Old 04-08-2004, 08:40 AM   #1
adeliciouspizza
Member#: 7844
05 STI CGM
OMGHi2U Wiring for STI IC Sprayer Switch/Tank
i need to hook up a sti ic sprayer switch & tank in my 02 wrx. i have everything i need except the wire that goes from the switch to the pump on the tank. it is the oem/jdm ic sprayer switch.. looks just like the oem cruise control switch (its probably the same one the usdm sti gets). it looks like it takes one of those small 3 or 4 prong plastic snap in connectors.
i have searched google and here and have not found anything.. i also asked the place where i bought the tank and they dont know although they said they will ask around. has anyone else had this problem & what did you do? pleeeease help..
adeliciouspizza is offline   Reply With Quote
Old 04-08-2004, 12:50 PM   #2
awdman
Member#: 27962
2003 WRX Sedan
Blue, with more dings!
Default Two options.
You'll have to either run your own wires or you can hack the wire used for the wagon's rear washer pump. Depends on where you want your tank of course...
Alot of us made our own female spade connectors to fit the switch or bought them at electronics stores. (Not Radio Shack)
awdman is offline   Reply With Quote
Old 04-08-2004, 04:24 PM   #3
adeliciouspizza
Member#: 7844
05 STI CGM
that helps alot. i dont know why i didnt think of using a spade connector. should be a piece of cake. thanks :]
Perrin PWI-1 using STi IC Sprayer Tank for Meth. Big-Sexy907 Water/Methanol Injection, Nitrous & Intercooler Cooling 8 05-11-2009 02:36 PM
WTB: Sti IC sprayer tank TurboWRX32 MAIC Private Classifieds 3 08-28-2008 06:28 PM
FS: Stock USDM STI IC sprayer switch ScoobyNubieToo! Interior/Dressup/Audio & Security 5 12-23-2007 02:49 AM
FS:STi ic sprayer switch,plug,ic nozle & one way valve."pic" joe r Engine/Power/Exhaust 7 10-16-2006 09:40 PM
In search of a switch hot wire near IC sprayer switch. StiDreams STi Forum Archive 3 09-07-2003 08:35 PM
Message Board Statistics All times are GMT -4. The time now is 11:06 AM.
