Old 04-08-2004, 10:34 PM   #1
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
Unhappy Leaking Fluid? worried.
Ok can anyone give me an idea on what this may be? Teh fluid is not like water but more of an oil based substance. I'm worried. I'm going to try take her in tomorrow but I still want to know what this is.
Matt
2.5RSMatt is offline   Reply With Quote
Old 04-09-2004, 11:03 AM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
My guess is that is ATF coming from your power steering pump...
Old 04-09-2004, 09:49 PM   #3
obyone
Member#: 16523
What color is it? If it's light brown to dark brown/black, it's engine oil. If it's reddish, it can be power steering fluid, green is coolant, and yellowy-brown is MT tranny fluid, grey is usually just grease.
Rock on brudda.
obyone is offline   Reply With Quote
Old 04-09-2004, 09:56 PM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I was working on it with him, and I couldnt tell if it was engine oil or ATF fluid. I couldnt find the leak location, but it might be under the timing belt cover.
Old 04-16-2004, 04:15 AM   #5
obyone
Member#: 16523
Why would you have ATF near the timing belt cover? The trans is on the other side of the engine.
Old 04-16-2004, 01:49 PM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
In addition to color, you can sometimes i.d. a fluid by it's odor. Coolant smells sweet, p.s. fluid has a sharp burnt smell to it, and oil smells like oil of course.
Tim Sanderson is offline   Reply With Quote
Old 04-16-2004, 07:12 PM   #7
obyone
Member#: 16523
Coolant also has a sweet taste to it. It's poisonfully delicious.
Just by looking at the pic, without access to a better pic, I'm guessing it's either engine oil or power steering fluid.
Old 04-16-2004, 11:16 PM   #8
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
ATF is what you use for power steering fluid.
Old 04-17-2004, 08:13 AM   #9
obyone
Member#: 16523
I guess it shows that I've never owned an automatic, and my RS is the first with power steering.
2008 STI AC pulley, smoking and leaking fluid. Alfaneggio Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-06-2009 07:26 PM
installed springs, now the car is leaking fluid DanmanWRX Brakes, Steering & Suspension 3 10-29-2006 11:44 PM
wastgate leaking fluid? raglan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 07-03-2005 02:44 AM
car leaking fluid? awdaddict172 Newbies & FAQs 3 07-25-2004 03:42 PM
Leaking fluids Jiz311 Newbies & FAQs 3 05-31-2002 09:36 PM
