Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-08-2004, 09:14 PM   #1
imposter
Member#: 10642
95 Impreza EJ22T
Default TD05 installed, now I have compressor surge
I finally got around to installing my new TD05-16G. Everythings hooked up right (i think) and Im running 9-10 psi. When I let off the throttle it sounds like a rally car; the bypass valve makes a fluttering noise. Its the stock bpv, and I know a few people here have a similar setup. Any ideas of whats causing this and how to fix it?
Thanks,
Jim
imposter is offline   Reply With Quote
Old 04-12-2004, 12:25 PM   #2
Unsung Boxer
Member#: 37196
i dont htink thats compressor surge, i believe that is simply a BOV flutter. its rather normal. I asusme your venting to ATM?
Also, there are many vehicles that run about 8psi w/o a diverter valve from the factory. So many of us suggest that it is semi-safe to run 8psi w/o a BOV at all.
Rember also that the WRX Diverter valve is desgined to recirculate. Are you getting a check engine light right now, and a rough idle? If so, its probably because the BOV is leaking at idle. If you can confirm this, than you need to "Crush" the bov.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 04-12-2004, 10:02 PM   #3
imposter
Member#: 10642
95 Impreza EJ22T
Well, the fluttering noise from the blow off valve is the audible part of compressor surge. You can read about it on the Go Fast Bits website, or the book Maximum Boost.
Im using the stock recirculating bypass valve of the legacy turbo, which is probably too small in the first place. Even at 8-10 psi, the TD05 can push alot more air than the stock VF11.
-Jim
Old 04-15-2004, 02:49 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
sooo where did you find the td05 ...
Old 04-23-2004, 02:57 PM   #5
Ishamiyal
Member#: 43682
2001 RS-T 2.5
When I installed my VF22 I thought the same thing. The turbo was SOOO much bigger and made such a diff sound, I thought I was getting compressor surge. I switched over to an HKS SSQ BOV at the same time and thought I was hearing what you think you are hearing.
If you have installed a larger IC as well (which I also did) there is a LOT more air under pressure- even if you are running the same general PSI. Your volume of air under pressure is greater, even though the pressure hasn't changed. The blow off takes longer and sounds different cuz there is simply more air. Think of it as 10 cubic feet of air at 15 PSI versus 1 cubic foot of air at 15 PSI. It's the same pressure, there is just more to blow off.
Dunno if that is your issue, but it sounds like it to me.
Ishamiyal is offline   Reply With Quote
New clutch installed now I have questions Paul Revere Transmission (AT/MT) & Driveline 4 03-19-2010 10:44 AM
compressor surge after fmic install drkwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-14-2008 04:12 AM
Td05, FMIC, atmospheric BOV....compressor surge? GripGC8 Pre-2002 Factory Turbo Powertrain 4 11-30-2007 07:57 PM
***TGV deletes installed, now i have a check engine/flashing cruise*** All4bSpinnin Engine Management & Tuning 30 05-11-2007 01:10 AM
I have compressor surge! Please help!!! adamsrs Normally Aspirated with bolt-on Forced Induction Powertrain 16 10-10-2001 05:20 PM
