Old 04-08-2004, 05:22 PM   #1
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
Default NEED vf22 map ASAP
im getting my car dynod on the 18th, so i need a safe map to get down to PA with.
i know i shouldnt use someone elses map but using the stock stg4 (vf30) map isnt the right answer either. i have to drive 250 miles to PA to get dyno tuned. my car is running fine w/ the safc but i dont want to uninstall it and install the utec the day of my dyno tune. i wanted to throw this utec in and limp down there w/ a vf22 map. so anyhelp would be appreciated. i know davenow has a map for 309whp which wouldnt help me
heres my mods;
vf22
sti injectors
denso fp
perrin fuel rails
bpm gt turbo back de-catted
helix uppipe
helix headers
unorthodox UD pulley
injen cai
stock IC
samco ic hoses
samco turbo inlet
utec w/ no map!
avc-r
wrxtremeWGN is offline   Reply With Quote
Old 04-08-2004, 06:45 PM   #2
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Default Re: NEED vf22 map ASAP
Why not? Just use that, turn the boost down, and you'll be fine in the interim. There really isn't THAT big of a difference between all the IHI turbos. The important thing, it seems to me, is to have low/moderate boost, a useable fuel map, and conservative timing until you put it on the dyno.
Joel
Zola is offline   Reply With Quote
Old 04-08-2004, 08:18 PM   #3
03WRXMA
Member#: 35081
2012 WRX
I have one you can use at your own risk, PM me if youd like it.
But keep the ABC closed, and stay out of boost!
03WRXMA is offline   Reply With Quote
Old 04-12-2004, 05:46 PM   #4
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
bump, ne1 else?
Old 04-12-2004, 07:05 PM   #5
Division By Zero
Member#: 7555
Why not? Just load the stage 4 map and you'll be set. It's not like you're going to be racing folks on the way there Seriously, the stage 4 map will be fine as long as you're not going crazy with it.
Division By Zero is offline   Reply With Quote
Old 04-13-2004, 02:42 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I ran the 'off the shelf' stage 4 map with my TD05 and it was pretty good overall, really....not perfect, but much better than I thought it would be.
need utec map asap!! gotawd UTEC 3 03-18-2006 06:06 PM
sti vf22 map needed to get me running moorebl Engine Management & Tuning 7 01-17-2005 12:33 PM
vf22 map needed with sti injectors please moorebl Engine Management & Tuning 4 12-04-2004 12:10 PM
need vf22 utec map plus fmic moorebl Engine Management & Tuning 0 11-27-2004 12:39 AM
Need Utec Map 740cc Vf22 catless EJ205rulezall Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 01-12-2004 08:01 PM
