Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 08-10-2004, 04:18 PM   #301
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
ok.. this is weird. I start it up today and it idles. I still have to give it a little gas to get it started though. I'm about to host this log I hook while testing for idle.
NeaD is offline   Reply With Quote
Old 08-10-2004, 04:24 PM   #302
NeaD
Member#: 43371
Hydra User, Blue
http://www.inactivity.org/jon/Data/idle.htm
I can tell by the AFR im running lean when idling, the fuel pulse is wayy too much. well.. at least I can start tuning now. BTW.. i still have my stock injectors in right now till i get my emissions done.
Old 08-10-2004, 04:26 PM   #303
STi_Drift
Member#: 25759
99 impreza
rally blue
this may be a dumb question, but did you scale the map for your size of injectors?
STi_Drift is offline   Reply With Quote
Old 08-10-2004, 08:00 PM   #304
NeaD
Member#: 43371
Hydra User, Blue
yes.
Old 08-11-2004, 02:01 AM   #305
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
have you tried adjusting the cranking enrichment trim?
HOK is offline   Reply With Quote
Old 08-11-2004, 03:46 AM   #306
NeaD
Member#: 43371
Hydra User, Blue
nope.. but I got a few runs in using the wide band. It works pretty good.
Old 08-11-2004, 12:09 PM   #307
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
so everything is working ?
Old 08-11-2004, 01:41 PM   #308
NeaD
Member#: 43371
Hydra User, Blue
yep. We are going to tune a lot more tonight.
Old 08-11-2004, 05:57 PM   #309
STi_Drift
Member#: 25759
99 impreza
rally blue
what is your cranking enrichment trim?? mine takes too many cranks before it fires, so its prolly too rich?
Old 08-13-2004, 08:51 AM   #310
Eraz3r
Member#: 25446
2005 Nissan 350z
silverstone
Two monkeys and a banana for Element Phil... my hydra arrives today!
Eraz3r is offline   Reply With Quote
Old 08-13-2004, 03:23 PM   #311
NeaD
Member#: 43371
Hydra User, Blue
Yeah.. I wanna know also.
Old 08-15-2004, 05:23 AM   #312
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
sorry missed this... I tried adjusting the cranking enrichment but it did not improve the delay in cranking.. it still takes me 4 cranks. I have no idea what it is i don't have the latop with me.. but it still does not act stock even after adjustment...
Old 08-15-2004, 11:40 AM   #313
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
This is a known thing with the hydra - its not batch fire on start like the stock ECU, its still direct fire. It take about 2-3 seconds to start the car, and that will never be any different until the firmware update Hydra is planning in the future that will allow batch fire at startup and immediately switch over to direct fire.
DarthChicken is offline   Reply With Quote
Old 08-15-2004, 07:07 PM   #314
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Thanks... I was thinking it was the ECU but didn;t know exactly what it was.. any thoughts on effects on the starter?
Old 08-15-2004, 07:43 PM   #315
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
That is has to crank a few more cycles? I doubt it will have any affect at all (batch fire ignition is fairly new in the real world, probably the last 20 years or so)... I was more concerned about my battery than anything. Also, if you think about it, you're actually building some oil pressure before the car starts, so in that regard its probably good for the engine
Old 08-15-2004, 10:18 PM   #316
NeaD
Member#: 43371
Hydra User, Blue
Is anyone with the stock rs engine running the hydra? I want to compare maps.
Old 08-16-2004, 11:15 AM   #317
STi_Drift
Member#: 25759
99 impreza
rally blue
Anyone had issues with a incorrect wideband reading? Mine is at perfect AFs, but the plugs are white, meaning lean
Old 08-16-2004, 02:54 PM   #318
NeaD
Member#: 43371
Hydra User, Blue
I was told that some of the 02 sensors in the wideband were not reading right and not to use it as of yet, by andrew. He said he is working on it and to wait till the new software comes out or something.. I can't remember what he said about how he was fixing it. He just told me to hold off on using it for a bit.
Old 08-16-2004, 05:21 PM   #319
STi_Drift
Member#: 25759
99 impreza
rally blue
He said it was the guage of wire not giving enough current. But i cant see it being the main problem.... How are ou tuning without the wideband?
Old 08-16-2004, 06:52 PM   #320
masiolli
Member#: 35840
1999 Blue RS-t
22t & Hydra
alright, i have a few questions...
i finally got my car running again (on the stock computer) after i got it running.. i called andrew to trouble shoot the Hydra... We went though EVERYTHING... and it wouldnt start my car.. so i sent it back, he tested the harness and the ECM.. and everything worked fine.. does anyone have any ideas what could be wrong? The only thing we didnt check was the air temp sensor...
it mounts between the turbo and filter right? and it plugs into the harness on the big plug, middle row, second from the right? (#10 on B134)
masiolli is offline   Reply With Quote
Old 08-17-2004, 02:43 AM   #321
STi_Drift
Member#: 25759
99 impreza
rally blue
It can't be the air temp sensor. I started mine regardless if it was installed or not. Does it crank and start and die or not start at all?
Are you sure you played with the settings properly? There are a lot of things that Andrew can't tell from being long distance. Anyways not sure what it is but if you list your prob in detail mebbe we can help I know it took me FOREVER to get mine running cuz I have almost every problem you can possibly fathom
Old 08-17-2004, 04:38 AM   #322
NeaD
Member#: 43371
Hydra User, Blue
I'm still using the wideband.
edit: I really wish someone would send there map to me to so I could compare it. (btw.. on the stock motor)
Old 08-17-2004, 05:19 PM   #323
masiolli
Member#: 35840
1999 Blue RS-t
22t & Hydra
it just wont fire up.... it turns over but never starts... it will on the stock ECU however... but since its running so rich.. it kills my plugs every 5-10 min.. haha.. he said he tested every wire on the harness and it was right... then he put the hydra in his rsx... and it ran it... so he said he has no idea what it could be... im supposed to get it back today.. and if it doesnt start, he said he'll give me a full refund...
and is all that about the air temp sensor correct? mounting location, and the place it plugs into the harness?
Old 08-17-2004, 05:34 PM   #324
NeaD
Member#: 43371
Hydra User, Blue
My car still runs with my air temp sensor not hooked up to anything.
Old 08-17-2004, 06:58 PM   #325
STi_Drift
Member#: 25759
99 impreza
rally blue
Dood. The air temp sensor hook up sounds ok, seriously i don't think it matters because it works off a long term average. mine is on the TMIC, but don't worry about that now. your car won't start because it sounds like its rich if its killing your plugs in 5 minutes. Reduce AF on the idle portion of the map and then reduce some of your cranking enrichment trim. Your post start up map should be ok, but all you gotta do is basically start playing with settings and methodically test each variable to see if it makes a difference
Make sure that your stepper motor settings are right as well. I know my car dies right away if those are not set properly. i.e play with extreme values to test them. Mainly your Max vacc setting in the ISC tab under settings.
FS: $420 SHIPPEDD !!Hydra Nemesis 2.0 with 2.14 2002-2005 WRX. Stand Alone ECU OBO! kokopuffs405 Engine/Power/Exhaust 18 12-10-2009 11:19 AM
FS: Hydra Nemesis 2.0 with 2.14 software for a 2002-2005 WRX. Stand Alone ECU OBO! kokopuffs405 MAIC Private Classifieds 17 12-10-2009 11:19 AM
Hydra/Nemesis 2.17r1 help for a n00b swilson Other Engine Management 24 01-22-2006 12:16 PM
Hydra Nemesis 2.0? NorCal11.7 Other Engine Management 5 11-23-2004 07:17 PM
Need help developing PNP HYDRA Nemesis 2.0 ecu for 99-02 2.5RS HydraEMS-NA Other Engine Management 1 02-17-2004 11:40 AM
Message Board Statistics All times are GMT -4. The time now is 03:53 PM.
