Welcome to the North American Subaru Impreza Owners Club Sunday January 25, 2015
Old 04-08-2004, 11:11 PM   #1
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
Default Help! Belt snapped and shredded. What size do I need?
So one of my belts , the AC one shredded off and I need to know what size it is and where to get one. I have an UNderdriven pulley so its going to have to be smaller than stock but does anyone know the specific # or size or whatever? Both belts are going to replaced so do you know what sized I need.
btw I serached high and low and found nadda.
Matt
2.5RSMatt is offline   Reply With Quote
Old 04-08-2004, 11:18 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
First- it would help to post the type of pulley you have, different ones may require different size belts.
Second- belts do not shred and snap for no reason, this is not normal wear. Examine all the pulleys carefully for damage, looseness or misalignment and correct any problems you find before replacing the belt.
Old 04-08-2004, 11:23 PM   #3
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
mkay. well its an unorthodox racing UD pulley. I know they don't shred and snap for no reason. It was making noise before and the belts on were a little loose and at the highest mark so I needed new belts. I'm just wnating to know if I can pick some up at a local store or if they are some sort of special order.
Oh and heres the belt.
Old 04-09-2004, 01:12 AM   #4
rabbitnutz
Member#: 51940
hey, you can pick them up from any local autoparts store, when fitz put mine on, it didn't come wiht any belts, so we had to run to a local autozone and pep boys, we got the belts from pep boys i believe, and here is the part numbers:
4 ribbed belt: 340K4
5 ribbed belt: 335K5
hope this helps, and good luck
rabbitnutz is offline   Reply With Quote
Old 04-09-2004, 01:40 AM   #5
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
thank you. much appreciated
Old 04-09-2004, 08:21 PM   #6
bheinz57
Member#: 37870
2012 ISM WRX
'07 FXT Sports
And for reference, write it down for next time. Especially if you run other than stock size belts, keep a part # or belt identification # handy in the glove box. This tip from me from a problem in the past. It is a good idea. Brian
bheinz57 is offline   Reply With Quote
Old 04-09-2004, 09:44 PM   #7
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
Wnet to pepboys and they only hade the AC belt. (340K4)
They have never heard of the other size (335K5)
Matt
Old 04-10-2004, 01:08 PM   #8
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
Read this and this. It explains how to deceipher the belt name and which belts you need.
bigdweeb is offline   Reply With Quote
'06 STi Spark Plug Snapped in Head.. What to do? SpoolinWRX4 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 03-15-2010 12:14 AM
Help figuring out what size fuse I need when adding another amp WRblueX_Guy Car Audio, Video & Security 15 12-24-2005 04:52 PM
what size do i need ? 05wrxtc Interior & Exterior Modification 2 12-10-2004 06:00 PM
Help, need a new clutch, what else do I need?? xenonk Transmission (AT/MT) & Driveline 0 09-22-2003 12:41 AM
what tap size do i need for a defi egt sensor mount? Otaku64 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-18-2003 02:10 AM
