Old 04-08-2004, 10:25 PM   #1
hoku123
Member#: 41853
2002 Impreza WRX
RED
Default Down Shifting from 2nd to 1st
Ok So i dont know what to say so i will just say it all and i hope it makes sense. I down shift a lot and i was just wondering why is it that i cant go from 2nd to 1st going like 35 mph i put the clutch in and then move the stick up but there is a big force holding the stick basically in neutral. After i hold the stick there for a good 2 seconds (still going the same speed) the stick goes into 1st. IT just seems really wierd to me because down shifting from any other gear doesnt do that and i was just wondering if that is normal, or am i doing something wrong? By the way once i get the stick into 1st and before i let out the cluch i rev the engine enough but i dont think that has much to do with my question. So if someone could just inform me a little on this subject i would appreciate it.
hoku123 is offline   Reply With Quote
Old 04-08-2004, 10:32 PM   #2
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
It's normal. 35 mph is pretty high to be downhifting into 1st. Try double-clutching; that will make it go into 1st much easier.
Mike Wevrick is offline   Reply With Quote
Old 04-08-2004, 10:32 PM   #3
skimmilk68
Member#: 53385
05 Titan 4x4
Puh-tooey
hey be happy you can get it in 1st at all . .. seems like you're forcing it in though, most of us cant get in 1st at all when the car is moving. i love my wrx in almost all aspects but tranny is bleh... i guess you can consider our cars the perfect girlfriend with a 3rd nipple
skimmilk68 is offline   Reply With Quote
Old 04-08-2004, 10:50 PM   #4
hoku123
Member#: 41853
2002 Impreza WRX
RED
thanks guys i appreciate it
Old 04-08-2004, 11:05 PM   #5
joebobanaught
Member#: 43566
2002 WRX Sedan
You can try rev matching and double clutching. It makes getting into gears a lot easier, but 35 mph is pretty high for 1st
joebobanaught is offline   Reply With Quote
Old 04-09-2004, 12:19 AM   #6
virulous
Member#: 14035
2002 Impreza WRX
Midnight Black
exactly... rev matching should be enough
virulous is offline   Reply With Quote
Old 04-09-2004, 10:15 AM   #7
Mike Wevrick
Member#: 24654
1957 Taggart Comet
Well for whatever reason its not. Double-clutching does the trick for me most times. 35 mph should be at least 3000 rpm in 2nd, though, so why would you want to downshift into 1st at that speed?
Old 04-09-2004, 10:24 AM   #8
Mopho
Member#: 32334
05 Outback
Caterham 7 Superlight R
I've never owned a car that would let me put into first at anything less than a crawl. They are designed that way (with a lock out), so people who try to put it into first at 35mph don't blow the tranny/engine/diffs/etc.
Mopho is offline   Reply With Quote
Old 04-09-2004, 11:04 AM   #9
WRXGR
Member#: 58487
Subaru Stars
man it's no wonder everyone is blowing tanny's!!!! i don't know of any car that would allow u to put it into first at any speed higher then 5 mph. I'm a mechanic and know better. when you force the tanny into that kind of abuse your only asking for trouble. This is why I'll never buy a used wrx
WRXGR is offline   Reply With Quote
Old 04-09-2004, 02:45 PM   #10
ITWRX4ME
Member#: 24472
2001 Miata
So, would you say that accelerating to 35 mph in first gear then lifting the throttle, allowing the car to decelerate, is abusive?
ITWRX4ME is offline   Reply With Quote
Old 04-09-2004, 02:55 PM   #11
Aphex28
Member#: 11506
2015 WRX
I don't really get the car back into first unless im going slower than 10mph.. i don't like forcing it in there. But if you really need to get in there, double clutching and revmatching works
Aphex28 is offline   Reply With Quote
Old 04-09-2004, 03:16 PM   #12
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
No, but dont expect first gear or your syncro's to last very long when you are forcing it into first gear at 35. Go in the NE forum and ask Zac if you dont believe me, he went through 2 tranny's playing that game. I havent really been able to do it in many other cars, but forcing it is not the way. If you really need to, try to rev match it....
Gfunk720 is offline   Reply With Quote
Old 04-09-2004, 04:27 PM   #13
Caddy Daddy
Member#: 11070
2004 SG9, Audi S8
Ducati ST2, BMW R100/7
no kidding
HOKU - if you like your car, dont put it into first gear or reverse unless you are at a complete stop.
Caddy Daddy is offline   Reply With Quote
Old 04-09-2004, 09:08 PM   #14
hoku123
Member#: 41853
2002 Impreza WRX
RED
what is rev matching? is that just reving it to where i thing it wouldbe in that gear at that speed? but i will take all your advice and not do it.
Old 04-09-2004, 09:18 PM   #15
Caddy Daddy
Member#: 11070
2004 SG9, Audi S8
thats the idea of it. to answer your original question, to downshift into 1st from 2nd, push the clutch in, drop it out of 2nd and into neutral, let the clutch out completely, give it a little throttle 'blip' (not too much), and while its 'blipping' push the clutch back in and gently direct the shifter from N into 1st. that way, you dont hit the lockout on 1st, and the car is much happier. this should all take place in ~ 1 second, and when you do put the car into 1st gear, you should not be exceeding 5-10 mph unless you want unpleasant surprises down the road.
hope this helps
the term 'rev-matching' has been thrown around and defined with different meanings, FYI
Old 04-09-2004, 09:55 PM   #16
collegedropout
Member#: 42569
adds to the douchery
level round' here...
Doesnt 35mph seem a little high for a downshift!!!! I mean that would be above redline in my WRX.
collegedropout is offline   Reply With Quote
Old 04-09-2004, 10:25 PM   #17
Mike Wevrick
Member#: 24654
1957 Taggart Comet
bah! You are right about reverse of course, but there is no reason you should not downshift into 1st just like other gears. Not at 35 mph, though, and not by forcing it in.
And AFAIK there is no "lockout" on 1st.
Old 04-09-2004, 11:10 PM   #18
WRXGR
Member#: 58487
you hit the head on the nail Gfunk720....again in any car u dont want to drop it in 1st above 5mph. anything above and your'e really chewing up the syncros
Old 04-10-2004, 01:04 AM   #19
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
complete stop for first is nonsense... how else does one expect to rip out of a hairpin turn (on the track of course)? my wrx loves that move... hard breaking into a turn, heel an' toe to second at 50, again to first at 25... music to my ears.
back to reality... for day to day driving, the downshift into first isnt very important. try a little throttle blip, to match the rpms to gear (figure the ratio according to your speed). dont fuss with downshifts tho too much. its fun to engine brake and all... but wouldnt you rather wear your brake pads than your engine/tranny/clutch?
LatentWagen is offline   Reply With Quote
Old 04-10-2004, 02:48 AM   #20
firedust
Member#: 38795
2003 WRX
Sonic Yellow
doesnt first gear in redline hit 35 mph?
heh...dont do that.
once the oil warms up i can get into first at about 12-15 mph if i need to....i double clutch if i need to in stop n go traffic..but as of late im just a bit harder on the brakes. i need this tranny to hold up another 30K but i got plenty of moeny for new pads and rotors.
firedust is offline   Reply With Quote
Old 04-10-2004, 09:53 AM   #21
fastsubie
Member#: 21999
2012 Wrx
maybe if 1st had a triple cone syncro like a real tranny should you could get it in above 10mph. Mine is worse than anyones. Mine wont go in above 5mph! Double clutch, rev match, heel toe, nothing will get it in. I'm saving for a 6spd swap or maybe just a RA gearset and new syncros. This car would be sooo much better at the track if you could wip out of a low speed corner in first at 60000 rpm instead of 2nd at 3000rpm.
My $0.02
-fess
fastsubie is offline   Reply With Quote
Old 04-10-2004, 10:41 AM   #22
Jaux
Member#: 56923
04 wrx
Down shifting on 35mph, 1st gear...in any car I think it is pretty high I wouldn't wanna risk anything.
Jaux is offline   Reply With Quote
Old 04-10-2004, 12:39 PM   #23
Gfunk720
Member#: 42549
E92 M3 M\\\
Why do people keep encouraging down shifting into first at over 5-10? Do you not realize that the tranny will just not tolerate action like that for long? There is a reason that it doesnt just pop into place, because there is too much tension on the gears to make the switch cleanly.
Im not saying it cant be done, because it can. But if you value your tranny and arent looking to do a gear swap in the next 20k miles, why even attempt it?
Like I said, If you dont believe me go search around in the tranny forum. Countless people have destroyed these weak trannies because they think they can drive this car like their old honda or BMW. Fact of the matter is that the suby gear box is out dated, and cant really handle the power being driven through it..
I guess it is a good way to motivate yourself to switch to RA's, which will be several thousands of dollars
Old 04-10-2004, 12:59 PM   #24
joebobanaught
Member#: 43566
2002 WRX Sedan
It is possible to get it into 25 w/o much trouble with correct rev matching, since you're matching the engine speed to the transmission speed, there isn't much tension on it (correct me if i'm wrong). Because if i'm going 15 mph, and i need to get into first, let's say because I need to go up a hill, then being on such low RPMs in 2nd won't give me the power to do so. Therefore, the logical thing to do is go into 1st to get the revs for the power to get up the hill. When you're on a street, you can't just stop, get into first and then go. So it is possible to slide it in w/o much trouble if you can rev match correctly.
It's hard to get it into 1st gear if you just leave the car idling unless it is basically at a complete stop, but it becomes almost effortless if you rev match it.
Though, I rarely ever downshift to 1st, it is very possible to do so without going to a crawl or a stop and without forcing it to do so. I think 35 mph is really high to be in first, but 25 doesn't sound too bad.
Old 04-10-2004, 05:59 PM   #25
jedjed1
Member#: 46937
2004 STi
Silver/Silver
Why would you possibly want to downshift into first at all? Second is such a versatile gear. In my STi, I can be going 3 mph and have no problem just chillin in 2nd. I was taught to never ds into 1st when I first learned to drive a manny. Why would you want to do that?
jedjed1 is offline   Reply With Quote
90 loyale shifting from 2nd to 3rd brokenrim Transmission (AT/MT) & Driveline 0 10-11-2006 10:16 AM
Shift from 2nd to 1st on tight turn. How?? Rally Punx Motorsports 56 04-09-2003 11:09 AM
('93-'01) Can you downshift from 2nd to 1st at 15 mph? Cupholder Impreza Forum 36 10-22-2001 07:44 AM
('93-'01) Test drove a WRX (again) - No problem downshifting from 2nd to 1st Cupholder Impreza Forum 4 10-21-2001 08:04 AM
weird noise when down shifting from 3rd to 2nd Ghostrider Vancouver Impreza Club Forum -- VIC 7 03-31-2001 04:55 PM
