Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 06-28-2004, 06:01 PM   #176
masiolli
Member#: 35840
1999 Blue RS-t
22t & Hydra
what is TB calibration?
masiolli is offline   Reply With Quote
Old 06-28-2004, 09:30 PM   #177
SubaFastR
Member#: 5786
adjusting the open and closed positions of the throttle body
SubaFastR is offline   Reply With Quote
Old 06-28-2004, 09:33 PM   #178
masiolli
Member#: 35840
1999 Blue RS-t
22t & Hydra
why would i need to do that? it runs fine with the stock ECU...
or is this a software calibration for the Hydra?
Old 06-28-2004, 09:34 PM   #179
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
You have to do that with every aftermarket ECU - its part of the standard setup process.
-Charlie
phattyduck is offline   Reply With Quote
Old 06-28-2004, 09:39 PM   #180
SubaFastR
Member#: 5786
I totally hated that Hydra crap. I had to retune it on my way to work and then on my way home. Temp correction doesn't work well, and yes I know my sensor was working because Andrew Nam and I hooked it up in his garage. Tuning is a major pain in the ass due to only being able to change one cell at a time. My first harness was full of bugs and the car would hardly run after picking it up from Andrew's house, 10 miles down the road. He blamed my car's harness. After I showed him the pins in his harness were not sticking out, he finally made me a new harness. I had a Link Plus before this and never had any tuning issues. I loved that thing. I only changed over because I wanted AVCS heads. Huge mistake. F it, I'm doing a swap on my car and having I Speed reflash my ecu when I put my STi block and turbo in. I pick up my motor tomorrow.
Old 06-28-2004, 10:15 PM   #181
masiolli
Member#: 35840
1999 Blue RS-t
22t & Hydra
-Charlie
would that be the menu in the Hydra software select/settings/throttle and at the bottom it says TPS CAL Calibrate zero Calibrate WOT?
Old 06-28-2004, 10:18 PM   #182
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
yes... turn the car to ignition but don't turn it on. don't touch the throttle and press calibrate zero then press fully on the pedal and press calibrate WOT...
HOK is offline   Reply With Quote
Old 06-28-2004, 10:19 PM   #183
masiolli
Member#: 35840
1999 Blue RS-t
22t & Hydra
then it should start?
Old 06-29-2004, 02:28 AM   #184
SubaFastR
Member#: 5786
Can't say. Check the harness to see if all of the pins come out far enough. Mine were hit and miss. Andrew is actually rather famous for building bad harness'. The guys at Link USA groaned when I said he built my Link harness.
Old 06-30-2004, 12:05 AM   #185
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Well i got it running and took a drive... the base map was very good. I was shocked.. Didn't think it would that good. I have logs .5 meg let me know if any of you want it...
didn't go on boost... as I was still trying to get the mechanical things worked out... but drove around for about 45 minutes, and washed the car. idles rock solid but I do stall now and then... need to work that out...
Old 06-30-2004, 01:05 AM   #186
bboy
Member#: 56468
04 Improved STI
Dirty White
HOK
I'm glad to hear that. Keep us posted.
SubaFastR
Contact Phil he was telling me there was new software that permitted changing more than one cell at a time. I couldn't even change one until he told me how. I'm just playing around though no tuning for me yet.
Old 06-30-2004, 01:21 AM   #187
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
whats this new software?
you can actually change an entire row of cells but only to one value.
The interaction isn't that great i agree... but the things you can do... sheesh..
Old 06-30-2004, 03:44 PM   #188
STi_Drift
Member#: 25759
99 impreza
rally blue
dammit! I am still waiting its been almost 2 months now! Damn Delphi and their connectors on backorder.
STi_Drift is offline   Reply With Quote
Old 07-01-2004, 11:38 AM   #189
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Spent the night till 2 am tuning.. fun fun fun...
Got most of the drivability problems out of the map... ride is good with no more stalling or stumbling. did a short 10 psi run on the new turbo... need to richen that sucker up hehe.
When you get used to the interface the usibility is not as bad as it seemed to me at first, because i was doing small and fine tuning changes... I would imagine if you needed to build a large portion of the map it would be a big PITA. I work in the IS industry and the words they use for download and upload really got me annoyed.. lol
But I have two recommendations, save every single map when you change a variable in settings. every time i changed the values in settings and uploaded to the ecu (download in thier language) the car shuts off and then i have to restart and download from the ecu.
I refuse to change multiple variables when i tune... it takes me more time, but I have a lot at stake and want to make doubly sure.
Also I have noticed that the stock knock sensor is useless. the knock threshold that i had to get it down to was so much I think I might as well turn off knock retard. Either something is wrong with my sensor or my tuning is so good it doesn;t even come close to knock.. yes i agree there is something wrong with the sensor. there was hardly any change registering on the knock map.
I have to say it: that manual sucks... big time
Old 07-01-2004, 03:42 PM   #190
Section 8
Member#: 821
Can you give us a quick instruction set to get the map off of the ECU when it arrives and saved to the computer with their backwards, ECU is the center of the universe, jargon so we don't lose it immediatly by following convention?
Thank you,
Greg
Section 8 is offline   Reply With Quote
Old 07-01-2004, 08:39 PM   #191
SubaFastR
Member#: 5786
It is actually intuitive. Your laptop is physically above the ecu. You download to the ecu when you store and upload from the ecu when you begin.
Old 07-01-2004, 10:19 PM   #192
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Intuitive is relative to your experiences and manner of working and thinking. Generally most would think of an upload as coming from the terminal (i.e. the i/o tool you are working from, in this case a laptop) and a download going to the terminal.
turboICE is offline   Reply With Quote
Old 07-01-2004, 10:45 PM   #193
Jon [in CT]
Member#: 2992
02 WRX Sedan
Everything is relative to one's point of view and SubaFastR has offered a simple and effective "point of view" to use when dealing with the documentation associated with this ECU. Why does anyone consider this to be a problem? ECU's predate the internet and just maybe Microsoft got it's terminology wrong (for the first time?).
Jon [in CT] is offline   Reply With Quote
Old 07-01-2004, 11:03 PM   #194
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
I agree I don't see why it would be a problem as long as it is consistent and made somewhat clear in the terms' first usage. I would hope that the context in which the terms are first used would at least leave it clear which way the data should be flowing. But upload and download predate the internet and Microsoft.
Old 07-02-2004, 02:53 AM   #195
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
If you have seen the software the buttons say "upload from" and "download to". The terms are incorrect. and welcome to 2004. jeez. sometimes this board I tell you.
Those term are wrong even in 1978. They are upload to ( a smaller medium to a larger medium) and download from (a cargo plane). I think the terms by now should be understood.
anyways... I've been thinking whether or not to write some sort of document for this thing... but i'm beginning to have reservations.
Old 07-02-2004, 10:12 AM   #196
Eraz3r
Member#: 25446
2005 Nissan 350z
silverstone
www.dictionary.com
Upload: to send data to a central server
Download: to get data from a central server
Being that the lap top in the case of the ecu would be the "central server" you would be downloading the map to the ecu.
despite all that, i have to agree... being an IS dork myself i tend to use the term Upload because i think of sending any data outside my workstation regardless of the various mediums as an upload, even if its not technically correct by the dictionary... all my geek friends understand. lol
Eraz3r is offline   Reply With Quote
Old 07-02-2004, 12:29 PM   #197
CK02WRX
Member#: 27859
2002 EJ257 w/CP's
8cmFP Red, RA 5spd, Hydra
Smile
Maybe it's some strange Canadian dialect.
CK02WRX is offline   Reply With Quote
Old 07-02-2004, 12:48 PM   #198
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
It's not a problem, it's nitpicking...an activity with which you ought to be intimately familiar.
So the Aussies who put it together screwed up their terminology, who cares? It's not as though it's a huge stumbling block to actually using the UTEC.
By the way, I agree about the woefully substandard manual. Of course they have other things that keep them busy but there is something to be said for spending a bit of money to hire a technical writer who produces documentation for a living.
Zola is offline   Reply With Quote
Old 07-02-2004, 01:12 PM   #199
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
Question
I have a question about the datalogs. What format(s) can you save the datalogs in? Is there an option to save it as a simple tab delimited text file?
Thanks,
- Steve
zzyzx is offline   Reply With Quote
Old 07-02-2004, 03:02 PM   #200
SubaFastR
Member#: 5786
The ecu is designed by a Chinese man and Singaporean. They have it made in Asia somewhere. No Aussies were used...since we are having so much fun nitpicking here
FS: $420 SHIPPEDD !!Hydra Nemesis 2.0 with 2.14 2002-2005 WRX. Stand Alone ECU OBO! kokopuffs405 Engine/Power/Exhaust 18 12-10-2009 11:19 AM
FS: Hydra Nemesis 2.0 with 2.14 software for a 2002-2005 WRX. Stand Alone ECU OBO! kokopuffs405 MAIC Private Classifieds 17 12-10-2009 11:19 AM
Hydra/Nemesis 2.17r1 help for a n00b swilson Other Engine Management 24 01-22-2006 12:16 PM
Hydra Nemesis 2.0? NorCal11.7 Other Engine Management 5 11-23-2004 07:17 PM
Need help developing PNP HYDRA Nemesis 2.0 ecu for 99-02 2.5RS HydraEMS-NA Other Engine Management 1 02-17-2004 11:40 AM
