Old 04-08-2004, 08:15 PM   #1
Alpha_32
Member#: 35876
2008 Legacy GT SpecB
Grey
Default EJ25's REAL rev limit?
i was just wondering how high a stock ej25 could rev to safely
Alpha_32 is offline   Reply With Quote
Old 04-08-2004, 08:26 PM   #2
2pt5RS
Member#: 10853
2013 BRZ LTD
Satin White Pearl
it safely revs to the redline, which is 6250.....
2pt5RS is offline   Reply With Quote
Old 04-08-2004, 08:27 PM   #3
Blindeye_03
Member#: 4418
2016 Focus ST
if you mean to valve float, its like 7000rpm, but good luck doing that with the rev limiter.
-justin
Blindeye_03 is offline   Reply With Quote
Old 04-08-2004, 08:40 PM   #4
Alpha_32
Member#: 35876
Grey
no chance of getting to 8?
Old 04-08-2004, 08:56 PM   #5
2pt5RS
Member#: 10853
2013 BRZ LTD
Satin White Pearl
unless you put a b18 motor in it, no
Old 04-08-2004, 08:58 PM   #6
Blindeye_03
Member#: 4418
2016 Focus ST
WHAT? why do you want it that high? Well, only if you had upgraded cams/valves/heads would you want to rev that high.
In stock form, the 2.5 runs out of breath around 6k rpms.
-justin
Old 04-08-2004, 09:20 PM   #7
b_tapper
Member#: 5291
'08 Scion xB
Nautical Blue Metallic
mine will go past that
b_tapper is offline   Reply With Quote
Old 04-08-2004, 09:36 PM   #8
2pt5RS
Member#: 10853
2013 BRZ LTD
Satin White Pearl
mine goes to all of 4500......gotta break in the new engine
Old 04-08-2004, 10:45 PM   #9
xxtwowheelfiendxx
Member#: 47597
1997 ///M3
'93 Impreza
you will not be making much power up past 6k, so theres really no point. You could rev to 12k if you wanted to but it would all be in vain unless you can continue to make power
Think outside of the box and shift.
xxtwowheelfiendxx is offline   Reply With Quote
Old 04-08-2004, 11:16 PM   #10
piker28
Member#: 22664
8k? hahahaha you ricer
piker28 is offline   Reply With Quote
Old 04-09-2004, 03:37 AM   #11
dcoty
Member#: 3149
01 V7 GC/R32 sky
I rev to 8k...and its a ton of fun!
If the redline were raised you would have no benefits really, your motor would run out of breath due to the stock grind of the cam, and you would soon get valve float.
As Blindeye said, you would need headwork, very agressive cams and new vale springs to rev that high, oh, and engine management (piggyback) to actually raise the redline.
B_tapper- What are you revving to latley?
Later!
Dan
dcoty is offline   Reply With Quote
Old 04-09-2004, 07:27 AM   #12
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
ommmjido is offline   Reply With Quote
Old 04-09-2004, 11:00 AM   #13
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Not only does the flow of the stock heads become an issue at 8000 rpm, but the intake manifold is a restriction. So, even with fully worked heads, you really see a major drop of in power around 7500. This is why Dan and his brother are working on a custom manifold, and others are working on ITB solutions for our cars.
And as has already been said, if we are talking totally stock heads, the valvetrain cannot handle even 7000rpm. Even at 7000rpm you will get float...
Old 04-09-2004, 09:52 PM   #14
obyone
Member#: 16523
Yeah...my tach says I have done 6500 easy.
BTW...Dcoty (IIRC) is working on a fully built N/A engine with a higher rev line. Last time I heard, he was having problems with the Enging managment switching off the stock limiter to the new one, but that was before he went stand alone managment.
obyone is offline   Reply With Quote
Old 04-09-2004, 10:43 PM   #15
Alpha_32
Member#: 35876
Grey
ok, but 7 is do-able?
it's just cool watching the needle go way past the redline
Old 04-09-2004, 10:48 PM   #16
piker28
Member#: 22664
i wouldnt do it the engine has a redline for a reason
Old 04-09-2004, 10:59 PM   #17
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
Is this really your reason?!?!
Why not just buy a tach and set the redline really low? Then you can watch it go way way past the redline, and it won't potentially cost you major repairs later.
nunyo is offline   Reply With Quote
Old 04-09-2004, 11:05 PM   #18
Alpha_32
Member#: 35876
Grey
well then there's no point in doing that because if you have a redline at like 5 or 4.5 then ur car sux
but reving to 7 + going past redline = cool;
Old 04-09-2004, 11:14 PM   #19
piker28
Member#: 22664
wow you know jack about cars
there are cars that rev to those and make a crap load more power than you
Old 04-09-2004, 11:25 PM   #20
Defiantguy
Member#: 41268
2015 WRX
jason I'd just stop posting on this thread before I have to start denying that I know you in real life.
Defiantguy is offline   Reply With Quote
Old 04-10-2004, 12:10 AM   #21
Machine Age Victim
Member#: 29961
2008 Honda Element
1975 Triumph Spitfire
a Bently Azure redlines at 4500, it's not very cool at all
Machine Age Victim is offline   Reply With Quote
Old 04-10-2004, 12:11 AM   #22
2pt5RS
Member#: 10853
2013 BRZ LTD
Satin White Pearl
Old 04-10-2004, 12:21 AM   #23
hvlwnc
Member#: 49127
2004 OBS
mud, pine needles, twigs
That is the funniest thing I've heard in a long time. I think it's my new sig.
hvlwnc is offline   Reply With Quote
Old 04-10-2004, 07:49 AM   #24
CheezeWeezle
Member#: 17187
2009 Braun Entervan
Gimpy White
Excuse me sir...but the hOnduh forums went that way
------------------------>ricer
CheezeWeezle is offline   Reply With Quote
Old 04-10-2004, 12:05 PM   #25
Alpha_32
Member#: 35876
Grey
ok, so 7 is safe?
07 stage 2, ecu limiting boost 8-7 psi after hitting rev limiter Varanont Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 09-26-2007 02:27 PM
Rev limiter crazy? car revs att 5k!! Stealth_RS Normally Aspirated Powertrain 14 04-13-2006 08:58 AM
rev limit, launch rev idea.... 80884 Proven Power Bragging 49 06-24-2004 08:29 PM
Car feels like it hits the rev limiter when it's not hitting the rev limiter Tainted Transmission (AT/MT) & Driveline 21 01-09-2002 12:21 PM
('93-'01) What kind of Rev limiter? Layman Impreza Forum 5 05-19-2001 12:27 AM
