fix incase i have to front the repair cost for tweeter?
Old 04-09-2004, 11:07 PM   #8
brunetmj
Member#: 8023
2004 2.5 RS
I have had a short that produced some of those problems. A simple device that hooked into the backup light had a nick on the
wire and was touching metal. However this also produced blown fuses.If it was me I would disconnect everything that plugs into the alarm and remote starter. Basically Pull the plug on it. Then check all fuses. An alarm and remote starter has access to all lot of the car wiring, which is why I would suspect it to be the cause.
brunetmj is offline   Reply With Quote
Old 04-10-2004, 10:31 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
In absence of any other possible cause, the only possible thing that may be causing your problems HAS to be the alarm if nothing else is different.
Old 04-11-2004, 09:41 AM   #10
wkderf
Member#: 47027
2004 Impreza STi
I Heart Prodrive
all problems solved. cause was blown fuse #11, but fuse was blown in an odd place so it didnt look like it went bad. i appreciate all of the help.
Old 04-11-2004, 09:44 AM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Check everything that is on that fused circuit so you can find the cause, otherwise this may happen again.
Which fuse box was that in?
Old 04-11-2004, 05:24 PM   #12
wkderf
Member#: 47027
2004 Impreza STi
I Heart Prodrive
the one inside the car. we have tested all components connected to this fuse and will continue to monitor it closely. at this point, i sincerely believe that it was just a bad fuse that prematurely blew.
Old 04-15-2004, 01:11 PM   #13
subegt
Member#: 58929
2000 GT Wagon
My Legacy had similar problems recently. The ABS light came on when I had the headlights on. It turned out to be shorted break lamp. The type with two poles on the base of the lamp. It took the dealer 6 days to find. The most expensive lamp I have ever replaced! $250 due to my Ext. Warr. deduct.
subegt is offline   Reply With Quote
Old 04-15-2004, 02:53 PM   #14
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i wouldn't pay them 250 bucks to troubleshoot a blown lightbulb... never in a million years!!
jm2c
ken
Old 04-23-2004, 08:21 PM   #15
shadrool
Member#: 59775
09 forester
white
thats why you boy works @tweezer. 7 year vet. HA. tool should have figured that one out.
shadrool is offline   Reply With Quote
Old 04-24-2004, 09:16 AM   #16
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
Fuses don't go bad.
yamarocket630 is offline   Reply With Quote
Old 05-24-2004, 04:50 PM   #17
subaru mike
Member#: 30749
2002 wrx
This sounds like my situation, i think that i will check it out.
subaru mike is offline   Reply With Quote
Old 03-05-2009, 08:44 PM   #18
tunamius
Member#: 200473
04 STI
Sounds just like my situation after my alarm and remote start install too. I have abs and brake lights coming on together even though my brake is not engage. Also the speedometer jumps around a lot. In addition, my headlight level adjustment does not work but when I try to adjust the level the brake and abs come on immediately. I will be checking all fuses tomorrow and maybe have my installer pull the alarm/remote start to see if the problem persists? Anyone have any other suggestions?
tunamius is offline   Reply With Quote
Old 03-06-2009, 11:23 AM   #19
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
nice bump
Old 03-06-2009, 08:37 PM   #20
superbowl3232
Member#: 204957
That sounds like a fix
superbowl3232 is offline   Reply With Quote
Old 03-09-2009, 07:08 PM   #21
tunamius
Member#: 200473
04 STI
Fixed it today. The back up light fuse was bad. It caused the abs and brake light to go on. In addition it caused the speedometer to behave weird. Hope this helps others with the same problem.
Old 03-10-2009, 11:40 AM   #22
robbie2883
Member#: 151396
glad you figured it out!
robbie2883 is offline   Reply With Quote
serious electrical issues pannell77 Electrical & Lighting 5 04-11-2010 12:32 PM
serious electrical issues pannell77 Mid West Subaru Owners Club Forum -- MWSOC 7 04-11-2010 09:17 AM
Serious Electric Problem SUBA-NOS Newbies & FAQs 2 07-27-2005 12:13 PM
Need help: serious electrical problem with MY02 Impreza TS Automaton Car Audio, Video & Security 13 04-14-2002 03:38 PM
serious idle problems on 99RS pearlblack2.5rs Service & Maintenance 8 03-29-2002 09:11 PM
