Old 04-08-2004, 10:09 PM   #1
DanZ
Member#: 21970
MBP wingless WRX
TMS Tuned / [email protected]
Default Residual oil leak at oil pan drain plug??
I have noticed that I am getting oil residue around the drain plug of my 02 wrx. I always watch where I park and there are no drips on the ground, but there is enough that it always looks like a drop is gonna fall from the pan. I have checked the oil level priodically and even the dealership didn't say anything was wrong when I brought in it for another problem. I did I search, came up with nothing. Guess I'm just worried. Also, the drain plug does have its aluminum washer on there. What if I used a rubber washer on top of that? Would it melt? any help is appreciated. thanks
-Dan
DanZ is offline   Reply With Quote
Old 04-08-2004, 10:12 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
The washer is supposed to be changed every time the plug is removed.....don't use any rubber washers....bad juju...
Get a new washer at the dealer and see what happens after the next oil change...the 'curved' side of the washer goes against the oil pan....and the plug gets 33ft-lbs
Old 04-08-2004, 10:18 PM   #3
DanZ
Member#: 21970
MBP wingless WRX
thanks scotty. you always come though with the quick replies . I may have not replaced that washer last time - that could be the answer.
btw, scotty, I installed those sti struts with rs-r springs - there awesome. much improvement from the stock struts w/tanabe springs.
-Dan
Old 04-08-2004, 10:20 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
Kool Glad it worked out for ya.
How's the overall drop with that spring/strut combo?
Old 04-08-2004, 10:27 PM   #5
DanZ
Member#: 21970
MBP wingless WRX
the drop is perfect for me. I got to take some pics to post. still a little space in the rear well, and a little more in the front, but an even drop overall. my lips make the car too priety low though.
-Dan
Little Oil Leak Near Oil Pan 09 WRX BigSteiner5 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-19-2010 11:16 AM
FS: 04 oem oil filters and oil pan drain plug slvr bullet Engine/Power/Exhaust 2 12-04-2008 12:33 AM
floor pan, drain plugs GripGC8 Interior & Exterior Modification 2 10-03-2007 06:36 PM
WTB!! NEED HELP! Oil Pan Drain Plug w/ Oil Temp Sensor Hotrodguru Texas Impreza Club Forum -- TXIC 5 01-02-2004 12:50 PM
NEED HELP! WTB: Oil Pan Drain Plug w/ Oil Temp Sensor Hotrodguru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-01-2004 10:18 PM
