Old 04-08-2004, 01:41 PM   #1
2dino
Member#: 41907
Default Is this correct engine air filter for STi?
Hi from Toronto.
Have a 2004 STi
Bought air filter from dealer in Toronto.
Filter in the box is dry paper element.
Box is white and says made in Canada.
Part# SCI530005.
I searched and seems others have commented the stock filer should be pre-oiled paper.
Appraciated those who have replace their USDM STi with OE filter
let me know whether you have also got a dry element filter.
Thanks in advance.
2dino
2dino is offline   Reply With Quote
Old 04-08-2004, 04:23 PM   #2
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
16546AA020 is the part number, same as WRX.
SCI#### is a Subaru Canada number.
ANZAC_1915 is offline   Reply With Quote
Old 04-08-2004, 10:35 PM   #3
2dino
Member#: 41907
Thanks Glen,
I would be wary to use it if OE is wet paper (oiled).
Seems another trip is needed to find out whether there are 2 kinds of STi/WRX air filter form the dealer.
Cheers & have a happy Easter.
2dino.
Old 04-08-2004, 11:02 PM   #4
ADR 04STi
Member#: 51918
2015 Audi S3
Daytona Gray
Impreza WRX STi
2Dino: I replaced my stock filter. ..I thought it would say "STI" on it. . .it didnt. Has a part #16546 AA020. I wonder why it differs from the advertised pix I see????
ADR
ADR 04STi is offline   Reply With Quote
Old 04-08-2004, 11:18 PM   #5
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
You are probably looking at the pix of the aftermarket STI filter.
The stock filter is a dry paper element, I think. Perfectly fine for most uses. OE air filters are usually pretty good.
Glenn
Old 04-09-2004, 12:30 AM   #6
2dino
Member#: 41907
Thks, ADR.
The filter I have gotten is dry white paper with black rubber frame & metal mesh on top. Subaru Canada # only. Seems a Canadian contractor supplied OEM item.
Glen - thanks for letting me know OE filter is dry element. I have no problem with OE filter. Just a little surprised as I was expecting oiled one. And I cannot remember last time I saw an OE engine air filter with white paper element.
Cheers all again from Toronto.
2dino
Old 04-09-2004, 01:30 AM   #7
ADR 04STi
Member#: 51918
2015 Audi S3
Daytona Gray
2dino: Mine is RED paper....slightly oiled. Pleated. No mesh. Pleats are running width to width and black rubber frame.
Hey . .. I want the better STi fllormats from Canada. Any help?
ADR
Old 04-10-2004, 12:01 PM   #8
2dino
Member#: 41907
Hi ADR,
Thansk for the further information.
I check my original this morning. It is same as your description - red pleated paper element with black rubber frame and without mesh. I also feel it is oiled but hard to tell on a 16000km old filter.
Think I'll check further befroe I put the snow white Canadian dry filter in.
As of floor mat.
Are you looking for the carpet or the rubber matt?
The blue footwell carpets with STi logo that came with my car are very very flimsy. Their colour does match that of the molded carpet though.
The rubber matt I got are the WRX ones.
Tell me what you are lookng for and I''ll check the price out for you next week.
2dino.
Old 04-10-2004, 02:21 PM   #9
ADR 04STi
Member#: 51918
2015 Audi S3
Daytona Gray
Impreza WRX STi
2dino : I want the carpeted ones . . . .with STi logo. From what ive read in here YOURS are supposed to be better quality then the USA ones. I like rubber for easy cleanup .. .they stay put.
The carpeted ones will add the final touch.. .. . is there 2 for the rear as well?
ps: You should consider a PERRIN panel filter .. .. .im using one right now. Thanx for the feedback. . .. .time to go spool up.
Thanx ADR
Old 04-13-2004, 02:20 PM   #10
2dino
Member#: 41907
Hi ADR,
Checked again daytime and realized I made a bobo:
the carpet matt in Canadian STi are black, not blue in colour with pink colour STi emb. on front matts.
Anyway. Cost is around CAN $118 from dealers here (so about USD80).
They could ship directly to you in the states.
You may try to check each dealers at:
http://www.mississauga.subarudealer.ca/
and
http://www.trento.subarudealer.ca/
and
http://www.attrell.subarudealer.ca/
Let me knwo if need further info.
Cheers.
2dino
Old 04-25-2004, 05:09 PM   #11
essogas
Member#: 35703
2004 WRX STi
Blue/British Black 18's
so what air filter did you end up using? My STi replacement is also white and same part number 16546 AA020. But the original filter is red. Should I use this one?
essogas is offline   Reply With Quote
Old 04-25-2004, 11:25 PM   #12
Porter
Member#: 486
2004 Forester XT
bug spattered
I have to disagree with Glenn here...
Stock filters (replacement) for all MAF airbox type Subarus (STi, WRX, early Forester, Impreza, Legacy, SVX) are the AA020 part number and ARE oiled. The element is either a yellowish color or a pinkish red depending on production date, there is no difference between them other than color.
Porter is offline   Reply With Quote
Old 04-25-2004, 11:30 PM   #13
essogas
Member#: 35703
2004 WRX STi
Porter, thanks alot! Mine is the yellowish one and it is oiled a bit. I also thought that the difference was just production date.
OEM air filter for STi? Part #? Options? oversteer Service & Maintenance 9 08-01-2008 01:22 PM
Cobb intake+blitz power SUS Air filter for STi/WRX 305wrxPIMP Engine/Power/Exhaust 2 04-07-2007 10:13 AM
Is this correct for Boost ? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-15-2003 11:50 PM
K&N air filter for H6 3.0 engine Heather Legacy Forum 3 05-06-2002 04:49 PM
How bad is water leaking through air filter for engine? IMPBOY Normally Aspirated Powertrain 7 10-27-2000 06:51 AM
