Old 04-08-2004, 06:47 PM   #1
yeravgjoe
Member#: 54616
1994 Impreza
Default Fuel/Gas Gauge is Dead!
I have a 1994 Impreza L AWD/AT/AC with 131,000 miles. I've recently completed a 500 mile mud&snow TSD rally in British Columbia on very bumpy ice covered logging roads.
Roughly 600 miles after I completed the Rally, my gas gauge started behaving erratically. If the tank is filled to 3/4-1/1 full, the gauge will intermittently display either the correct reading or 0/1. If I drive 50-75 miles (roughly 1/4 of the tank used) then the gauge goes completely dead.
I've checked all my fuses in the fuse box under the hood, and none are blown. The car's driving behavior hasn't changed any, no new rattles or squeaks - just the gas gauge seems affected.
What should I try next in terms of trouble shooting?
Any help you can provide would be greatly appreciated!
Thanks,
Steve
Seattle, WA
94 1.8L/AWD/AT/AC/131k/White
[url=http://www.geocities.com/yeravgjoe2002/94Impreza_TBird.jpg]
yeravgjoe is offline   Reply With Quote
Old 04-08-2004, 07:03 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Most likely the level sender in the tank is shot.
Old 04-09-2004, 12:16 PM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
from the jerkiness and acting strangly I would also say to check the level sender in the tank...
Fuel smell, followed by pretty nice fuel leak, followed by car is dead sk8er722 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-17-2008 10:38 AM
04 STi: cluster gauge is dead... fuses? ldivinag Service & Maintenance 8 06-20-2007 02:19 PM
Fuel sensor/gauge is off - quick consumption - bad ground/electrical? Siper2 Electrical & Lighting 2 09-14-2005 08:32 PM
Your gas gauge is stuck what now? Starscream Off-Topic 6 03-18-2005 01:19 PM
Can anyone think of any situation where a mechanical fuel pressure gauge is best? Drew888 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-12-2004 04:33 PM
