Old 04-08-2004, 01:41 PM   #1
OB2
Member#: 51500
1999 impreza rs-t
sylver
Default Tm Ic???
Where can i find a tm ic that fit on a 99 RS engine bay??? I know MRT ans Searco make IC but they are to big to fit betewen the TB and the firewhale!!!
OB2 is offline   Reply With Quote
Old 04-08-2004, 03:05 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
get one made, its a LOT cheaper than i thought
Old 04-08-2004, 03:47 PM   #3
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
Ditto on custom. Just buy a core and have someone bend you pipes. It'll be less headache then modifiying a US WRX one or a GC8 WRX one.
seven881 is offline   Reply With Quote
Old 04-10-2004, 02:43 AM   #4
Unsung Boxer
Member#: 37196
what do you mean? if you take a WRX one (or one designed for WRX) then cut the snout on the intercooler, then shave the snout on the throttle body, it will fit.
the real problem is the orientation of the intake manifold (i think). I believe the RS/L manifolds go farther back than the WRX one.
I am using a WRX intercooler on my GC. it is a tight fit, but it works. And more importantly it was cheap, so i didnt feel bad about cutting it
-Jake
Unsung Boxer is offline   Reply With Quote
Old 04-10-2004, 05:01 AM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
im talkin for a beefy setup
Old 04-10-2004, 12:23 PM   #6
Unsung Boxer
Member#: 37196
then go front mount
-Jake
Old 04-10-2004, 12:27 PM   #7
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
it depends what you want to do, drag racing, definately a front mount, auto-x or road racing have a top mount made. You can make USDM WRX TMIC's fit, but it's not incredibly effective. If you really don't want to have one made you can probably dig up a JDM GC STi intercooler and make it fit
no-coast-punk is offline   Reply With Quote
Spearco TM or wait for Cobb's TM?? hondaeater69 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 03-04-2005 09:55 AM
Intercooler Tm MIDNIGHTROCKET Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-27-2003 12:18 AM
Just had the lamest TM call me Brad Pittiful Off-Topic 4 09-19-2003 03:59 PM
Technomagnesio TM Sports That Guy Brakes, Steering & Suspension 1 12-24-2002 02:05 PM
Rallispec-tm Intakes Availble vivace Tri-State Area Forum 1 09-07-2001 07:44 PM
