Old 04-08-2004, 05:51 PM   #1
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Unhappy Help - Prodrive UK300 lights (aiming revisted)
Some of you may recall, a month or so ago I posted a thread with some pics of my lights with HIDs. It was then that I found out my beam was off. Here's the thread if you don't recall:
http://forums.nasioc.com/forums/show...light=prodrive
Anyways, I left off that thread assuming that tweaking the LHD/RHD slots were going to be the cure, but low and behold it did not. Basically right now, my beam pattern looks like this:
They should look like this __/ __/
Right now, they are in the RHD position
When I repositioned them to the LHD position, my beams looked like this \__ \__
So the only thing I can think of is that somehow my H7 capsules were not installed straight onto the headlight mold. I've seen pics of other Prodrive light owners and they all have the proper beam pattern. I'm just miffed at why mine are off like that. The only thing I can think of is somehow rotating the capsule slightly counterclockwise as that will make things look right. Anybody else have any suggestions?
Hank3 is offline   Reply With Quote
Old 04-08-2004, 06:24 PM   #2
xstar
Member#: 10821
2008 WRB STi
My old headlights looked like that before. (the slight V-ish look) I just aimed my low beams wrong. Another hour of aiming got it looking like __/ __/ again...
But this was a year ago.
good luck!
xstar is offline   Reply With Quote
Old 04-08-2004, 06:27 PM   #3
rossscarbro
Member#: 34627
2006 Evo IX GSR
Graphite Grey
I hate to hijack this thread, but since we have a few of you UK300 owners here...
I desperately need a UK300 carbon fiber pattern headlight...driver's side only. I've tried Vivid, Prodrive, Aerosim... I'm getting nowhere. Can anyone help??
rossscarbro is offline   Reply With Quote
Old 04-08-2004, 06:45 PM   #4
Golfa
Member#: 21394
Sold 2004 STi
08 WW Evo X
get EDM's
Golfa is offline   Reply With Quote
Old 04-08-2004, 11:31 PM   #5
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Originally posted by Future Rex 0wner
get EDM's
Sorry but the beam pattern and output are superior in the UK300's over the EDM STi's.
Hank - interesting dilemma you have there. Can you possibly adjust the slotted portion of the housing adjustment somewhere in the middle? Or does it have to lock up to one end or the other? They are both pretty even in alignment so i wonder if the bulbs are fine. I can't imagine you would misalign the bulbs so perfectly on both sides. Know what I mean?
but that is your beam pattern in right hand drive mode? strange. I'll take a pic of mine with left hand drive mode and see if we can compare.
gotta wait till its dark.
Arnie is offline   Reply With Quote
Old 04-09-2004, 12:16 AM   #6
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Hank, reading your other thread i was thining you might have gotten an early UK300 lamp that was actually still set up for the UK! The later kits were then adjusted for left hand drive.
Old 04-09-2004, 12:16 AM   #7
Hank3
Member#: 16157
'03 Mazda P5 <><
xstar - hmmm, I don't see how adjusting the aiming screws would rotate the entire beam counterclockwise
But I guess if it worked for you, that's great
Arnie - thanks for chiming in. Yes it is quite a dilemma I have and trust me when I say that I've literally spent hours trying different things and nothing is working for me...which leads me to believe that mine were assembled incorreclty somehow. Please let me know if and when you find out more about your setup...
Old 04-09-2004, 12:18 AM   #8
Hank3
Member#: 16157
'03 Mazda P5 <><
Well even if mine were setup for the UK, shouldn't my horizontal line actually be horizontal instead of diagonally down and then etched up? Know what I mean?
Old 04-09-2004, 12:46 AM   #9
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
inter/w Spec C roof vent
Mine are running \___ \___..They are a pita to aim..
Anybody have a aim harness hooked up?
enewtabie is offline   Reply With Quote
Old 04-09-2004, 01:05 AM   #10
Hank3
Member#: 16157
'03 Mazda P5 <><
Do you know if your lights are set in the LHD or RHD position? I've actually got the aiming down to a science since I have tooled with these lights so much in the past couple months!!!
Old 04-09-2004, 01:08 AM   #11
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Default god my camera sucks
yes, you're probably right, regardless, the line should be horizontal. Mine are.
Old 04-09-2004, 01:14 AM   #12
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
enewtabie is based in the UK I think. His lights better aim \__\__ .
Old 04-09-2004, 01:21 AM   #13
Hank3
Member#: 16157
'03 Mazda P5 <><
Thanks for the pic Arnie - more validation that something is wrong with mine. So in that pic, do you know if your lights are in the RHD or LHD slot?
Old 04-09-2004, 02:01 AM   #14
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Hank, take a look at the high beam lamp housing. It has 3 alignment adjusting screws. Do the low beams also have three? I felt, when messing with these once on the highbeams, one sort of moved the light diagonally and messed a bit with the rotation of the light.
Old 04-09-2004, 02:03 AM   #15
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
those should be in the left hand drive slot, though I have not taken apart my light to confirm. this is the usual e-code pattern for left hand drive. My old car in Germany had the same kick up to the right.
Though i seem to remember, when aligning my EDM STi's I got them to be kind of **** eyed like yours. Though I can't remember if it was the horizontal or vertical aiming screw. If the screws weren't such a pain to get to you could just twist to your heart's desire.
Old 04-09-2004, 02:08 AM   #16
Hank3
Member#: 16157
'03 Mazda P5 <><
The low beam only has two aiming screws as opposed to the three for the high beams. Is that a pic of your lights taken from the back? If it is, it's in the RHD position from what it seems like. There could be a chance that the pic I posted of the back of the light is incorrect of the LHD/RHD orientation?
Old 04-09-2004, 02:16 AM   #17
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Yes, this is the back of my light, driver's side, left hand drive.
Old 04-09-2004, 02:31 AM   #18
Hank3
Member#: 16157
'03 Mazda P5 <><
Hmmm - very interesting then because your driver's side light is setup in the RHD slots if we basing it with the pic I posted of the back of the light module. So there's something obviously miscaliberated with my lights - at least that's the only thing left to consider. Coz the back of my lights are set up like yours and you can obviously see the variation of my beam pattern against yours. I guess I'll either have to live with it or research more. Really noit a big issue, but it would be nice to figure out why mine are off
Old 04-09-2004, 03:02 AM   #19
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Hank, where did you get the info that indicate which slot orientation is right and left and hand drive?
Old 04-09-2004, 03:07 AM   #20
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
I dunno, all I can advise is to try playing again with your alignment screws. Just play with one of them and see what its full range of motion is and then the other and see what it does. Perhaps somewhere there the horizontal lines actually get horizontal. then follow daniel sterns alignment guide.
Old 04-09-2004, 08:59 AM   #21
enewtabie
Member#: 18928
2002 jdm wrx v7/v8
LHD..came off one of Lovells old cars
I want to get the leveling harness wired..I assume its 4 wire
Old 04-09-2004, 09:44 AM   #22
Hank3
Member#: 16157
'03 Mazda P5 <><
Got it from here Arnie:
http://faq.auto.light.tripod.com/hella-90mm/
A very informative site about our Hella 90mm H7 capsules.
Of course I would have to retract that statement somewhat if indeed the LHD/RHD info is wrong
Old 04-09-2004, 11:16 AM   #23
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
Actually the low beam does have three adjusting screws. The third on is the one with the leveling motor on it. You just have to hook it up.
I also just got these lights, and will be installing them in a while. I just donít like the way itís all hooked up. So, I am going to rewire the whole thing. Does anybody know what that heatsink thing is at the top of the lights?
Thanks
Shane
PARANOID56 is online now   Reply With Quote
Old 04-09-2004, 11:35 AM   #24
Hank3
Member#: 16157
'03 Mazda P5 <><
So unless you have the leveling motor, the third adjusting screw is not there. The back of mine and Arnie's look the same - there's no third adjusting screw that I can see
Old 04-09-2004, 11:42 AM   #25
PARANOID56
Member#: 22035
2003 Brocoma DCab
arnies pic above of the rear of his light does have the leveling motor on it. its the moter looking thing above the low beam. you can adjust it, but its a PITA.
Shane
Prodrive/UK300 light owners: Help needed Hank3 Electrical & Lighting 51 02-16-2005 09:36 PM
anyone know where to have UK300 lights aimed properly? SLowery Southern California Impreza Club Forum -- SCIC 14 11-27-2002 03:37 PM
FS: Prodrive UK300 lights. Local to STL only! RacerinLSL Mid West Subaru Owners Club Forum -- MWSOC 9 06-03-2002 04:49 PM
Installed my Prodrive-UK300 lights! RacerinLSL Interior & Exterior Modification 6 05-21-2002 06:04 PM
check out my prodrive uk300 lights christoph1371 Interior & Exterior Modification 6 12-15-2001 05:52 PM
