Welcome to the North American Subaru Impreza Owners Club Saturday February 13, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 10-12-2004, 05:42 PM   #1
STi_Drift
Member#: 25759
99 impreza
rally blue
Default Hydra Nemesis knock count?
Does anyone know what the definitive hard number that would represent detonation on the Hydra?
I realize every engine is different and have mine tuned now, but would like to get some insight to what you guys are doing. I was hoping Phil @ element may have an answer?
Anyways my setup is a ej22t with 2.5 SOHC heads, TMIC Vf turbo etc.
Many thanks in advance for the replies
STi_Drift is offline   Reply With Quote
Old 10-12-2004, 08:04 PM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Because the knock thresholds and amplification are adjustable there is no definitive number that equals knock. Like you stated, because every engine is different, and because some model years use different sensors, the knock thresholds will vary to some extent.
I suggest that you be conservative with your knock thresholds by allowing normal noise to closely approach the threshold. The best way to determine normal noise would be to use a knock listening device which is what I use. The other option is to reduce boost, cut timing, and richen up the AFR some and take note of the noise level using either your data logger or the trace "Xs" in your knock threshold map.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 10-13-2004, 12:49 PM   #3
STi_Drift
Member#: 25759
99 impreza
rally blue
So then if one had actually traced the x's and made the threshold accordingly is it normal to see a variance or two that spike up above the threshold off boost? This happens pretty much every drive.
Thanks for your help Phil! ^^
Old 10-13-2004, 03:06 PM   #4
Element Tuning
Member#: 54918
673 WHP Element
Normal noise, maybe. Knock, maybe. Not what you wanted to hear I bet. You may want to turn of the amplification and alter the thresholds accordingly to see if itís just a sensitivity issue. The only true way to know is with a knock headset.
Phil
knock count = 17, knock count = 4 no UTEC timing, no load!!! K2Skier Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-03-2005 09:32 PM
Hydra Nemesis password? HELP!! Pi7467mp Other Engine Management 2 11-13-2004 03:41 PM
Hydra Nemesis 2.0 NeaD Other Engine Management 426 10-20-2004 10:55 AM
Need help developing PNP HYDRA Nemesis 2.0 ecu for 99-02 2.5RS HydraEMS-NA Other Engine Management 1 02-17-2004 12:40 PM
hydra nemesis ecu audioize Other Engine Management 7 02-09-2004 12:35 PM
