Old 07-15-2000, 02:12 PM   #1
STi Sev
Member#: 2876
99 Impreza
Rally Blue Pearl
Lightbulb Atttn: TRi tuning/8Complex
This is the deck that I have.. See I dont even know if it has wattage
DRX9575Rz Features:
Z-Enhancer EQ Selector with Adjustable Effect
8 Color Full Dot Display with Screensaver
Rotary Volume Control
Fully Motorized Face
CeNet Controller
Multi-Changer Capable (CD/MD)
Pre-Amp Output Only
6 Channel/4 Volt RCA Line Level Ouptut with Non-Fade Subwoofer Output
Subwoofer Level Control
TV Tuner Control
DRX9575Rz Features:
EQ/DSP/Crossover Control
Zero-Bit Detector (TM) Mute Circuit
8X Oversampling Digital Filter
Dual 1-Bit D/A Converters
RDS Tuner
CD Text Ready
Disc Title Memory
Prism Key
Magi-Tune+ (R) FM
18 FM/6 AM Presets
Included Infrared Remote Control
STi Sev is offline
Old 07-15-2000, 02:15 PM   #2
STi Sev
Member#: 2876
99 Impreza
Rally Blue Pearl
Post
Case Situation
My deck doesn't run wattage. Can the subwoofer up to the 40.2 Rockford Fosgate amp and turn the bass fairly down. (I dont to blow it!) Would this work?
STi Sev is offline
Old 07-15-2000, 02:15 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
What are you looking for, Sev? If you're talking about an internal amp so you can just run your speakers off the radio directly, it doesn't have one ("Pre-Amp Output Only"). You'll have to use an amp(s) no matter what.
8Complex is offline
Old 07-15-2000, 02:18 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I don't know Rockford's amps, but if you get a pre-out to it and then run that to the sub, just turn the gain on the amp all the way down and slowly turn up the stereo. Start slowly turning up the amp gain little by little until you get the radio up to about 90-95% of volume, where the gain on the amp should be set to put out the volume from the sub that you'd like. From there, all you'd need to do is some fine tuning.
BTW, why address the stereo question to me? I haven't posted much about it and it's been a while since I've tuned them... not that I really forgot it all though.
8Complex is offline
Old 07-15-2000, 02:40 PM   #5
STi Sev
Member#: 2876
99 Impreza
Rally Blue Pearl
Post
Hey 8Com,
Thanks for the info.
Im not sure if my rockford fosgate 40.2 has pre-amp. Shouldn't it?
STi Sev is offline
Old 07-15-2000, 02:42 PM   #6
STi Sev
Member#: 2876
99 Impreza
Rally Blue Pearl
Post
8Com,
I have 3 amps
225.2
75.2
40.2
Here are the specs for the 75.2
37.5 Watts x 2 at 4 Ohms
75 Watts x 2 at 2 Ohms
150 Watts x 1 at 4 Ohms
.05% Max Distortion at 4 Ohms
Frequency Response 20Hz to-20kHz
Bridgeable
1 Xcard Crossover
MEHSA Technology
11 9/32 x 9 5/8 x 2 5/8
28.65cm x 24.4cm x 6.6cm
STi Sev is offline
Old 07-15-2000, 03:22 PM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
No no... pre-amp is in the radio itself. From what I read about your deck up above, you don't have any, but with those amps you should be fine to run you whole stereo.
While we're at it, can you state this in English - "My deck doesn't run wattage. Can the subwoofer up to the 40.2 Rockford Fosgate amp and turn the bass fairly down. (I dont to blow it!) Would this work?"
LOL, I'm not sure what you're looking for. Maybe to see if your sub will blow up if you put it on that amp?
Actually wait... you're looking at hooking up a Subaru factory sub, aren't you? I thought it had an internal amp in it, didn't it? You'd need a line level input in that case, making your other amp you had for your sub useless.
8Complex is offline
Old 07-15-2000, 08:22 PM   #8
chris300zxtt
Member#: 532
93 Nissan 300ZTT
Black on Black
Post
Well....hmmm. I am not a stereo expert, so here's my input.
Your CD deck has no internal amp (ie: no 40x4 etc) running it.
Now, with a set-up like this, every speaker in your car is run with amplifiers. However, the stock sub is pre-amplified ( I believe), meaning that it has a built in amp. So, it would seem logical to think that the sub/amp from Subaru would hook up as easily as any amp would, it is just that the subwoofer is built in.
It's like the Bazooka bass tubes. You wire up the amp only, so you shouldn't have to play with your amps (Rockford's) as far as bridging, etc goes.
Chris
TRiTuning
chris300zxtt is offline
HTML code is On
TRi Tuning TRI-STATE deal untill the end of July Faraz Tri-State Area Forum 0 07-25-2001 10:07 PM
('93-'01) TRI Tuning........Ugh....where is my freaking part? ARG Impreza Forum 77 05-08-2001 12:35 AM
TRi Tuning??? Legacy STi L Legacy Forum 5 04-29-2001 08:37 AM
Tri Tuning Carbon Fiber Legacy Hood? CtGT Legacy Forum 6 04-13-2001 06:34 AM
TRi Tuning vs. Ralispec, who is your pick? Deznuts05 Tri-State Area Forum 9 04-03-2001 05:53 AM
